what to do when you cant unscrew the screws
ghettostan
PostPosted: 15:54 - 03 Jan 2008    Post subject: what to do when you cant unscrew the screws Reply with quote
my bike needs a new set of chain and sprocket, but one problemo
i cant take the case/cover off to get into the front sprocket, becuase the screw have been screwed on pretty tight and i cant seems to unscrew them.
whats the best thing to do?
leave it to a mechanic?
i dont want to keep trying myself because sooner or later the screw will be warned out and will become rounded. Sad
help ! lol
PostPosted: 15:58 - 03 Jan 2008    Post subject: Reply with quote
You need a tool called an impact driver.
If you don't have one of those, a bit and brace is also quite effective (an old fashioned drill brace with a screwdriver bit in the chuck).
Giving them a good soaking in penetrating oil is never a bad plan.
ghettostan
PostPosted: 16:50 - 03 Jan 2008    Post subject: Reply with quote
thanks mate i think my mate said he has one of those, if not i will go and buy one, thanks.
Mudskipper
I've always found a good spray of Loctite freeze n release helps with those real stubborn bastards.
And like stinkwheel says, an impact driver.
skinny
PostPosted: 16:58 - 03 Jan 2008    Post subject: Reply with quote
Also it will help after giving it a good spray to find the right size screw driver and give it a couple of good tap this is normally enough to free up a stubborn bolt.
oops I did it again....
PostPosted: 17:34 - 03 Jan 2008    Post subject: Reply with quote
Oh yeah, and don't put them back in again afterwards. Replace them with some socket head cap-screws (the sort that take an allen key) with a thin smear of copper grease on the threads. They'll waltz out next time you need to remove them.
Putting semi-burred crosshead machine screws back on motorbikes comes second only to joining wires with PVC tape on my list of things which make me want to repeatedly hit someone with a claw hammer.
Walloper
PostPosted: 18:35 - 03 Jan 2008    Post subject: Reply with quote
What about 'Rim Tape'?
PostPosted: 18:51 - 03 Jan 2008    Post subject: Reply with quote
Well, it's tasteless and pointless but it can easily be peeled off or painted over. I wouldn't have it on my bike and I feel free to openly mock people who do as trying to replicate traction engine pinstriping but it doesn't make me angry.
veeeffarr
PostPosted: 18:54 - 03 Jan 2008    Post subject: Reply with quote
Embarassed
ghettostan
PostPosted: 19:12 - 03 Jan 2008    Post subject: Reply with quote
yeah i was thinking of replacing the old screws for those what take allen keys anyways if i ever get them out Shocked .
thanks.
Odie
PostPosted: 19:38 - 03 Jan 2008    Post subject: Reply with quote
If you find that you screw driver bit slips put a bit of valve grinding paste on the tip, it will give you a better grip on the screw head.
PostPosted: 19:46 - 03 Jan 2008    Post subject: Reply with quote
If you find the screwdriver bit slips, put it back in the box and select the one that is the correct size and type for the screw you are tryi8ng to undo.
Importantly, learn the distinction between phillips and posidrive.
https://en.wikipedia.org/wiki/Pozidrive
Odie
PostPosted: 20:05 - 03 Jan 2008    Post subject: Reply with quote
Good point. Thumbs Up
The last post was made 18 years, 227 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 79.31 Kb
