Spark Plugs
Dylan
PostPosted: 14:05 - 23 Feb 2002    Post subject: Spark Plugs Reply with quote
Ive got an nsr125rk, and got a new spark plug for it. The old one was an NGK BR9ECS. But the one my bike shop gave me for it was an NGK BR7ES. Is one of them for hotter combustioon or summin. They bothe work in the bike. All i want is the best performance, and not the high speed motorway cruizin.
Thanks
Dyl
the_icon
PostPosted: 17:57 - 23 Feb 2002    Post subject: Reply with quote
I have exactly the same bike. When my plug needed changing, phoned the local honda dealer and asked if they had any NGK BR9ECS in stock. When I went to collect it he thought I would need two, told him what bike I had and there was a knowing Aahh but no reason given.
I know this hasn't answered your question but the honda dealer suggested I keep to the ECS plug - but don't know why?
I will ask him and see if I can get a better answer.
PostPosted: 10:41 - 24 Feb 2002    Post subject: Reply with quote
The number is the heat range. The lower number is for cooler running engines and will make them run slightly hotter (spark plugs work properly over a narrow temp range). Use too low a number and the plug will run too hot and be damaged (and possibly burn a hole in the piston), too high a number and the bike will be more inclined to foul the plug, especially at low revs
If you are doing lots of round town mileage then you could consider dropping to an 8, but going down to a 7 sounds a bit risky
Dylan
PostPosted: 22:02 - 25 Feb 2002    Post subject: Reply with quote
Ill see how hot it gets on the temp gauge and give a report!!!
Dyl
PostPosted: 23:13 - 25 Feb 2002    Post subject: Reply with quote
At high revs by the time the temp gauge reacts it may be too late. It is not so much water temp that is affected but the combustion chamber temperature. The cooling system should have plenty in reserve.
Dylan
PostPosted: 19:14 - 26 Feb 2002    Post subject: Reply with quote
Is there any benefit to having a plug that burns hotter. The plug is the one that is recomended in the chart they had in the shop, i might of just had a cooler plug in to start with??? What has everyone else got in there RK's???
Thanks for the reply Keith, you might be saving me a hole in my piston!!!
Dyl
PostPosted: 21:35 - 26 Feb 2002    Post subject: Reply with quote
Honda say a BR9ECS, or a BR10ES for sustained high speed riding.
There is no advantage to having a hotter or colder plug as such, what is required is the plug with the correct heat range for your engine. Basically the difference is the amount of insulation round the centre electrode. Less insulation means more heat is transferred out of the combustion chamber. The pkugs work in a certain temperature range, outside which they will either start to blister and burn, or to foul.
Hunter
PostPosted: 03:51 - 03 Mar 2002    Post subject: Reply with quote
Hey Guys
I have a 92 NSR125RK with an BR9ECS plug, I think that you should stick to this because you can run into all sorts of problems if you go for too low/too high temp ranges!
bye...
N.I.N
PostPosted: 22:52 - 04 Mar 2002    Post subject: Reply with quote
I've got a set of NC30 plugs going spare if anyone wants them.
The last post was made 23 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 57.92 Kb
