majour sv problems with starting :help needed please:
kenny
PostPosted: 19:27 - 22 Jan 2008    Post subject: majour sv problems with starting :help needed please: Reply with quote
hi i am having some seroius trouble with my 2001 sv650s this morning i came to the bike and it wouldnt start it just kept clicking very fastley when i pusehed the start button i have just had it in for a 20k mile service had the rollers done and a new battery fitted it was doing this before i had the service done but its still doing it could it be the battery at fault here as the bike was running sound till this morning when i tried to start it. the battery i got was a nano gel filled one. could it just be a faulty new battery or could it be something more.im really stuck now for transport so i need to get the problem sorted quite quickly can aany one shed any light on the matter if at all possible please. i leave the bike outside over night would that stop it working as i have stored the rest of my bikes there before in the past and had no trouble from them.
thanks
KeNNy 100cc peugot speedfight 125cc Honda NSR125R 650cc suzuki SV650R 125cc suzuki GZ125 600cc yamaha YZF-R6
James
PostPosted: 20:15 - 22 Jan 2008    Post subject: Reply with quote
Sounds like the battery is flat they usually click when insufficient current to spin the starter. Get a trickle charger on it for a couple of hours and it should start straight up
Like shit off a stick
garyd
PostPosted: 20:32 - 22 Jan 2008    Post subject: Reply with quote
As that is a new battery its fair to assume that the charging system needs testing Thumbs Up
CRF230 all you need
Itchy
PostPosted: 20:36 - 22 Jan 2008    Post subject: Reply with quote
learn to bump start it, SVs are tricky in that you need to hold on the clutch while starting it though.
Usual thing , multimeter across the terminals should be a bit above 12volts,
bad recs ruin batteries ,
kenny
PostPosted: 12:43 - 23 Jan 2008    Post subject: Reply with quote
when the bike when in for service i got them to check to altenator and the said the charging cucuit was fine and kicking out enough
i have had the battery on trickle charge before as its about 3 weeks old now and every time it gets cold it seems to just loose all its power and then will not start again till it charged back up.
Trixie
PostPosted: 13:41 - 23 Jan 2008    Post subject: Reply with quote
You may possibly have a duff battery - even if it is new. Why was the other battery replaced?
If the mechanic replced it, maybe you can have a word and try another battery in the bike for a few weeks and see if you get the same problems or not.
Dead nobodies in company cars...
kenny
PostPosted: 18:15 - 23 Jan 2008    Post subject: Reply with quote
i replaced the old battery as it was on its last legs and as old as the bike 5-6 years thats why i think the new one is duff as well it has the same symtoms i.e draining all the power out of it when its cold over night.
Cigaro
PostPosted: 18:18 - 23 Jan 2008    Post subject: Reply with quote
Are you sure you don't have a short circuit or something drawing power out of your battery?
WHILE THE BIKE IS TURNED OFF, connect an ammeter in between the battery positive lead and the terminal. (Make sure you connect it in series with the battery, not parallel, or there will be smoke and flames.) See what reading you get.
kenny
PostPosted: 18:51 - 23 Jan 2008    Post subject: Reply with quote
i got the mechanic to have a look at my wiring and he says he fixed a fault on the starter motor wiring what i dont know. but its wierd i picked the bike up on the a wednesday the bike worked fine and started fine but the next sunday night the battery must have drained as i tried it monday morning it was dead as a fart.
Biker100
PostPosted: 21:37 - 23 Jan 2008    Post subject: Reply with quote
been having similar problems on my sv, just learn to bump it. i'm only 8.5stone and can bump it easy enough, the problem with mine was the regulator/rectifyer cost me £60 from main dealer.
PostPosted: 09:20 - 24 Jan 2008    Post subject: Reply with quote
I got one for £20 on ebay - I avoid 'main dealers' wherever possible.
kenny
PostPosted: 13:16 - 25 Jan 2008    Post subject: Reply with quote
i've got the battery on the dianostics machine at work as its a 10a battery and its taken 4 hours to put only 600ma into it so far i prop wot know the out come till round about monday tuesday as to the condition of the battery voltage and ampage wise.
The last post was made 18 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 74.66 Kb
