RS 125 oil pump
stirlinggaz
PostPosted: 22:07 - 21 Dec 2007    Post subject: RS 125 oil pump Reply with quote
hi all,
can anyone give me some advice on how to adjust the oil pump on my Aprilia rs125?
when i refitted carb & started bike up, i let it idle for a minute or 2, then to my horror, i realised that i hadnt re-connected up the 2t oil pipe to the carb! doh!
anyway, while i had the pipe in my hand, i noticed that there wasnt any oil coming out?
even when i opened the throttle a little, nothing came out.
so i removed fairing, to discover the oil pump adjuster nut was hanging off!.
anyway i screwed it back into the rubber mounting, & the alignment marks look ok.
but when i turn the adjustment nut, either way, marks dont seem to move either left or right?
anyone tell me how much 2t should be coming out of the feed pipe into carb?
ie - would i be able to see it come out, a trickle, a drip or what?
& how do i turn pump up? as i dont seem to be using any oil!
the adjuster nut is the same type as on a clutch lever.
so do i tighten it down/in or loosen it off/out?
where would alignment marks be if it is turned up?
top mark to the left or right?
im sure all this makes sense to someone who has taken the cover off the oil pump recently!
anyway, any advice welcome,
cheers,
GAZ
stirlinggaz
PostPosted: 22:40 - 21 Dec 2007    Post subject: Reply with quote
Vincent wrote:
I'm not that familiar with the RS pump but if you've had the feed pipe off the carb you need to bleed the system. You usualy do this by opening the oil pump to maximum flow manualy while the bike is at about 2k RPM until all the air is expelled from the pipe. Be careful, don't let it run too long without oil or the whole motor will melt. If you're unsure if the oil is getting through check for blue smoke coming from the exhaust, cup your hand over the end of the pipe and you should see and smell the oil residues. Sorry, without pics or more info, I can't help with the adjustment.
Hi,
the rs has a bleed screw at the oil pump assembly.
just loosen off screw till all the air bubbles are out & oil starts coming out,then tighten back up.
i presume this does the same job?
i dont have a pic at moment but will look for one!
anyway its cable operated.
cable connected to throttle.
so as you open up the throttle, cable pulls open the oil pump via some sort of cam.
pump has an adjuster nut but need to know which way to turn it,
as either way doesnt seem to do much to the alignment marks on the cable assembly.
should i be able to see oil flow from pipe at carb end, if i pull it off carb for a short time?
& how do i increase oil flow?
cheers,
GAZ
stirlinggaz
PostPosted: 22:58 - 21 Dec 2007    Post subject: Reply with quote
Vincent wrote:
The bleed screw on the pump just bleeds the pump only. You need to get the air out of the pipe that goes to the carb too. That's right what you say about the cable opening up the pump - more throttle, more oil, but the cable has be adjusted to open the pump the right amount according to the amount that the throttle is open. There might be two markes on the pump body and the pulley that the cable connects to that line up on full throttle. Sounds like you need to make sure that the pump is together right after the adjuster nut came loose. Someone should be along with more info on pump adjustment
hi,
yes your right about the marks on the pulley.
But they line up at idle.
they are now lined up.
(this is all it says to do in manual.line marks up & use bleed screw.)
how would i know if there is air in pipe?
as nothing is coming out when i open throttle
im quite worried that oil is not getting into system & its gonna go bang!
cheers,
GAZ
PostPosted: 23:17 - 21 Dec 2007    Post subject: Reply with quote
Very little oil is pumped out. Quoted at 0.9% to 2%, so a tiny amount compared to the fuel you use, and at idle you are only using a tiny amount of fuel.
You can try holding fully open the operating lever on the oil pump while it is idling to push the oil through more quickly to check it is working.
PostPosted: 10:10 - 22 Dec 2007    Post subject: Reply with quote
You could avoid any damage by making a premix of oil in the fuel tank then after the fuel pump is working again drain it out.
Obviously only premix as much fuel as you need or else you will be wasting it when the fuel pump starts to work again.
stirlinggaz
PostPosted: 15:28 - 22 Dec 2007    Post subject: Reply with quote
Hi,
thanks for all the replies.
i like the sound of premix, just as a temp measure.
have i picked this up right, if i connect oil feed pipe back up to carb.
start it up,
then open up oil pump by moving the pulley by hand,
this should force more oil thru?
& i should see the difference in the smoke coming out of exhaust?
sounds pretty simple?
would i do any harm by just adding a little 2 stroke strait into fuel tank?
or am i being stupid/too cautious?
cheers,
GAZ
PostPosted: 16:15 - 22 Dec 2007    Post subject: Reply with quote
Note that if you run pre mix then in theory you have leaned the mixture off (the volume of oil is replacing the same volume of petrol). So don't thrash it running on premix unless you have adjusted the mixture to compensate. Should be fine for low speed / idleing use, just make sure you lob in plenty of normal petrol afterwards.
stirlinggaz
PostPosted: 17:31 - 22 Dec 2007    Post subject: Reply with quote
Hi,
thanks for that tip.
i was only thinking of putting a little 2t into tank as a temp measure.
wouldnt be for long & wont go too hard on it!
i think i worry too much!
just gonna tip a little tts into tank & take it from there.
i reckon if cable is working the pulley at oil pump & the marks are lined up & theres oil in tank,
surely it wont go bang?
watch this space!
cheers,
GAZ
PostPosted: 17:37 - 22 Dec 2007    Post subject: Reply with quote
When you tip it in shake your bike from side to side so that the oil mixes in with the petrol.
stirlinggaz
PostPosted: 17:53 - 22 Dec 2007    Post subject: Reply with quote
hi,
tanks off at the mo.
so was gonna tip in about 200ml of tts,
then fill it up with petrol from my jerry can.
give a shoogle & hope for the best!
cheers,
GAZ
PostPosted: 17:55 - 22 Dec 2007    Post subject: Reply with quote
That should be good. Do you want to premix that much though? When your oil pump is working again you would have too much oil going into your engine and as Kickstart said it would run lean.
PostPosted: 18:11 - 22 Dec 2007    Post subject: Reply with quote
At 2% that is enough oil for 10L of fuel. I would put about a litre in max, and around 20ml of oil. Enough to check the oil pump is really working (and to be honest if it wasn't the engine would have seized pretty rapidly), and easily diluted afterwards to be a negligable amount.
stirlinggaz
PostPosted: 20:03 - 22 Dec 2007    Post subject: Reply with quote
hi,
oops 200 ml , what was i thinking!
20ml, ok!
i actally thought it would be about 100ml,
but i get your point.
so i will bung in a couple of cap fulls!
cheers,
GAZ
stirlinggaz
PostPosted: 20:10 - 22 Dec 2007    Post subject: Reply with quote
edit,
i was thinking along the lines of -:
tank holds 13l of fuel,
put in 100ml-200ml of tts,
then fill up tank - 13l.
then just run it carefully till tank is about empty.
bike has been off road for a while so i dont know if everything is ok!
i have had cylinder head off,
drained coolant,
checked thermostat,
but as i mentioned, when i test ran it for a few miles,
it got very hot - 90 odd degrees!
was i thinking along the right lines with the oil in the fuel tank?
cheers,
GAZ
PostPosted: 23:06 - 22 Dec 2007    Post subject: Reply with quote
Right lines, but I would not use that much fuel. Do you really think you can avoid thrashing it for a couple of hundred km (how long a full tank can last when taken easy), plus if the pump is working then you are putting 2~3 times the amount of oil in that it needs.
If the pump had failed then then engine would seize. Unlikely it would cause it to overheat for long enough before for you to even notice.
Litre of fuel would be fine for the experiment.
PostPosted: 23:13 - 22 Dec 2007    Post subject: Reply with quote
You could change the jetting in your carb for the duration that you are running it with the premix.
I would listen to Kickstart and only do enough so that you can fix your fuel pump.
stirlinggaz
PostPosted: 10:14 - 23 Dec 2007    Post subject: Reply with quote
HI,
ok.
thanks for the advice.
i was thinking of more than a litre of fuel,
simply because it wont start with so little!
for some reason (& i have heard other rs owners say the same) it doesnt like to get low on fuel!
as soon as i get on reserve , i fill her up.
as it can be a nightmare to get her re-started when really low on fuel!
reserve holds 3.5l.
tank is completely empty now.
so would i be ok with say 4l of fuel & 50ml of tts?
that way i know i can get it started.
go for a wee run & if all ok- just fill tank up?
that should dilute whatevers 2t is left in fuel tank?
i just want so make sure it runs ok- oil pump wise before i start worrying about the temp.
that way i can rule out the unlikely event the overheating is oil related.
then move onto coolant system!
as i have no idea why it is getting so hot!
cheers guys,
GAZ
PostPosted: 11:37 - 23 Dec 2007    Post subject: Reply with quote
I think you may need a bit more oil for 4 litres.
50ml in 4 litres would make a premix of 1:80. When I premixed for my mopeds I did 1:25 or 1:32.
Linky
That gives you an idea of what to premix as 1:50 is 'DO NOT USE' and 1:100 is 'NEVER USE'.
You risk seizure if you use 1:80 so I would make a premix of 1:25 to be on the safe side.
stirlinggaz
PostPosted: 11:45 - 23 Dec 2007    Post subject: Reply with quote
hi,
thanks for the link!
very useful!
should be able to work out how much i should mix,
thanks again,
GAZ
stirlinggaz
PostPosted: 12:00 - 23 Dec 2007    Post subject: Reply with quote
mmmm,
ounces?
maths aint my strong point!
anyway if i go 1:24
=1000ml oil to 24000ml of fuel right?
this breaks down to 167ml of oil to 4 litres of fuel?
its been a long time sine i did any kind of maths in my head! lol
does that sound about right, tho?
cheers,
GAZ
The last post was made 18 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 137.19 Kb
