Battery smells like rotten eggs?
mattish
PostPosted: 12:20 - 23 Jan 2008    Post subject: Reply with quote
Usually smells like that when its boiling the acid, same smell I had when the reg/rec went on my fzr6 and I boiled the battery dry on the way home Embarassed
Finglonga
PostPosted: 12:34 - 23 Jan 2008    Post subject: Reply with quote
The eggy/sulphur smell is hydrogen given off by the battery when charging. By boiling it dry the plates are probably shorting out and you will have dead cells now.
Unless you have been VERY lucky its time for a new battery.
powelly wrote:
Now wont be trying that again but is the battery just shot (its been stood for 6 weeks) has the optimate fecked it? or is it something to do with the bike?
Is there still electrolyte in the battery? Is that voltage with the engine off? If so what does it go to with it running? Don't let it run long at all if its high as it may cause you problems.
Andy Sez....
F.Y.Y.F.F.
Finglonga
PostPosted: 12:54 - 23 Jan 2008    Post subject: Reply with quote
Wow time travel. Mr. Green
Andy Sez....
F.Y.Y.F.F.
powelly
PostPosted: 12:57 - 23 Jan 2008    Post subject: Battery smells like rotten eggs? Reply with quote
Ok I think my battery is shot.
I tried to start the bike yesterday and the battery was flat, stuck it on the optimate over night and everything looked fine so I hooked it up and tried to turn it over again.
Bike tries to start, then I hear the solenoid ticking then a little smoke comes off the battery and I can smell sulphor.
UPDATED:
Multimeter says I'm getting 12.71 volts out of the battery
Yamaha RXS 100 > Gilera Runner 50 > Suzuki SV650SY
powelly
PostPosted: 13:01 - 23 Jan 2008    Post subject: Reply with quote
can i post yet?
woohoo im back from the future!
The bike wont start, so I cant measure the voltage when its running, and I havent opened the battery as I don't know what I'm doing Smile
NSR Mick
PostPosted: 13:03 - 23 Jan 2008    Post subject: Reply with quote
Batteries can smell a bit when you charge them even if they are ok. Although yours does soung goosed if it still wont start after charging.
Finglonga
PostPosted: 13:23 - 23 Jan 2008    Post subject: Reply with quote
What time is it now? My flux capacitor is fubared! Mr. Green
*edit* The space time continuum is back to normal. Thumbs Up
Andy Sez....
F.Y.Y.F.F.
Walloper
PostPosted: 13:59 - 23 Jan 2008    Post subject: Reply with quote
What you smell is sulfor Shocked (Sulphur) Just because they use sulphuric acid and water as an electrolyte. Laughing Which has sulfur in it.
It should smell like eggs.
If it gets hot it means the regulator is not doing its job of regulating charge. It should cut the charge from the generator when the voltage gets to a set max.
If you charge to max (Volt meter should read 13v) then you only get one or two starts from the battery then it is fcuked. Buy a new battery.
BUT ENSURE THAT THE REGULATOR IS GOOD BEFORE FITTING A NEW BATTERY OR YOU WILL HAVE THE SAME PROBLEM BEFORE LAST YEAR.
Please refrain from posting in the future too. Confused Very few of us @bcf can deal with the issues raised in a time-slip.
garyd
PostPosted: 19:30 - 23 Jan 2008    Post subject: Reply with quote
As Walloper said ,but.......if it smeels of bacon its charging at more than 13.8 volts ,smell of chicken? below 11.5 volts,anywhere in between can smell of eggs or cheese flan ,in fact anything that has eggs in the recipe,cabbage smell and is fecked wont hold a charge and volts will be just enough to run a torch Wink
CRF230 all you need
Timmeh
PostPosted: 20:28 - 23 Jan 2008    Post subject: Reply with quote
you're funny. Thumbs Up
PostPosted: 01:16 - 24 Jan 2008    Post subject: Reply with quote
You should still be able to bump start.
I had the exact same problem on my curvy SV road bike.
Reg rec was gone - new one sorted it (having two more SVs sitting in the garage helped, but I eventually got a replacement on ebay for £20).
The last post was made 18 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 4.58 - MySQL Queries: 13 - Page Size: 68.96 Kb
