Aight I give, NC30 freaks/maintainers please help :mrgreen:
cypher
PostPosted: 00:35 - 26 Dec 2007    Post subject: Aight I give, NC30 freaks/maintainers please help :mrgreen: Reply with quote
Got a odd problem, the parking lights appear to not be working on my 90' NC30. Hi and Low beam on main works with no issues at all.
Any fuses, weak points I need to check? Both bulbs are fine. Got a useful part of your haynes you can scan and put up? Mine is coming Cool
Thanks in advance
NC30 Pilot | NO2ID Worcester Coordinator
Deano
PostPosted: 00:38 - 26 Dec 2007    Post subject: Reply with quote
im sure they dont have parking lights, on the imports anyhow.
if the brake lights arent working altogether then check the fuses in the box.
cypher
PostPosted: 02:55 - 26 Dec 2007    Post subject: Reply with quote
Just has the marking and the switch position on the switchgear is what made me think it should work.
The brake lights come on (dimly as I would expect) with the switch in the "P" position. Shouldnt that also mean a dim glow from the headlights?
If im wrong then tell me to shut up and I shall strike it off my list Cool
PostPosted: 11:03 - 26 Dec 2007    Post subject: Reply with quote
Usually, "P" on the ignition will switch on the sidelight at the front and tail-light at the rear. Pretty useless on a bike since the battery will be flat in hours.
cypher
PostPosted: 02:45 - 29 Dec 2007    Post subject: Aight I give, NC30 owners/maintainers please help [UNSOLVED] Reply with quote
Need to poke this thread. Im still baffled.
Anyone know what might be stopping the parking lights from working?
I have checked for any blatantly loose connections and cant seem to find any. The headlights work just fine in other modes. Dipped and Main work without issue with a healthy click from the relay. The taillight and clocks light up in the "P" position.
What other places can be checked? What are the facts on parking lights on NC30's are they actually not on the imports?
If it doesnt matter in an MOT situation then great, but this is a problem that will annoy me after a while.
MaybeGuy
PostPosted: 03:59 - 29 Dec 2007    Post subject: Reply with quote
you've probably had a new ignition barrel at some point.
iooi
PostPosted: 10:10 - 29 Dec 2007    Post subject: Reply with quote
Try a multimeter, start at the bulb and work your way back along the wire. Just make sure it is well earthed, connecting to neg on battery best idea.
Has the light switch got a position where only sidelight is on ?
Best guess, as above or wire has broken somewhere around headstock.
Tis about all you can do.
Assuming you are 100% sure bulb is OK.
The last post was made 18 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.82 - MySQL Queries: 13 - Page Size: 52.14 Kb
