lowering cbr 600
Roco1970
PostPosted: 21:30 - 13 Dec 2007    Post subject: lowering cbr 600 Reply with quote
just wondering what options are available to lower the back of the bike 1" as my mate cant put his heels down and he doesnt feel comfortable in not doing so.
He had the seat lowered and suspension is set to soft.
Bikes CBR 125, ZZR 600, ZX636 current ZZR 1400
Sparks!
Sir Tart-a-lot
PostPosted: 21:54 - 13 Dec 2007    Post subject: Reply with quote
You can get lowering kits on ebay, search for them, they basically change the angle of the rear shock which lowers the back end.. if that makes sense.. easy enough to fit as well.
Roco1970
PostPosted: 21:56 - 13 Dec 2007    Post subject: Reply with quote
cheers sparks i found this,
https://www.motorcycle-road-and-race.co.uk/catalog/product_info.php?cPath=645&products_id=403000
acwman
PostPosted: 21:58 - 13 Dec 2007    Post subject: Reply with quote
Having lowering your seat and softening the suspension..and you still want it lower?? Wow...How tall is your mate!??? Shocked
Think that you can drop the front forks through the yokes, and you should be able to get a lowering kit to lower the back end...though they are not cheap though.
Playing around with the suspension settings could drastically ruin the handling of the bike, and hear it's not the best thing to do to just to get the bike lower.
BMW R1200GS & Honda Fireblade 929RR
Bikes owned -Yamaha R1+akrapovic, Ducati 749S, Power Commander + Termi's,Buell XB12R - with race kit, GSXR600-K4 Titanium Scorpion end Can, ZXR400, RS125, Cagiva Mito, RS50, RG125, ER50, FS1E. https://www.bikepics.com/members/acwman/
MaybeGuy
PostPosted: 00:31 - 14 Dec 2007    Post subject: Reply with quote
tell him to put on weight.
Noxious89123
PostPosted: 14:08 - 23 Jan 2008    Post subject: Reply with quote
Sorry to revive an old thread, but seems totally pointless to start a new one...
Just passed my A2 test today, and i'm looking to get a CBR600F. Smile
I went and sat on one yesterday night, and whilst i had the balls of both feet on the floor, i feel like a brisk wind would have me over. I'm a particularly strong or muscular guy, and i just didn't feel as if i could save it if i tryed to go over.
What are my options for making it lower, and what are the pros and cons of each?
I understand that with different suspension linkages tha back end can be lowered. An inch would be plenty i reckon. Would this mess with the handling of the bike?
I'd have thought that lowering it slightly would give better results than just messing with the preload. (Because that would make the suspension far too soft, all the time surely?)
Would it be better to drop the rar by 1/2" and droped th forks through the yokes by 1/2", to keep the "geometry" of the bike?
New linkages are gonna cost some £££, but dropping the forks is something that could be done by myself, right? (or by a mechanically minded friend Smile )
Itchy
PostPosted: 14:11 - 23 Jan 2008    Post subject: Reply with quote
use my technique, when you stop , slide off slightly to flat foot one of your feet, (for the CBR600).
its more technique that strength, keep it in gear and in 1st holding the clutch in so that IF you do feel it going over you can save it as the torque should stand it up.
Bendy
Mrs Sensible
PostPosted: 14:13 - 23 Jan 2008    Post subject: Reply with quote
Ignore it for a month, you'll get used to if. If you haven't, then look at hacking the seat down a bit.
PostPosted: 14:26 - 23 Jan 2008    Post subject: Reply with quote
The lesson isn't to stop it going over, it is keeping the bike in a position so you don't have to stop it going over. Frankly once on its way down there are few people with the strength to stop it hitting the ground.
Balls of both feet is far more than many people can manage.
Yes, both will affect the handling. softening the rear shock more so.
That would be better, but half an inch is a tiny amount (and you would make that up from cutting the seat down a bit).
Linkages are pretty cheap, although if you lower the bike you will also likely need to shorten the side stand. Dropping the forks is easier, just make sure that the wheel won't touch anything when braking hard.
b-f-c
PostPosted: 15:08 - 23 Jan 2008    Post subject: Reply with quote
Dropping the forks through the yokes will reduce the angle of rake, which will change the way it steers - I think it translates to 'will turn into corners quicker'
I would ask the owners club too see what they suggest
PostPosted: 15:13 - 23 Jan 2008    Post subject: Reply with quote
Should be compensated by dropping the rear the same amount if they do what they are thinking of.
Noxious89123
PostPosted: 17:22 - 23 Jan 2008    Post subject: Reply with quote
Cheers guys, will bear that in mind. Still gotta save some pennies before i buy!
The last post was made 18 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.02 - MySQL Queries: 13 - Page Size: 79.99 Kb
