| Paivi |
 Paivi World Chat Champion
 Posted: 22:21 - 17 Dec 2007 Post subject: Gilera 50cc misfire |
The son of a friend of mine is having probs with his Gilera 50cc.
Can anybody offer any suggestions as to what could be wrong with the scoot?
| Quote: | My sons scooter has developed a misfire and power loss when the engine is warm. The scoot ran perfectly for a couple of weeks and then developed this problem. It has a sports exhaust fitted and a foam type air filter it has also been derestricted.
It is a Gilera 49cc with fuel injection. I have changed the plug and tried a standard air filter set up with no improvement.
Symptoms are, from cold the scoot whips off the mark and runs perfectly, however when it is warm it develops a misfire and loses power. It starts on the button and will idle and rev on the stand perfectly, seems to have problems when under load.
Do you think it is a fuelling or electrical problem breaking down under load. I do not believe it is a fatal problem as it runs ok at rest. Local scoot shop is scratching head.
| Quote: | Could anyone PLEASE help with this issue. I have fitted a new ECU, coil, stator, original airbox ( it had a foam filter on it ) and the bloody thing still will not run right.
It starts ok, although it struggles to stay running from cold initially, however from start when cold it fires off the line. Within a couple of minutes its starts misfiring and losing power at full throttle. If you roll off the throttle it will run smoothly although, then you are only running at 70% capacity so cannot get it above 20-30mph.
I would appreciate any input, as its becoming a small bike money pit ( £400 so far ) |
Ta muchly! ____________________ My other bike's a Monster...  |
| Paddy Blake |
| Phil_P |
 Phil_P Trackday Trickster
| djrichieb |
 djrichieb Nitrous Nuisance
| baldy |
 baldy World Chat Champion
| pax |
 pax L Plate Warrior
| GeorgeCBR |
 GeorgeCBR Scooby Slapper
| pax |
 pax L Plate Warrior
| GeorgeCBR |
| pax |
 pax L Plate Warrior
| GeorgeCBR |
| prawny1 |
 prawny1 World Chat Champion
| Phil_P |
| cheekythomas |
 cheekythomas Crazy Courier
 Posted: 20:56 - 21 Dec 2007 Post subject: |
If it was a sensor issue surely the garage will have checked for that as being a Fi purejet engine, it has a fault code system so will be flashing a fault code at them as soon as they plugged the diagnostic box in.
It needs to be looked at by someone who knows the machines, as first checks before bolting any bits to the purejet engine is..
A=check for faultcodes on the ECU
B=check fuel pressure is 8.0Bar at tickover
C=check air pressure is at 5.5Bar at tickover
D=make sure the 2 figures stay approx 2.5Bar different as the rpms are altered.
E=do a compression test to make sure its not a issue with the piston, which reminds me, what oil are you using as the FI motor needs specific oil, not any old 2 stroke from halfords.
But in main reply to the temp gauge issue, then yes the signal from the temperature sender unit screwed into the head goes direct to the ECU at terminal 9. Without that the ECU has no way of knowing what temperature the bike is so will revert to a base setting which will make it run like a pig. So thats certainly the first thing to do... but the fact the dealer hasnt makes me think it needs to go somewhere better as they clearly dont know the system.
Assuming youve been using the right oil so the engine should be ok, the only other common fault on these engines is water emulsion issues in the fuel injector body, which is easy to see by taking it out and looking into the pressure regulator, if its clean all is good, if its full of milky substance then it needs cleaning. The air compressor is also a common problem if the diaphragm splits.
| Phil_P |
| cheekythomas |
 Posted: 21:20 - 21 Dec 2007 Post subject: |
(i got the 8 and 5.5 wrong way round, now edited.... but 0.8bar pressure and the engine wouldnt run at all... wouldnt even fire)
Infront of the rear wheel running off the crankshaft is a compressor unit that pumps air into the fuel metering head at 5.5bar and increases with rpms.
(now added piccy from workshop manual )
https://img176.imageshack.us/img176/5/51089190mq7.jpg |
| cheekythomas |
| Phil_P |
| cheekythomas |
| cheekythomas |
| Phil_P |
 Posted: 22:32 - 21 Dec 2007 Post subject: |
I understand the principal now. seems like an awful lot of trouble to go to to do what atmospheric pressure does on most 'normally aspirated' bikes. Each to their own I suppose, no doubt it's sold loads of scoots.  ____________________ It is not enough to win, others must fail.
Moto Guzzi 1100 Sport Injection '96 |
| cheekythomas |
| davidlewtas16 |
 davidlewtas16 Renault 5 Driver
 Posted: 01:56 - 23 Dec 2007 Post subject: my gilera runner sp 50 has a problem can you help |
my runner has a problem where it keeps cutting out when i rev it can any of you help me  |
| cheekythomas |
 Posted: 16:14 - 23 Dec 2007 Post subject: |
As per your main post. More info is needed before any advise can be offered.
Age of machine, type of machine, type of fueling (carb or purejet), has it started all of a sudden or got worse, bike standard or had race exhausts etc fitted... give us some info and we will see what we think  |
| warped one |
 warped one Banned
The last post was made 18 years, 298 days ago. Instead of replying here, would creating a new thread be more useful? |
