| GFK |
 GFK Scooby Slapper
 Posted: 02:49 - 23 Dec 2003 Post subject: What bike to hire, and where from?? |
I did my test on 19th December - failed miserably on 3 points. It was a disaster from start to finish. It pissed me off that the examiner was in a car, while I was on the bike freezing my bollocks off - the roads were wet and there were icy patches on the back-roads. Anyway, he tested the radio thing - it worked. He got in his car, told me to set off.
So off I went. Got to the test centre gates. Which way does he want me to go? He isn't saying anything. So I turned left and headed for the town centre. I went across 3 or 4 roundabouts - still wasn't hearing a peep out of the examiner. What the hell is going on?
I took a left, and pulled up. Turned out the batteries had died just after he told me to set off. So I had to do the rest of the test old-fashioned style, with him telling me where to go for the next half mile or so.
In the end I failed on three things.
1. Emergency stop. I locked the back wheel and the back end slid to the right. I controlled it, stopped in a very short distance taking into consideration the road conditions, got the bike quickly out of the way not forgetting life-savers. Yet I still failed for it.
2. U-turn. On an NSR! I pushed the bike around on the road to make sure it'd go, and it *just* went at full lock. I knew i'd fucked it there and then. I had to put a foot down half way round.
3. On the very last road back to the test center, I was so determined my speed wasn't going to waver above or below 30, that I failed to notice I was in a 20mph restriction. Failed for speeding!
That little lot brings me nicely onto the point of my post.
Points 1 and 3 I can deal with. If I do another U-turn on my next test on THAT road on my NSR, I'll fail for the exact same reason.
What would be a good 125 to hire for a bike test? I need something that DOESN'T turn like the titanic and is gonna get me through that u-turn safely. I'm pretty sure I did my CBT on a CG125, but it was ages ago and I really can't remember.
Also, does anybody know where I could hire a bike from in South Yorkshire or North Nottinghamshire? I'm having problems finding places. |
| Dusty |
 Dusty King of the Rim
 Posted: 05:28 - 23 Dec 2003 Post subject: |
Bad luck mate, sorry to hear that.
The U turn is always tricky under pressure, even when you're on a decent sized road. It all comes down to having very good clutch and rear brake control. Get another one booked as soon as you can, hopefully you might even get a working radio.
Who did you do your training with? Do they not hire bikes? Most training centers I know of have some 125s for hire. ____________________ Gallery |
| Ste |
 Ste Not Work Safe
 Posted: 08:52 - 23 Dec 2003 Post subject: |
Unlucky mate. Did they not ask you to push the bike in the road in a U turn first? You should tell him then if the road is too narrow for it. Put it down to nerves and you'll be ready next time  |
| G |
 G The Voice of Reason
 Posted: 09:40 - 23 Dec 2003 Post subject: Re: What bike to hire, and where from?? |
Right,:
1: It's worth going out in the rain and practicing emergency stops, but although you do have to use the rear brake, just make sure your foot is touching it.
Generally you want to avoid using the rear brake in such situations and I was definitely advised to only make it look like I was using, not actually use it .]
2: When I did my test I made sure I didn't push the bike on full lock, walk the bike around, but only at 1/2 - 3/4 lock, this way you've got plenty of space to spare, they should take you somewhere better if you don't. It's worth getting some U-turn practice in on the NSR as well. With some practice, you can counter the instinct to put your foot down, and do a U turn on full lock... you just have to train yourself to put more power on as the bike is about to fall.
3: Just one of those annoying things that the pressure does. Good luck next time .
As far as I know most training places will only hire bikes to people they're teaching. Have a look in MCN if you're really bothered by it, though most tend to be London based, but a bit more practice will probably save you £100.
Before my test I went out for several evening on a narrow road and did U-turns and emergency stops on my NSR. |
| Danny |
 Danny Ask Me About Stoppie School
 Posted: 10:58 - 23 Dec 2003 Post subject: |
Unlucky mate. I rented a CG125 for my test because I couldn't get the hang of U turns on my NSR and didn't feel like dropping it trying.
Tip for the U turn, look up and towards where you want to go, NEVER LOOK DOWN AND AT THE CURB, also keep the throttle busy. I was never good at U turns but I found this advise (when followed) made the difference between putting my foot down and completing a u turn successfully.
Good luck for your next test. |
The last post was made 22 years, 288 days ago. Instead of replying here, would creating a new thread be more useful? |
