MTT Y2K for less than 2K?
Whosthedaddy
PostPosted: 23:11 - 24 Dec 2007    Post subject: MTT Y2K for less than 2K? Reply with quote
Its funny how a seed is set and that it nags and nags and nags just like the wife.
Its both useful and yet scary at what you can google and find out on the net. The ability to build a turbine jet engine seems to be one of these ideas.
A pulse jet engine seems to be the most straight forward and simplest forms to build if not the most dangerous looking at its simplicity, whereas utilising a cars turbo and some metal piping, a bodged flame tube and afterburners means that you have a ready to go turbine engine? And, by using a cars turbo it would be small enough to strap to a bike. Wink
As mentioned things always look simple and the complexity is in the small print.
Problems that I can see would be:
Arrow starting the bike without the use of a wind source such as a vacuum cleaner or leaf blower
Arrow fuelling, most of the vids use propane but could a conventional fossil fuel be used or even diesel?
Arrow acceleration and more importantly deceleration, would brakes suffice and with no engine braking it could be interesting if the lights suddenly change
Arrow gearing, would a gearbox even be present on a bike? I have seen small electric motors on the rear wheel to allow moving the bike around easier rather than firing the beast up to do a U turn, but other than this why would there be a chain to the rear wheel?
Arrow insurance. Laughing
Arrow safety*
What say you, a homemade turbine jet engine for a bike?
* Jay Leno stated that he melted a cars bumper when in traffic as the car was too close to the exhausts / after burners. Laughing
Below is a photoshopped mock up of the yanks YSR project. they have yet to complete the project but from the pics it looks much better than the idea initially drawn up.
Itchy
PostPosted: 23:21 - 24 Dec 2007    Post subject: Reply with quote
Seems kind of simple (relatively compared to say my NTV which seems complex due to the shaft drive/single swinger type thing),
Ripping apart my CBR it seems really simple thinking about it, engine strapped to a frame which turns moving power to a chain....
comparatively....
but surely a jet engine would just be faced sideways say the air intake on the right , and a big heat proof sprocket on the left with a heat proof scotoiler / scot chain cooler on the left which linked to the rear .
This would mean that you would not have to make a complex rotation of the power 90 degrees as in Shaft drives (although shaft drive on the NTV is like 90 degrees at the gear box then another 90 degrees at the wheel). Though there would be sideways thrust of course lest it was ducted and there would need to be tons of heat sheilding.
With all the other ancilaries kept on like brakes/steering etc,
PostPosted: 23:21 - 24 Dec 2007    Post subject: Re: MTT Y2K for less than 2K? Reply with quote
I believe the MTT is driven by the wheels. Think the MTT ones uses a helicopter jet engine that's obviously designed to give a rotational output.
Obviously I don't think you could really do this in the same manner with a pulse-jet engine.
I've seen people who have shoehorned some moderately chunky jet engines into the back of cars, forget the details now though - I'm sure google would have further answers Smile.
You'd need a damn big jet engine to give you good acceleration I suspect.
If you haven't seen it, try and find a copy of the Scrapheap challenge where they had jet engined cars.
Whosthedaddy
PostPosted: 23:25 - 24 Dec 2007    Post subject: Re: MTT Y2K for less than 2K? Reply with quote
A VW Beetle springs to mind. Laughing
The way that the engine in the mock up I posted worked (or so I believe ) is that the intake is facing forwards with the flame tube sticking out of the right hand fairing with the exhaust going under the seat and literally pushes the bike along rather than driving the wheels.
https://www.badbros.net/images/jet_bike/co2_tanks_mounted_pics/AAAA0010.jpg
Not the best pic in the world, but you get the idea of the way that its mounted in the frame and is basically a slight variation on this arrangement:
https://www.salvatoreaiello.com/images/Main/Names.jpg
https://www.badbros.net/jetbike.html for the full story and write up.
PostPosted: 01:03 - 25 Dec 2007    Post subject: Reply with quote
Search for jet MR2 and you'll find some stuff. Jets don't have good acceleration until they are doing some speed already. Think of turbo lag on a much larger scale.
Also as G said the Y2K is wheel driven by a turboshaft from a helicopter, not a turbojet or a turbofan.
There are no rotating parts in a pulse jet, and precious few in a turbo based home built turbojet. So in short it will either burn your arse and not work, or not work.
The last post was made 18 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 50.99 Kb
