fizzing along
dave49
PostPosted: 15:41 - 27 Dec 2007    Post subject: fizzing along Reply with quote
Hi!Ive got two fizzes (yes Im sad to say im stuck in my youth)But ones a half finished project with a yb100 engine fitted.It has a spark but wont run(even with a bit of petrol down the barrel)Does anyone know if anything else needs changing before it will run.cheers all
cypher
PostPosted: 15:50 - 27 Dec 2007    Post subject: Reply with quote
Do a compression check on it. IF you dont have the tool just wind her over with your thumb over the plug hole. No matter how hard you try it should always be able to blow your thumb off the hole.
Good luck
NC30 Pilot | NO2ID Worcester Coordinator
dave49
PostPosted: 15:57 - 27 Dec 2007    Post subject: fizzing along Reply with quote
Good luck
It fells like its got compression!Its usually just acase of spark and fuel and that should be enough!cheers anyway
cypher
PostPosted: 16:34 - 27 Dec 2007    Post subject: Reply with quote
You arent using old fuel are ya? Is it a strong spark?
PostPosted: 16:57 - 27 Dec 2007    Post subject: Reply with quote
Just because a plug sparks, doesn't mean it will do so inside the engine. Change it for one you know is working.
Then check the points are correctly set. A spark is no use if it is happening at the wrong time.
dave49
PostPosted: 09:33 - 28 Dec 2007    Post subject: wont fire Reply with quote
No I havnt actually put any fuel in yet!I just put some down the barrel cos thats normally enough just to fire the engine if spark etc is ok.The spark looks fine and consistant when I turn it over.
dave49
PostPosted: 14:51 - 28 Dec 2007    Post subject: Reply with quote
Found the problem!Its the wiring etc.no condensor and needs new wiring loom(half the wirings broken)
The last post was made 18 years, 194 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.56 - MySQL Queries: 13 - Page Size: 51.15 Kb
