- Computer bits
P_J
PostPosted: 11:07 - 12 Jan 2004    Post subject: [WANTED] - Computer bits Reply with quote
AMD Athlon XP 2500+ / 2600+ / 2800+ (or better)
* I have found them new, here for approx 65 > 85 quid so obvliously I am after a cheaper one. Does not have to be new, has to be good working order. (with fan)
DDR RAM PC2700 333MHz
* Total, I would like one Gig (2 x 512MB) but will settle for 512 for now till I get the cash for more. I'm skint, so the cheaper the better. Not bothered about the make etc, unless it is well known, worldwide to be absolute shite.
Will add / change list as I get parts / ideas
Cheers!
PJ
{edit} I am looking, and bidding on ebay at the moment{/edit}
Dreams will get you nowhere, a good kick up the arse will take you a long way.
Only1PJ.co.uk
P_J
PostPosted: 21:43 - 15 Jan 2004    Post subject: Reply with quote
Network Card 10/100
* My laptop has LAN, my new PC has LAN and I want to connect the three together (third being my old PC).
Will I need two seperate LAN cards or one with two ports?
PJ
Only1PJ.co.uk
PostPosted: 22:02 - 15 Jan 2004    Post subject: Reply with quote
You could get two cards, but it'd be better to get a hub or switch.
I've most probably got spare cards around, might be able to do something with the memory, but not sure if I got 'owt spare.
P_J
PostPosted: 22:08 - 15 Jan 2004    Post subject: Reply with quote
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=176&item=3070516851
This would do wouldn't it?
Only1PJ.co.uk
PostPosted: 22:12 - 15 Jan 2004    Post subject: Reply with quote
Yep, that should be fine.
Remember you'll also need 3xpatch cables (not reversing) if you don't have them.
Can be picked up for bugger all from any decent computer place.
P_J
PostPosted: 22:47 - 15 Jan 2004    Post subject: Reply with quote
What is the difference between this
https://image.ebuyer.com/UK/P0016463_C0000024_P0000000.jpg
This says it's a patch cable.
and this
https://image.ebuyer.com/UK/P0043773_C0000024_P0000000.jpg
This says crossover cable.
Only1PJ.co.uk
PostPosted: 22:53 - 15 Jan 2004    Post subject: Reply with quote
A crossover cable is purely used to connect two computers together.
If you do it this way you do not require a hub, but you can only connect two computers.
A patch cable is a normal straight through cable for use with hubs.
P_J
PostPosted: 11:01 - 18 Jan 2004    Post subject: Reply with quote
80 or 120 Gig HDD
* Must be cheap as chips, but not compleat crap. Smile
PJ
Only1PJ.co.uk
The last post was made 22 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 58.7 Kb
