| Thom |
 Thom World Chat Champion
| finpos |
 finpos World Chat Champion
| Thom |
| finpos |
 Posted: 00:00 - 12 Jan 2008 Post subject: |
Yep, sounds exactly like a guffed plug.
First rule of two stroke - if it randomly stops starting, stick a new plug in it
If you don't want to do that, get the plug absolutely as hot as you can in a gas flame. You want to burn all that oil/petrol/carbon off it. Put it back in while it's still hot (ouch), the engine will probably start.
f. |
| TUG |
 TUG World Chat Champion
| Thom |
 Posted: 01:37 - 12 Jan 2008 Post subject: |
well luckily i bought two plugs so i'll try the second tomorrow, lets hope that sets it all off for me  |
| Thom |
| finpos |
 Posted: 13:42 - 12 Jan 2008 Post subject: |
Just because you have charged the battery unfortunately doesn't mean it's any good I doubt you have the kit to test the battery under load, which is what matters in this case. If the starter is labouring, the battery will be the prime suspect. Also realise when the starter is labouring because the battery can't supply enough current, it tends to suck all the power from the ignition so the spark plug isn't firing either.
Easiest thing to do is get jump leads and a car battery, see if that spins the engine quicker. If it does, your battery is borked.
If you can't do that, try the starter with the plug out - with no compression it should whizz around quite smartly. Again, if it slows down a lot when you put the plug back in suspect the battery.
f. |
| Thom |
| finpos |
| Thom |
 Posted: 16:58 - 12 Jan 2008 Post subject: |
I've thrashed the bike tonight!
The problem seemed to be the starter flywheel, i covered in in 3 in 1 and it gradually span faster and faster, seems it was stiff!
Now the bikes a dream, not a rattle coming from it
thanks for all the help guys! |
The last post was made 18 years, 12 days ago. Instead of replying here, would creating a new thread be more useful? |
