Home Server
P_J
PostPosted: 12:21 - 05 Jan 2004    Post subject: Home Server Reply with quote
I am building my own PC at the moment and have realised that I have a shed load of parts left from past machines too.
All that is missing from one of them is a hard drive, which I now have, and memory, which I can take from or share with, my current PC (as I have 2 DIMM's in at the moment).
I was wondering exactly what I would need to build my own server in order to run a web site from my home PC, or to store files on it to access over the internet etc.
Im going to google for a bit now but any thoughts or past experience would be appreciated.
PJ
Dreams will get you nowhere, a good kick up the arse will take you a long way.
Only1PJ.co.uk
R1stu
Shrek!
PostPosted: 12:39 - 05 Jan 2004    Post subject: Reply with quote
I also run my own server mate, and its great fun. All that you need is a few little programs installed to make it all work.
1) ServU FTP Server
2) DNS4me/NO IP.com (for getting a site to your IP)
3) IIS/Apache (web server IIS is part of windows)
With these bits of software you can have your own FTP server and a web server. However I am having problems with the web server side of things at the mo, where as my Intranet is fine, but the outside world cannot access the pages.
You can get a 30 day trial of DNS4me from Rhinosoft.com after that its only $20 per year for the service, which is very good and I will be subscribing.
This service changes the server address to the new IP every time it changes, as unlike mine most peoples IP are Dynamic. (Meaning they change every connection) No IP is a free service, however you need to update the IP address manually each time it changes via their website.
I hope this helps, if you need and more info let me know ok?
Regards
Stuart
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
P_J
PostPosted: 12:53 - 05 Jan 2004    Post subject: Reply with quote
What is this "Apache" you speak of?
I cant see if IIS is installed on my PC or not, where could I get IIS (if in fact you can get it separately to a windows installation) or Apache download.
Is Apache free?
PJ
Only1PJ.co.uk
PostPosted: 13:03 - 05 Jan 2004    Post subject: Reply with quote
Apache is a web server program, and its better (so I hear) than IIS. I have apache running on my laptop and it is very good. I believe (not 100% sure) that it is free.
Hope that helps. Smile
R1stu
Shrek!
PostPosted: 13:05 - 05 Jan 2004    Post subject: Reply with quote
You can get Apache from https://httpd.apache.org/download.cgi?Preferred=http%3A%2F%2Fapache.mirror.positive-internet.com
and its FREE! IIS is part of windows.
If you goto add/remove programs in the control panel, and then windows system components, then you can install it from there!
P_J
PostPosted: 14:10 - 05 Jan 2004    Post subject: Reply with quote
I have downloaded Apache (and have no idea what it does or how to work it still) but I am now after a domain name.
I did a bit of searching through previous posts and have a list of places to look for and buy domain names but I am not sure exactly what I need.
https://uk2.net/ where Syfoon got his .co.uk account seem to be the cheapest but they offer extra services like:
* WebDiversion with UK2NET Header
* Website 50mb
* WebDiversion without UK2NET header
* CGI / PHP (Requires website)
* MySQL database (Requires CGI)
* 500 extra forwarding addresses
* Spam filtering
* DNS Management
If I am going to be running this site from my PC (2nd PC when I get the new one built) I will not need the web space, but if I use some of the programs mentioned earlier, will I need DNS management, CGI/PHP etc?
PJ
Only1PJ.co.uk
PostPosted: 14:13 - 05 Jan 2004    Post subject: Reply with quote
Any PC connected to the Internet can be run as a webserver. However, there is little point in doing this for most people other than as a quick and easy way of developing websites and being able to test them.
Apache is the industry standard in web server's.
Unless your site is using lots of the computer processor power there is no need for a seperate machine to be running as webserver.
Remember to also setup a good firewall correctly as you are allowing people onto your PC.
My Penny Coin Penny Coin would be to install it, learn it, play about with it etc but just use it internally.
PostPosted: 14:16 - 05 Jan 2004    Post subject: Reply with quote
* Website 50mb
* Spam filtering
* DNS Management
PJ
If you're buying the domain then you'll be wanting to have it point to your IP. What internet connection are you?
CGI and PHP are scripting languages which you can install onto your server. DNS Management is simply making that domain point to your PC. I found a good free service offering this, I'll look the URL up when I get home.
www.ukreg.com are also good for buying domains from.
PostPosted: 14:20 - 05 Jan 2004    Post subject: Reply with quote
If you have to ask what Apache is then it's probably not for you.
It's moderately complex to setup, compared to IIS anyway.
However if you intend to use IIS you need to be sure that you install every security update as and when they become available.
IIS does FTP as well, but as above, you need to be sure that it's kept up to date and this still doesn't guarentee it will be 100% safe.
There are some dynamic dns places that do it for free.
I can reccomend www.ukreg.com for domain names, however unless you particularly want your own name, most of the dynamic dns places will give you a free subdomain... ie yoursite.dynamicdns.com style.
P_J
PostPosted: 14:23 - 05 Jan 2004    Post subject: Reply with quote
I have NTLworld Broadband - 600k.
If I bought a domain name, who 'points' it to my IP address. Is it something I will be asked to set up when I have bought it? I would have thought so, but maybe wrong.
CGI and PHP, these will install onto my PC wont they? Therefore no need to pay extra to UK2.net?
DNS management, im still not sure about, is this going back to the
comment?
PJ
Only1PJ.co.uk
PostPosted: 14:28 - 05 Jan 2004    Post subject: Reply with quote
Should cope with light traffic. What are you planning on hosting?
Right. When you buy a domain you then have to specify the name servers you're using. These will need to have the information about your domain stored on them so it knows where to then "direct" the traffic. As I said, you can get several free services which will host your domain and direct it on to your IP.
CGI and PHP will not be provided by the domain registering service. They are a feature of the webhosting server. You will not need to pay anyone for using them if you are using your own server.
comment?
PJ
Comment? Confused
As G said, if you're needing to ask all this, it might be a better idea to stick to paid hosting accounts until you're more familiar with it all.
P_J
PostPosted: 14:48 - 05 Jan 2004    Post subject: Reply with quote
Basic web page, files, images, basically personal stuff that not many people will want to look at but its just a project so I would not have thought the speed of the connection will be much of an issue. Well, hopefully anyway.
Still do not fully understand but I will not ask anymore from you, I will look it up myself. Smile But this is the DNS management side to it, right? Please say yes.
Webhosting server being Apache(if I work it out) or IIS?
I know, but I like getting myself confused Rolling Eyes Laughing
Only1PJ.co.uk
Bendy
Mrs Sensible
PostPosted: 14:52 - 05 Jan 2004    Post subject: Reply with quote
Unless you have a fixed IP, you can't just buy a domain and point it at your home computer. You'll need one of the dynamic IP things people have been talking about.
I'd sort that out and if everything else works fine, buy your domain as the last step.
P_J
PostPosted: 15:01 - 05 Jan 2004    Post subject: Reply with quote
As far as I can tell, No-IP.com do the job... dont they? Confused
Registered with them and then intend to buy domain name.
PJ
Only1PJ.co.uk
PostPosted: 15:04 - 05 Jan 2004    Post subject: Reply with quote
It will do the job. You don't need to buy a domain name unless you're going to use thier plus service which isn't worth it as you can get it for free.
I'd start of just getting apache to work, then getting it to work with an IP address, and then think about getting a domain as that is the only bit which is actually going to cost any money Smile
R1stu
Shrek!
PostPosted: 17:36 - 05 Jan 2004    Post subject: Reply with quote
Im using dns4me, like I said, its only $20 for a years use or $30 for 2yrs!! and my address is vengence.servu4me.com.
You can then get a web address forwarding system to the address you choose!! Thats how I am doing it!
Bendy
Mrs Sensible
PostPosted: 17:39 - 05 Jan 2004    Post subject: Reply with quote
I think you'd agree that he should get it up and running on free trial first though.
P_J
PostPosted: 17:41 - 05 Jan 2004    Post subject: Reply with quote
So, if I used https://www.dyndns.org/, for free, and then arranged some free URL redirection to my www.only1pj.co.uk address, that would work right?
PJ
Only1PJ.co.uk
P_J
PostPosted: 17:47 - 05 Jan 2004    Post subject: Reply with quote
dynDNS provide this dynamic DNS service for free.
Where as
Sytlutions offer redirection also, for free.
Confused
Only1PJ.co.uk
Bendy
Mrs Sensible
PostPosted: 17:57 - 05 Jan 2004    Post subject: Reply with quote
You want https://www.no-ip.com/services/page/free/dynamic/dns or similar. It doesn't matter which, they all do the same thing.
Then, yes, you could get your domain name forwarded to that if you so desired.
I think I used dns2go when I did this, they were fine and would redirect users to another page when your machine was offline.
Dr Nick
PostPosted: 18:11 - 05 Jan 2004    Post subject: Reply with quote
For when i needed to convert my forum to phpBB, i needed to run the converter locally. I found a piece of software called phpTriad which has apache, php, perl, mySQL etc bundled with it.
I think its the tits, but ive only used to to convert my forum.
Heres the link
https://sourceforge.net/projects/phptriad
is that it
P_J
PostPosted: 18:32 - 05 Jan 2004    Post subject: Reply with quote
Right, this is annoying me now.
To have people 'access' my website/server/files etc, by typing in the domain name I bought earlier today, Only1PJ.co.uk, I can not use one of these third party companies can I.
They all make you use there long company name url's. Don't they?
PJ
Only1PJ.co.uk
Bendy
Mrs Sensible
PostPosted: 18:51 - 05 Jan 2004    Post subject: Reply with quote
Where did you buy your domain name from?
Most places, for a fee, will let you 'forward' the url on to somewhere else. That somewhere else would be the dynamic ip redirecting address that you get and point at your actual machine.
So you point PJ'sdomin.com at PJsdorkyIPthing which points at 81.23.45.67 or whatever your machine is that day.
If the company you bought it from will NOT do this, me & G will host your domain name for a small donation and can do the forwarding.
P_J
PostPosted: 19:31 - 05 Jan 2004    Post subject: Reply with quote
Got the name from UKreg.com, same place as ste got his isn't it?
Have you and G got a site to have a look at, Bendy?
Only1PJ.co.uk
Bendy
Mrs Sensible
PostPosted: 19:37 - 05 Jan 2004    Post subject: Reply with quote
Like we're that organised Rolling Eyes Razz
Apparently UKreg will forward, so you won't need us. Well, not until you muller your connection and realise buying some webspace would have been easier from the start...
The last post was made 22 years, 299 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 143.38 Kb
