In the jungle a Badger roared today
Ariel Badger
PostPosted: 20:48 - 27 Jan 2008    Post subject: In the jungle a Badger roared today Reply with quote
Seven months and quite a few hundred working hours after I started work on the hill climbing 1936 350 RH (the Badger) today was the day to breath some life into her.
Dougie Walker was summoned and he supplied some high octane fuel and Speeroil grease for the box.
We fuelled and lubed her and took her up the top of the road for a bump start. First attempt was a bit lame as the 10.5-1 compression just locked the wheel in second. Third gear at least turned the engine over and we got a bit of a pop out of it so back to the top of the hill and a real hard push in third and she burst into life. She has no silencer and only a stubby high level pipe this combined with the compression ration resulted in an exhaust note that puts the HS to shame. As I had no helmet or gloves on ( and the bike has no road registration) I restricted my first ride to a quick burst up and down the road until Doug flagged me down. I was squirting oil from the engine at an alarming rate, the problem was quickly traced to the pressure gauge connection. I was not using a gauge but had neglected to blank off the port, a 1/4 bsf screw did the job and we topped up the oil and pushed her back up the hill this time I had a crash hat on and a silencer jammed over the end of the pipe and held in place with a bungee. At the end of the road I performed a U-turn, unfortunately I had not built enough travel into the steering stops and the bike had a somewhat restricted turning circle. I leaned off the bike a bit too far and hit the bump stop resulting in me going clattering down the road breaking the front brake lever and removing enough meat for a ferret's dinner from my elbow.
A bit of fettling sorted the steering but then it was apparent that the oil was not returning to the tank so we pulled the timing cover off and striped the pump down, a bit of crap under the non-return valve ball seemed to be the cause so we nailed it all back together. Doug was getting a little tired of pushing (he is 69 on Tuesday) so we phoned Marc up.
First thing Marc noticed was excessive valve clearance So we sorted that and fired her back up, the oil was now circulating as it should so I took her around the block. She seems to pull like a train and feels more like a 500 VH than a 350 RH with the front wheel threatening to lift as the power piles on, a dry weight of under 100Kg makes a difference. The revs raise very quickly ( lightness of valve gear etc?) but there is a bit of a flat spot at full throttle that may need a bigger main jet.
All in all a very satisfying day and big thanks to Marc and Dougie.
Wali
PostPosted: 21:25 - 27 Jan 2008    Post subject: Reply with quote
I think we need some audio clips of your amazing bike Very Happy
hmmmnz
PostPosted: 21:35 - 27 Jan 2008    Post subject: Reply with quote
at least the valve clearance are easy to do Very Happy
wicked looking bike Very Happy Thumbs Up
the humans are dead
I kick arse for the lord
Ariel Badger
PostPosted: 21:53 - 27 Jan 2008    Post subject: Reply with quote
I think she looks like sex in aluminium. As you say open valves are easy to adjust and fact that I decided not to use tubes for the rods and the sidevalve tappet blocks made it easier still.
mistergixer
PostPosted: 11:24 - 28 Jan 2008    Post subject: Reply with quote
I'm not generally a fan of older bikes, but that thing looks like it would bite your arm off and then shag your mum/sister.
Giz a go mister, go on, giz a go.
Very Happy
Space Monkey #7
Endless Nameless
PostPosted: 11:38 - 28 Jan 2008    Post subject: Reply with quote
Awsome looking bike. Classics rock. Love the bare metal look and all.
Erm, badger. Am I missing something? (quite probable)
Anyway, it's great and cheers for sharing Very Happy
A2 passed 22/07/08; restriction up 22/07/10 (just so I don't forget)
'79 Suzuki GS550E. Yes, that's a GS550, not a GS500.
Supersports "In a video editing competition I'd kick your sorry ass"
neatbik
PostPosted: 12:19 - 28 Jan 2008    Post subject: Reply with quote
awesome bike Thumbs Up
i take we'll be seeing you at redmarley on the beast?
Ariel Badger
PostPosted: 20:17 - 28 Jan 2008    Post subject: Reply with quote
She is built just for Red Marley, hundreds of hours and a thousand quid for a couple of miles of riding Very Happy
Thanks for all the positive coments.
PostPosted: 21:08 - 28 Jan 2008    Post subject: Reply with quote
Good period touch with the "Drilled for lightness" engine mounts.
neatbik
PostPosted: 21:15 - 28 Jan 2008    Post subject: Reply with quote
looking forward to seeing you mate, not long to go now Very Happy Thumbs Up
Lone-Wolf
Wotcha.
I think you'll find that's a classic case of 'Aluminium Worm' Wink
Terrible little beasties they are.
Cheers.
L.W. - www.moonshiners.org.uk
The last post was made 18 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 72.02 Kb
