| lard44 |
 lard44 Borekit Bruiser
 Posted: 18:07 - 02 Jan 2008 Post subject: Utter n00b spark plug question... |
Hi all,
Picked up my first bike at the beginning of December...a Suzuki RG 125
https://i83.photobucket.com/albums/j310/lard44/DSC00159.jpg
I took all the bodywork off (held on with cable ties when I got it!), patched up a few cracks, and am in the process of wet/drying and priming the lot - the nasty glossy stuff had dripped and smeared everywhere!. I also had to sort out the electrics - the previous owner cut off the indicators and horn to pass the MOT I guess.
Tried to start it today (having been idle for a month) and, surprise surprise, it wouldn't. The engine turns over but no go. So I was going to check the spark plugs but...where are they?
It must be reeeeeealllllllly obvious but I dunno where to look...help!
Thanks,
P |
| Ichy |
 Ichy World Chat Champion
| lard44 |
 Posted: 21:15 - 02 Jan 2008 Post subject: |
Cheers for the quick reply!
I can't see naff all out there atm but it's the first thing I'll be checking in the morning - if it hasn't snowed!
Times like these I wish I had a garage...  |
| 01dabreoo |
 01dabreoo Scooby Slapper
 Posted: 23:10 - 02 Jan 2008 Post subject: |
If you take your tank off you should be able to see it easily  |
| lard44 |
| Ichy |
| mattish |
 mattish Spanner Monkey
| lard44 |
| Ichy |
| lard44 |
 Posted: 19:09 - 04 Jan 2008 Post subject: |
Side stand seems fine, need to try the clutch tbh...
I pulled out the carb and saw a nozzle (not the throttle or the oil - those were connected fine) that didn't seem to be connected to anything - is this right?
https://i83.photobucket.com/albums/j310/lard44/DSC00179-1.jpg
Can't get the thing open as the heads on ALL the bolts has been utterly shagged. I've broken too many drill bits trying to get them out but I'll have another crack in the morning I guess.#
Cheers for all the input so far guys - might still crack this... |
| Vincent |
 Vincent Banned
 Posted: 21:27 - 04 Jan 2008 Post subject: |
| lard44 wrote: | Side stand seems fine, need to try the clutch tbh...
Looks like the Powerjet, if so, that's fine. Take the bowl off the botom, (you should be able to leave the powerjet pipe connected), take another pic of the inside and someone can tell you which is the pilot jet. It could be blocked up. Make sure not to damage the floats when taking the bowl off. I take it you're using choke when trying to start it? Have you tried a new spark plug? Just cos it's sparking outside the cylinder doesn't mean it is inside. |
| lard44 |
| The Artist |
 The Artist Super Spammer
 Posted: 23:45 - 06 Jan 2008 Post subject: bike |
Ok, most engines need 3 things.
Fuel, compression and spark. BY doing the fuel in cylinder test, this means you have compression and spark. Therefore the problem is fuel not getting to the cylinder.
Remove carb, remove float bowl from underneath, if you have a compressor, get up to 80-120psi, and blow the s*** out of it! Point air in all the nooks and crannies, especially the main jet up the middle.
Be careful not to blow away any loose bits!!
Then soak in a pot of carb cleaner, not neccesary but if you have some, may aswell.
Reassemble and connect everything up. Make sure float is the right way up and is loose to move. Replace carb, should be good as new  |
| tutton |
 tutton World Chat Champion
| saturdaynight... |
 saturdaynight... Derestricted Danger
| lugoismad |
 lugoismad Nova Slayer
 Posted: 05:26 - 07 Jan 2008 Post subject: |
| saturdaynightbeaver_uk wrote: | | tutton wrote: | Mate the acid test of this is,
Put the carb back on,
Stick the bike in 1st gear
clutch in
Run as fast as u can and drop out the clutch
and give it a little gas not a lot otherwise itll stall, and then smack clutch back in.
erm...isn't this EXACTLY what the starter motor does? (except with less stress on gearbox, etc)
I can only assume you are joking!
Many thanks, |
No, its called bump starting. Its how you start a bike when the battery is dead. Or, like in my case, I have no electric starter on one of my bikes, only a kick starter. If you can't get it to turn over fast enough to start up with the kick starter, you have to bump start it. |
| lard44 |
 Posted: 18:28 - 07 Jan 2008 Post subject: |
I put a new in-line fuel filter in place, soaked and scrubbed the carb yesterday and having let it soak for half a day wiped it off and stuck it back on. STILL nowt.
I haven't tried bump starting it yet, I'll give that a go tonight. At least it's dark quickly so no prat can see me making a tit of myself running round the estate  |
| stirlinggaz |
 stirlinggaz World Chat Champion
| tutton |
| Phil_P |
 Phil_P Trackday Trickster
| lard44 |
| faddius |
 faddius Traffic Copper
| truslack |
 truslack World Chat Champion
| Phil_P |
| tutton |
 Posted: 22:00 - 08 Jan 2008 Post subject: |
haha
soz for the confusion i ment
Battery/starter motor
haha  ____________________ Past: '05 Peugeot XPS '99 Aprillia RS125 '94 FZR600R
Current: '02 ZX636 A1P '51 CCM R30 |
The last post was made 18 years, 289 days ago. Instead of replying here, would creating a new thread be more useful? |
