Carb/throttle/tick over issue
c-m
PostPosted: 16:20 - 22 Dec 2007    Post subject: Carb/throttle/tick over issue Reply with quote
I have been playing around with different carb setups inan attempt to fix the problem of my bike bogging down and cutting out.
I have fitted the carb this afternoon and fired up the bike. It ticked over faithfully at 1K however when in neutral and applying some throttle the revs would shoot up (as expect) but they would not come back down, unless I put the bike into gear.
My throttle cable is fine and the slide is returning to the bottom of the carb when the throttle is released.
Why do my revs not drop back down to idle when in nutral?
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
Paddy Blake
PostPosted: 16:39 - 22 Dec 2007    Post subject: Reply with quote
It sounds like there is air being sucked in from between the carb and the
head.Are you sure the carb is on all the way and the clips are tight.
Paddy.
c-m
PostPosted: 14:19 - 23 Dec 2007    Post subject: Reply with quote
Deffinately no air getting in. I've checked double checked and checked again.
It only occurs when opening the throttle, even when let go the revs stay at the same level they were for a good 20+ seconds.
Its almost like an improv cruise control Razz
The bike is an RD125LC
The last post was made 17 years, 363 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 41.86 Kb
