| Danny |
 Danny Ask Me About Stoppie School
 Posted: 00:31 - 23 Dec 2003 Post subject: |
Could be carb icing, but not that likely I suspect. Tends to be worst in cold damp weather, but generally air cooled bikes are not too bad for it (although Kawasakis tend to be worst for it). Not sure what the weather was like when you took it for a run.
My old FZ would be fine at low speeds, and fine at high speeds for a couple of minutes, then start to suffer. It would be fine at higher revs except for drinking fuel. Just that when you slowed down it did not want to know below 4000rpm.
Have the carbs been balanced? This would mainly affect idle, but would not make it particularly great at small throttle openings (ie, trying for a constant throttle). Easy to fix but probably not that likely.
Also check the rubber diaphragms in the carbs. These had a reputation for failing in 1980's Kwaks. With these holed the mixture will vary fairly randomly.
Have the carbs been cleaned out? If not first try dumping a can of carb cleaner into the tank.
Also check the rubber carb mounts. If these crank the mixture will go all over the place.
Valve clearances tend to firstly give problems with starting. Would also probably be noticeable from a compression check (I assume compression is not too bad).
I would hope it isn't electrics, but ignition problems normally seem to mean the bike just doesn't run (not always, but most of the time).
| Danny |
 Posted: 00:58 - 23 Dec 2003 Post subject: |
| Quote: | Not sure what the weather was like when you took it for a run. | Cold weather.
| Quote: | My old FZ would be fine at low speeds, and fine at high speeds for a couple of minutes, then start to suffer. It would be fine at higher revs except for drinking fuel. Just that when you slowed down it did not want to know below 4000rpm. | The problem seems to start as soon as I hit 50 or above. I worked out is is doing 55mpg.
| Quote: | Have the carbs been balanced? This would mainly affect idle, but would not make it particularly great at small throttle openings (ie, trying for a constant throttle). Easy to fix but probably not that likely. | The idle is fine, I have no idea when the carbs were last balanced, doubt it was recently.
| Quote: | Also check the rubber diaphragms in the carbs. These had a reputation for failing in 1980's Kwaks. With these holed the mixture will vary fairly randomly. | Will do.
| Quote: | Have the carbs been cleaned out? If not first try dumping a can of carb cleaner into the tank | No they've not been cleaned out, but as I said i've dumped a load of redex in there. I thought redex was carb cleaner.
| Quote: | Also check the rubber carb mounts. If these crank the mixture will go all over the place. | That could very well be the problem.
| Quote: | Valve clearances tend to firstly give problems with starting. Would also probably be noticeable from a compression check (I assume compression is not too bad). | Don't seem to be any problems starting. Except that when I use the choke it wakes up half of Wimbledon. I haven't done a compression test, might be something to try.
| Quote: | I would hope it isn't electrics, but ignition problems normally seem to mean the bike just doesn't run (not always, but most of the time). | / me shudders. I really hope it's not electrics either, if it is I can hopefully try parts of the other bike. |
 Posted: 01:03 - 23 Dec 2003 Post subject: |
Probably not carb icing. 55mpg is too good. The FZ would drop from 45mpg to 25mpg, and you could watch the fuel gauge go down.
Carb balancing takes a few minutes with the right gauges.
Redex is not a carb cleaner. It cleans out the combustion chamber (unless Redex have brought out a new product).
For the carb rubbers check for cracks. You can bodge this up with silicone sealant.
Most likely it is mixture somewhere. Compression problems would affect starting.
Carb rubber and the diaphragms would be my main areas, but AFTER cleaning the carbs out. Old petrol is horrible stuff.
| Danny |
| Danny |
 Posted: 22:39 - 23 Dec 2003 Post subject: |
Water will mainly affect the electrics, unless it is getting water into the petrol tank. Thats a point. Charlottes GPZ500 is a bugger for getting water into the tank which doesn't cause a problem until you switch onto reserve at which point you either need to drain the carbs or push.
Get a spray can of something and spray it onto the carb rubbers with the engine running. If the idle speed varies then you know there is an air leek (just be careful with spraying flammable liquids on a running engine).
| Danny |
 Posted: 23:20 - 23 Dec 2003 Post subject: |
How did the water get into Charlotte's tank.
Hmm flammable spray near a running air cooled engine..... could be interesting. I'll try this tomorrow and see what happens. |
| Danny |
 Posted: 15:50 - 24 Dec 2003 Post subject: |
Right, had a little look around the carbs, the rubber seal looks very bad. I tried the spray thing, no effect. I pulled the rubber of one carb a bit, no effect. Might take the carbs off and try and get the rubber on properly or get some sealant stuff. |
| Danny |
 Posted: 00:24 - 25 Dec 2003 Post subject: |
I've been told that boiling the old rubber should make it easier to fit, I might try that.  |
| Milo |
 Milo World Chat Champion
 Posted: 01:45 - 26 Dec 2003 Post subject: |
those things were a right cunt to get back on after removing the restrictors. Very, very fiddly!
they look pretty much as they did when i had it, and it was running fine for about 10 months like that until it was garaged.
Damn! I forgot to take my old horns off the thing  ____________________ Shaft drives rule.  |
| Danny |
| Milo |
 Posted: 14:04 - 26 Dec 2003 Post subject: |
I haven't looked for the old restrictors. but I know they're sat in my tool box.
I did get some better horns for that bike but don't worry about it - i don't think i could be arsed to fit them!
No idea about the fuel filter.
the carbs were fully drained before garaging to avoid them gunking up so i thought they'd be ok. ____________________ Shaft drives rule.  |
| Dusty |
 Dusty King of the Rim
 Posted: 12:40 - 27 Dec 2003 Post subject: |
(Danny)
We've got the carbs off, they seem to be clean (generally in good nick), but we have cleaned them anyway. There was engine oil in the airbox, which was coming from the crank case breather.
We are boiling the carb rubbers now.
So we're a bit confused as to what the problem could be.  ____________________ Gallery |
| Kickstart@Work |
 Kickstart@Work Scooby Slapper
| EuropeanNC30R... |
 EuropeanNC30R... Gay Hairdresser
 Posted: 13:47 - 27 Dec 2003 Post subject: |
| Milo |
 Posted: 14:14 - 27 Dec 2003 Post subject: |
Oi, that was a nice bike!
Definitly not a case off too much oil in there - not when i had it anyway! ____________________ Shaft drives rule.  |
| Dusty |
 Posted: 14:26 - 27 Dec 2003 Post subject: |
| EuropeanNC30R... |
| Milo |
 Posted: 16:21 - 27 Dec 2003 Post subject: |
I can't wait to get mine on the strip.
All that torque and the weight up front I reakon i could do pretty well. ____________________ Shaft drives rule.  |
| Danny |
 Posted: 23:20 - 28 Dec 2003 Post subject: |
Update:
Got the front wheel bearing and zaust fixed with help from G and Ste, thanks guys.
Still got the problem with the carbs (?) it has got a fair bit better now, but is still there.
I'll try to MOT it again and see what happens. |
| Milo |
 Posted: 10:07 - 29 Dec 2003 Post subject: |
I know you've done the whole redex thing, but i'd take it out for a good hot run and put the engine under strain and rev high. Cos of the MOT legal thing i dunno if you've done this yet but it could be an idea.
Also check the vacuum hose that goes to the top of the carbs (right at the top in the middle) as if that's coming adrift it could affect the fuel flow. It's a short pipe and fiddly so could easily happen. ____________________ Shaft drives rule.  |
The last post was made 22 years, 256 days ago. Instead of replying here, would creating a new thread be more useful? |
