Idling problem with my Neos
MikeNeos50
PostPosted: 23:48 - 22 Dec 2007    Post subject: Idling problem with my Neos Reply with quote
hi, i have a 2002 yam neos 50
History is i bought the bike, basically hasnt been on the road since 2003, probably been started every now and then. After giving it a fresh tank of fuel and 2 stroke oil, after being stubborn for 15 mins she finally started, after starting the first time every time following that it started pretty much straight away. But it fails to idle.
First job i changed the spark plug, bike would start but with the same symptoms. Then i removed the carb and gave it a thorough cleaning with carb cleaner, air line, removed bottom to release a possible water in float chamber. Refitted and tried it out still the same. Attempted to adjust the idle/mixture screws but failed to improve the fault.
fitted to the carb is an electrical componant, idle controller/solonoid?? not exactly sure myself but could that possibly the cause of an idle fault?
Any further suggestions would be brilliant! Thanks in advance!
mike
MikeNeos50
PostPosted: 20:36 - 26 Dec 2007    Post subject: Reply with quote
bump .... Question
baldy
PostPosted: 21:34 - 26 Dec 2007    Post subject: Reply with quote
Did you clean out all the jets? they are probably blocked up. If petrol is left to sit it turns in to a glue sort of stuff.
One day i will rule the world, just not today.
cypher
PostPosted: 01:35 - 27 Dec 2007    Post subject: Reply with quote
Cleaning the jets is a good start. But looks like you have already done that.
The electrical component is probably a thermo-element which is better known as an auto-choke. It heats up when the bike is below a certain temp. It may have died, which means you basically want to be revving her for a bit so she can warm up.
Other things to check are that airfilter is tightly connected to the bike. Make sure it is the idle screw you are actually turning.
NC30 Pilot | NO2ID Worcester Coordinator
MikeNeos50
PostPosted: 19:27 - 28 Dec 2007    Post subject: Reply with quote
cheers for the reply!!
with regards to the possible auto choke, i have kept it revving for few mins to warm her up but then letting it back to idle it just dies. im pretty sure all the jets are clear because i cleaned them with carb cleaner and a air line blower.
i have changed the air filter for a new one and it al seems to be ok.
would you happen to know say the basic setting for the idle screw? if i screw it all the way in how many turns out should i be looking at to reset it?
thanks again for the replies guys!
cypher
PostPosted: 03:50 - 29 Dec 2007    Post subject: Reply with quote
You might wanna buy a new thermoelement. Failing that, get a pipecleaner and shove it down your idle jet just to be sure. There has to be something blocking it.... Cool
The last post was made 18 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 47.09 Kb
