Hi I Need Help By Tommorow.
Jack2004
PostPosted: 23:24 - 02 Jan 2004    Post subject: Hi I Need Help By Tommorow. Reply with quote
I have a Suzuki ae50 style with a problem. The petrol doesn't flow through properly. It goes into the fuel pump but doesn't come out the other end. It has a vent tube i wondered if it could be that? I know it's not the fuel pump as it is brand new. If i blow into the fuel tank though it will put some petrol into the engine and run for about 3 minutes. Any ideas anybody??????
P_J
PostPosted: 23:26 - 02 Jan 2004    Post subject: Re: [b]Hi I Need Help By Tommorow.[/b] Reply with quote
Do you mean free flowing or whilst its hooked up and working?
Electrical problem? erm ... I am sure someone on here will know mate.
PJ
Dreams will get you nowhere, a good kick up the arse will take you a long way.
Only1PJ.co.uk
Jack2004
PostPosted: 23:29 - 02 Jan 2004    Post subject: Reply with quote
When i get the bike running after blowing into the petrol tank to put some petrol into the engine it will run but then cut out because there is no petrol going through the pump, i've checked because while it was running i disconected the fuel out pipe and there was no fuel coming out at all.
Robby
Dirty Old Man
PostPosted: 23:31 - 02 Jan 2004    Post subject: Reply with quote
Well your petrol pump clearly isn't doing its job. Check all the electrical connections, if they are ok i'd assume its broken. See if you can find any way of testing it with a multimeter online.
Jack2004
PostPosted: 23:56 - 02 Jan 2004    Post subject: Reply with quote
Do you think it could be any problem with the vent?
PostPosted: 00:38 - 03 Jan 2004    Post subject: Reply with quote
Does the bike run with the fuel cap off (don't try riding it like this)? If so the chances are that the vent to the tank is blocked.
Is it an electric pump?
One possibility is that it is a vacuum pump. As such it will need a pipe from it to the crankcases to provide a pulsing vacuum. If the pipe is blocked then nothing gets through to the pump. These pumps are not common, but sometimes they are fitted (gits at Yamaha fitted one for the early Diversion, fortunatly they discovered the guy who did it, strung him up and replaced it with an electric pump for the later bikes).
PostPosted: 00:40 - 03 Jan 2004    Post subject: Reply with quote
You could try getting an airline (from air compressor) and blowing out all the appropriate holes.
Not sure about what the 'vent' does.
If you've got some spare hose you could try running it without the pump, presuming it's an electric one, I can't see it needing it /that/ much for a 50.
The last post was made 22 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 51.76 Kb
