| LanaTheGreat |
 LanaTheGreat Scooby Slapper
| darkangel |
 darkangel Nitrous Nuisance
| LanaTheGreat |
| Ariel Badger |
 Ariel Badger Super Spammer
| Odie |
 Odie World Chat Champion
| LanaTheGreat |
| Finglonga |
 Finglonga World Chat Champion
| LanaTheGreat |
| Ariel Badger |
| Ichy |
 Ichy World Chat Champion
| Vincent |
 Vincent Banned
| LanaTheGreat |
| Vincent |
 Vincent Banned
| LanaTheGreat |
| Paddy Blake |
| LanaTheGreat |
| LanaTheGreat |
 Posted: 01:38 - 03 Jan 2008 Post subject: |
I stripped the engine down to the bone. The oil pump is still fine, no problem there. Run-out on the crank seems fine, nothing notably wrong there.
I am including pics of the only things I found that could possibly cause the engine noise:
Main Bearing.jpg --> Brand new bearing replaced about two months ago. The bearing is spinning inside the crankcase where it is fitted. There is no noticeable play between the bearing outer trace and the crankcase, yet if you turn the crankcase over the bearing simply falls out. Now please, tell me anything that gives me hope, I am NOT going to buy a new crankcase... Besides the main bearing, there are four other bearings also a bit loose in the casing, and they have slight play. That includes the bearing for the balancer shaft. I will replace those as well.
Buffer Boss Crack.jpg --> Yeah, that is what you call that thing, got the name in the parts catalog. Three parts to that thing, the gear teeth outer part, the springs, and the inner part. They can be separated. The arrows point to where the inner part is cracked. The boss goes directly onto the crankshaft and I HAVE to replace that, no doubt. Bloody expensive at about $55.
Sleeve Pitmarks.jpg --> The pit marks I mentioned earlier. Regret no picture of the piston. Excuse the poor quality of the pics, I took them with my cell phone.
Now the question part. Regarding the bearings, I am not buying genuine Yamaha bearings, they are madly priced, I am buying them from the bearing shop in town. Is this a good idea or not? Then, taking into account that the main bearing is still new, do I need to replace that one too, if so, is it possible to get one just a wee bit bigger that will fit snugly into the casing? Will it be possible to get slightly larger bearings for the other four having the same problem?
Then the sleeve pit marks. Will simply honing the cylinder be enough to fix this problem? And what caused this damage to the cylinder wall?
Something worth mentioning too, i found some metal grain at the strainer and the oil filter, not a lot, but it worries me, as I cannot really determine where it came off. Not sure if it is aluminum from the crankcase or other metal from the other parts. I inspected every little spring, screw, gear etc coming out from the engine.
Sorry for this mouthful. Given all that I wrote above, what is your professional advice, as I am getting fed up opening this engine every few months. |
| Phil_P |
 Phil_P Trackday Trickster
| Ariel Badger |
| LanaTheGreat |
 Posted: 16:59 - 03 Jan 2008 Post subject: |
Thanks for the replies.
The guy at the bearing shop also mentioned punching the casting to make the bearing fit, but never mentioned loctite bearing fit, surely he should have heard of it before. The bearings I got for replacement are NSK's. I was wondering if the slipping bearing could be the cause of oil leaks from the magneto end, as the oil seal is brand new, and oil keeps leaking from it. As mentioned before, the bearing is slipping, but there is no play as it still fits snugly into its housing.
The scuff marks are not too deep, you can see it, and lightly feel it when running your fingers over. They are not alloy deposits, but grooves. I am going to hone it anyway, I am not replacing anything there as yet.
The new bearing is the exactly the same size as the original. Oddly the bearing on the other side fits snugly, and does not rotate in the casing as the one in question. I see all the bearings are made in Japan - NSK, SKF, Yamaha, and the smaller bearings that are in the engine are branded Koyo.
I am trying to get a secondhand part for the buffer boss. Hopefully I can find one in some bike scrapyard. |
The last post was made 18 years, 225 days ago. Instead of replying here, would creating a new thread be more useful? |
