Brake light and front brakes.
fatsamurai
PostPosted: 13:18 - 10 Jan 2008    Post subject: Brake light and front brakes. Reply with quote
Hi everyone,
My brake light isn't lighting up when I use the front brake, only the back one.
Someone told me that it'll be the front brake switch which is most likely at fault. What is it, where is it, and what should I do to it?
I there anything else that could be causing these symptoms?
PS: It's a 2004 Hyosung Comet.
Cheers!
fra-zzr
PostPosted: 13:23 - 10 Jan 2008    Post subject: Reply with quote
on an '04 comet aswell but cant help you on the brake light issue, get over to korider.com theres a huge amount of support there. hope you find the problem Thumbs Up
fatsamurai
PostPosted: 14:55 - 10 Jan 2008    Post subject: Reply with quote
Thanks Frasier.
I've tried to register at korider but no luck so far. The registration activation emails don't seem to be arriving (tried two email addresses).
fra-zzr
PostPosted: 16:26 - 10 Jan 2008    Post subject: Reply with quote
could be a spam filter moving them around, i had a similar problem.
If you dont sort the light out you can always buy a new one and give the old one to me, broke my lens then other day Evil or Very Mad
PostPosted: 16:36 - 10 Jan 2008    Post subject: Re: Brake light and front brakes. Reply with quote
fatsamurai wrote:
Hi everyone,
Cheers!
Don't know that specific bike but it will be the front brake switch that is knackered which is either a microswitch that works as you pull the front brake lever or a pressure switch that operates on brake fluid pressure as you operate the brake.
Triumph Trophy Launch Edition
fatsamurai
PostPosted: 17:34 - 10 Jan 2008    Post subject: Reply with quote
Well, as I pull the front brake slightly I can hear the clicking of a switch. I'll have a dig around tomorow and see what I can see.
PostPosted: 17:58 - 10 Jan 2008    Post subject: Reply with quote
fatsamurai wrote:
Well, as I pull the front break slightly I can hear the clicking of a switch. I'll have a dig around tomorow and see what I can see.
That sounds like the microswitch version then. I've just changed the one on my Wing, cost me £17. I expect yours will be a lot cheaper Laughing
Rowey
PostPosted: 19:51 - 10 Jan 2008    Post subject: Reply with quote
Got the same problem on my super dream, good news being, becuase it's old, it dosn't legally have to have one on the front brake.
Mines under the r/h switch gear, its a little barrel shaped thing that works through the hydrolics pressure. Bought one from david silvers for £7, but they sent me the wrong one (a newer micro switch type one) so still waiting to fix it.
ZX6R C6F.
fatsamurai
PostPosted: 13:52 - 11 Jan 2008    Post subject: Fixed. Reply with quote
I got the switch off, lathered everything in WD40 and cleaned the connectors down.
All is now working Thumbs Up
Cheers for that link Frasier. I joined up and they were really helpful. Got myself some nice service manuals now.
timjim
PostPosted: 17:04 - 12 Jan 2008    Post subject: brake light Reply with quote
it sounds like the front brake light switch is either coroded or broken internally..follow the front brake lever towards the pivot edge and youll 9/10 times find it as a small micro switch held in with a tiny screw,pull the two wires off the switch and connect the two wires together with a split pin or a small length of electrical wire,if the light works,then that will point towards the switch.Try also spraying WD40 or a spray penetrating oil into the switch and allow to soak in,keep applying the switch as they suffer with water ingress and corode.I hope this is of use.
ps a replacement switch is about a fiver and 30 seconds to fit.
The last post was made 18 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 65.13 Kb
