Is it possible for the choke to freeze open?
gmanxiii
PostPosted: 10:13 - 21 Dec 2007    Post subject: Is it possible for the choke to freeze open? Reply with quote
Went to ride into work this morning, started the bike on full choke and ran for a min or 2, then switched the choke off only it didnt, the switch was in the off position but the bike was still revving as if it was on. So i figured it was frozen... only i ran it for about 5 mins and the bike started heating up and it remained the same. So its either frozen or seized? If the choke cable was to have snapped, surely if would just remain off right?
I kills hondas
VFR400NC30 > ZZR600 > CBR600FX > CBR1000rr
the grim reaper
PostPosted: 11:47 - 21 Dec 2007    Post subject: Reply with quote
What bike?
Some bikes, like the carbed Fireblade, have a choke 'bar' that is attached to the cable, if this is corroded, then the choke can stick open, even when the cable is pushed back.
Grim
gmanxiii
PostPosted: 12:07 - 21 Dec 2007    Post subject: Reply with quote
Hi its an NC30, whats a choke bar? ive had the tank and airbox off in the past and see where the cable goes into the choke mechanism.
I kills hondas
Ichy
PostPosted: 12:16 - 21 Dec 2007    Post subject: Reply with quote
Its stuck open. Its happens a fair bit this time of year with various bits of the bike. Water and crud get in all sorts of places, this with a general lack of grease or oil cause bits to fail.
For starters, if its cable operated then check the cable is ok. On the carbs there will be a bar that opens the chokes on all the carbs at the same time. If you can see where it is then give it a good going over with penetrating oil and try, with the choke in the off position, opening and closing it by hand until it frees up.
gmanxiii
PostPosted: 13:46 - 22 Dec 2007    Post subject: Reply with quote
Right got it sorted now, it was stuck open however now it wont start. Just ran the battery dry from trying. Im guessing the spark plugs have been flooded having been sat in petrol for 24 hours... so will i need to replace the plugs or do you think i can just leave the petrol to evaporate away? Sad
cheers
I kills hondas
Phil_P
PostPosted: 14:47 - 22 Dec 2007    Post subject: Reply with quote
Whip your plugs out, turn off the petrol and spin the engine to clear any build up. Dry the plugs off, and preferably give them a good heat up with a blow torch or gas cooker ring. Screw them back in while still warm (carefully), and try to start with the battery charged. Chances are the plugs are just wet and maybe a bit carbonned up from running rich, but loadsa heat should solve that.
It is not enough to win, others must fail.
Moto Guzzi 1100 Sport Injection '96
The last post was made 18 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 47.85 Kb
