| trevoriv |
 trevoriv World Chat Champion
| Kickstart |
 Kickstart The Oracle
 Posted: 18:42 - 23 Jan 2008 Post subject: |
Normally I would say the chain would be the most likely cause. Check for any tight spots.
However given you say you have checked the chain and you have just had new tyres then I would be checking the rear wheel bearings.
The sprocket carrier has a bearing of its own and then there is a spacer between the bearing in the sprocket carrier and the bearings in the wheel. If this spacer goes missing then there is nothing supporting the bearing from one side. Normal ball bearings are not that good at coping with a sideways load so tend to rapidly fail when this happens.
Check quickly as this can have nasty effects. You may feel the extra play, and might find the sprocket is a lot closer to the swinging arm than it should be. Could possibly be touching (and if it is don't ride the bike until you have sorted it).
| trevoriv |
 Posted: 19:44 - 23 Jan 2008 Post subject: |
Cheers.
Ive probably just ballsed up adjusting the chain. Althought he bearing idea does make more sense. Meh, im not to be trusted with mechinical devices.
Looks like im on the train to work until i can get it to a garage
Bums. ____________________ Past: '96 Thundercat, '02 ZX636R (A1P), '58 KTM 690 SM LC4 Current: '06 ZX636R (C6F)
Mudskipper wrote: Someone just has to sig that... |
| Kickstart |
 Posted: 19:46 - 23 Jan 2008 Post subject: |
| trevoriv |
| Itchy |
 Itchy Super Spammer
| trevoriv |
| Itchy |
 Itchy Super Spammer
 Posted: 23:00 - 23 Jan 2008 Post subject: |
Do you want me to come round to have a look Saturday?, yes I know I mostly ride me shaft drive NTV. You only need two bits of string to do this jobbie. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| trevoriv |
 Posted: 23:12 - 23 Jan 2008 Post subject: |
| TUG |
 TUG World Chat Champion
The last post was made 18 years, 155 days ago. Instead of replying here, would creating a new thread be more useful? |
