IP address'
P_J
PostPosted: 17:17 - 04 Jan 2004    Post subject: IP address' Reply with quote
I fell into the fights and flame wars page and read a few posts allegedly written by the w@nker formerly known as TGE*mumble something or other*.
If you (admin/korn/otherwise) ban's an IP address, surely the offender just has to reconnect to the internet to get a different IP?
I have broadband which is never turned off at the wall, so even if I turn off or re-boot my PC it keeps the same IP address. If we had a power cut or I turned the cable modem off, then it re-assigns a new IP.
Doesn't it?
Im confused.
PJ
Dreams will get you nowhere, a good kick up the arse will take you a long way.
Only1PJ.co.uk
PostPosted: 17:23 - 04 Jan 2004    Post subject: Reply with quote
Dialup internet connection users are assigned a new IP each time they connect. However it is possible to ban an entire ISP or IP range if needed (each ISP has a different range of IP address to asign to people as they connect)
Your broadband might have a static IP, so even when you re-connect you'll have the same IP. However you normally have to specify this when you join with your ISP and sometimes pay extra for it. There aren't any real advantages for a home user in having it.
Most broadband connections get a new IP each time you connect Smile
Hope that makes some sort of sense Smile
PostPosted: 20:45 - 04 Jan 2004    Post subject: Reply with quote
Ste,
I haven't payed any extra for a static IP but my IP is the same each time I reconnect. I assume that this is because the DHCP server at my local server has only a few IP addresses that it can allocate in my area and either
A) all of the others are connected (unlikely)
B) it allocates them in mumerical order and I am the only one connected to my local node (likely - everyone else near here has BT.)
So it could just be luck that I have the same IP address. Might that be a likely reason why P_J is experiencing the same thing?
Smile
PostPosted: 20:47 - 04 Jan 2004    Post subject: Reply with quote
I find ntl IP addresses are static for a few months, but do change.
So you can't be 100% sure on such things.
PostPosted: 20:48 - 04 Jan 2004    Post subject: Reply with quote
Ste,
Smile
Or your ISP just works with static IP's Razz
PostPosted: 20:49 - 04 Jan 2004    Post subject: Reply with quote
Ste,
Smile
What G said.
It says in the NTL literature that it uses DHCP, I'm sure of it. Smile
Milo
PostPosted: 15:49 - 05 Jan 2004    Post subject: Reply with quote
I've not read the above, cos i'm lazy like that, but you only get a static IP if you pay your ISP for one (even though it's a simple case of ticking a box for them!)
I'm on virgin.net adsl and do get a different IP each time i connect-but i've got a broadband router which keeps the connection alive.
My IP does stay the same as i never disconnect, even when no computers require the connection.
This is a much simpler way of networking multiple PC's and sharing the internet.
You can also pay some ISP's for up to 4 static IP's.
This way you can use NAT (Network Address Translation) and give each PC on the network an internet IP address - as if each computer had their own modem.
Hope this helps
Shaft drives rule. Razz
PostPosted: 16:23 - 05 Jan 2004    Post subject: Reply with quote
Actually, they don't all use a static IP, as for each IP they purchase it costs them money, so they'd have to buy more if they give everyone one. Not everyone is connected to thier internet connection 24 hours a day (I havn't figured out how to do this yet Sad Razz ) so they don't have to buy as many IP's as they have customers.
Thats the connection ratio, which for ADSL is about 20:1 or 50:1 for most home connections meaning they've got 50 customers for each IP.
Bendy
Mrs Sensible
PostPosted: 16:45 - 05 Jan 2004    Post subject: Reply with quote
There's also the issue that the world is running out of IP addresses, hence the move to IPv6. Once that gets going people will probably be throwing static IPs at you. Your computer will have one, your printer, your fridge...
McJamweasel
BCF Junkie
PostPosted: 16:55 - 05 Jan 2004    Post subject: Reply with quote
Are you sure you're not thinking about the contention ratio, which is how many people are sharing your connection to server? (Hence the higher the ration the more likely you are to find your bandwisth reduced at busy times)
carvell
Scuttler
PostPosted: 16:59 - 05 Jan 2004    Post subject: Reply with quote
Nope. Each customer connected to the service has their own IP, you cannot share IP address, no matter what the contention ratio is.
Each customer connected to their service will be in the the same IP range however, for example everybody connected to Pipex may have 81.86.xxx.xxx for an IP.
Yamaha TDM 850
PostPosted: 17:02 - 05 Jan 2004    Post subject: Reply with quote
No customer can share IP addresses at the same time, but the DHCP server can hot swap between people who are connedted and people who are not. Smile
Syfoon
TRUCK!!!
PostPosted: 19:13 - 05 Jan 2004    Post subject: Reply with quote
Ponder.
If you connect via a router, wouldn't that hold the IP for you, as you'd be connected (as long as its powered)?
I know then you have to deal with network IPs and all that then, but if I wanted a static IP jobby, wouldn't a DSL router do it?
Not here...
PostPosted: 19:36 - 05 Jan 2004    Post subject: Reply with quote
Most routers will disconnect after a set amount of time of inactivity. There's a setting on mine to change that Smile
Milo
PostPosted: 22:00 - 05 Jan 2004    Post subject: Reply with quote
*cough*
Plus it's very satisfying to tell your computer that you connect via a lan-and being able to fire up anything without having to bother with connections.
I also get a total connection time and amount of data downloaded Very Happy
Syfoon
TRUCK!!!
PostPosted: 22:08 - 05 Jan 2004    Post subject: Reply with quote
I can cough too, you know Razz.
Not here...
Milo
PostPosted: 22:11 - 05 Jan 2004    Post subject: Reply with quote
I've now got more time to read it as i'm not busy at work with the boss able to see my screen.
Me saying I'm lazy just means I'm too lazy to say why i didn't read it Razz
Or that's my excuse anyway... Rolling Eyes
Smoto Bob
PostPosted: 22:41 - 07 Jan 2004    Post subject: broadband Reply with quote
NTl do use DHCP but if you run the little program called New IP on the cd they give ya you can get the server to re-assign you a new one ( usefully if you have errr been doing silly illegal things) but generally you will keep the same ip for a while like G said as temp address.
F'it DO WHAT EVER MAKES YOU HAPPY!!!!! Even if it screws over everyone else :p
Titz wrote: "..and my 3rd accident was when this police car....."
The last post was made 22 years, 295 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 108.35 Kb
