Bikes
Eddie Hitler
PostPosted: 20:02 - 02 Feb 2008    Post subject: Bikes Reply with quote
When it comes to normal bikes (push-bikes) im pretty useless.. i was thinking of just going to Halfords to buy a bike, but after some things ive heard im wondering if thats a good idea?
Basicly ill be using the bike 8 miles a day (work and back), on single country lanes.. like i said im useless.. is a front suspension bike the best type to go for?
Marcg868
PostPosted: 20:29 - 02 Feb 2008    Post subject: Reply with quote
Whats your budget?
Something like a Specialised Hardrock is a good bike for travelling to work and also for a bit of singletrack dirt riding. Look for Cross Country type bikes. Which are just basically hardtail framed with decent front forks for road riding and light off road riding.
Dont go for full suspension ones as their pointless on the road.
Also avoid dirt jumping type bikes as these have very low frames.
https://www.leisurelakesbikes.com/ProductDetails/mcs/productID/13685/groupID/7/categoryID/75/v/f1db18d9-8ca0-40c5-90a6-636994deb592
something like this is ideal although depends on your budget
JACK, MISS YOU LOADS YOU LEGEND.
UnknownStuntm...
PostPosted: 21:01 - 02 Feb 2008    Post subject: Reply with quote
Carrera (Halfrauds own brand) make some surprisingly good hardtails. Try not to get to worked up about the name on the top tube, ride a few around and you'll find something that steers right and feels just lively enough to buy. I think the Vulcan has always been a good, underrated bike.
Dischord
PostPosted: 21:06 - 02 Feb 2008    Post subject: Reply with quote
I work in Bikehut (Halfrauds bike dept) and someone in your shoes I would just recommend and Apollo XC26, if you wanted to upgrade go for the XC26 S which has better front forks and a disc brake. Good enough to get you to work and back and as long as you look after it should go for ages! You'd also get free service etc if it did go wrong.
89.99 cant go wrong Very Happy
2012 KTM EXC 250
Eddie Hitler
PostPosted: 21:18 - 02 Feb 2008    Post subject: Reply with quote
Cheers guys Thumbs Up
PostPosted: 21:25 - 02 Feb 2008    Post subject: Reply with quote
What happens when one does go wrong? Wink
If wanting an inexpensive pushbike for riding on the roads don't get suspension, no need for it unless you're going to be venturing offroad. The money is better spent towards other parts being better quality. Freeads rather than new if looking less than a few hundred, you'll get a lot more bike for your money.
Wouldn't buy from Halfords unless you know what you're doing with pushbikes cos you'll get someone trying to sell you something inappropriate for what you want. Rolling Eyes
Walloper
PostPosted: 21:26 - 02 Feb 2008    Post subject: Reply with quote
'Taking Up' things:
Rule No. 1) Never go into it half baked. Thumbs Up
Rule No1 2) Either spend a fortune on the kit or buy cheap and regret either later. When you get into it the shit kit will put you off. When you give it up the money you wasted on kit will depress you.
I would go with the Specialised. It's a lot of bike for the money and they take more shit than you can shovel into a wheelbarrow.
I took one out to the jungles of Ghana and I broke before the bike. Embarassed
But nowt wrong with Halfrauds if on a budget. And the mechanic guys in the stores are not too bad. (if you count out Discord that is Razz )
Buy the proper shoes. Hard soles make such a magical difference to a few miles of pumping everyday. Use toe clips if fitted they sort-of half the work you have to do as you can pull the pedal round on the up stroke.
Pedal biking is more to do with energy conservation than anything.
I hope we don't lose you to www.pedalbikechatforums.com They are well Ghay Razz (I heard Embarassed )
owdamer
PostPosted: 21:40 - 02 Feb 2008    Post subject: Reply with quote
I had an apollo and to be honest it was a pile of shite. If you wanted to stop in a hurry your best bet would be to jump off the thing. I took the bike bike as I considered the brakes to be dangerous. The halfords guys adjusted the brakes and they still wern't capable of locking the front wheel while walking the bike in the shop, never mind with me riding it. I said it wasn't fit for purpose and the halfords guy said he couldn't disagree so I swapped it for a raleigh.
Obviously not in the same league as the higher end stuff but it does me. I only use it for short trips up & down the canal towpath.
UnknownStuntm...
PostPosted: 09:23 - 03 Feb 2008    Post subject: Reply with quote
Agreed. Apollo bikes are normally made in a large chinese or vietnamese factory where they don't have words for 'tighten' or 'safe' so I wouldn't recommend one for anyone going near a road or off-road.
RealNinja
PostPosted: 14:12 - 03 Feb 2008    Post subject: Reply with quote
Avoid the Apollo shite!
The Carrera stuff is o.k, cos although it's Halfrauds own stuff they had help from Giant when they designed them.
The Carrera Kraken, for instance, is a perfectly capable singletracker.
Remember these things.....
1. You get what you pay for, you may not be able to see what you are paying for, but a set of disc brakes on a £300 bike means horrible cheap components where it counts (chain set, crank etc)
2. Go to a proper bike shop, and be absolutly honest about what you are buying the bike for, they will help you (at least the local ones round here will!)
3. Don't be drawn into having this years model.....MTB's are like cars, if you are happy to go for last years model, you may well get a blinding bargain, just cos it's last years colours/components.
4. If you are looking into doing this with any sort of venom, spend the most you can afford, in the long run it'll pay off when you bike isn't creaking and making funny noises in 3 months time!
5. Light is good! You would be amazed how light MTB's are with the right parts and frame, and the effort involved in trying to pedal a heavy bike up a hill may be the difference between getting on the bike every morning and thinking 'f*ck it, i'll take the car/bike'
6. Cable operated disc brakes are SH*TE!, go for a decent set of V brakes, or spend the proper money
on a wet brake system!
If you are only really honestly going to use it for work and back....I would go for the Hardrock - decent components, light enough and adequate for your porpoises
Something to think about..... Embarassed
You will become my force of retribution. Where you tread, doom will follow. Go now and claim your destiny
Eddie Hitler
PostPosted: 14:17 - 03 Feb 2008    Post subject: Reply with quote
Thanks ninja Thumbs Up Karma Ive been hearing Hardrock alot now so i think thats what ill be going for. Ones popped up on eBay - it says the specs are:
Deore LX shifters. Included also is a Hope M4 front brake with 203 front disk The rear brake is Magura hs33 hydraulic rim brake which provides excellent stopping power Hardly used Marzocchi MZ III front forks Alex DM24 rims nearly new And brand new WTB werewolf front tyre Also dmr v8 pedals and included are some TIME spd's Not to be missed Upgrade forces sale
Any good?
RealNinja
PostPosted: 14:21 - 03 Feb 2008    Post subject: Reply with quote
Any good?
Yes, and yes....
A little more than you need for work and back, but if you can get it for a reasonable price have it! (mind your shins/calves on the V8's Wink )
Eddie Hitler
PostPosted: 14:23 - 03 Feb 2008    Post subject: Reply with quote
What would you say a reasonable price for it is?
RealNinja
PostPosted: 14:29 - 03 Feb 2008    Post subject: Reply with quote
Damn, I knew you were going to ask that!
Give me a minute to check the components..... Rolling Eyes Laughing
Marcg868
PostPosted: 14:30 - 03 Feb 2008    Post subject: Reply with quote
I forgot to mention about the V8's they are excellent, but do be careful as them pins will gouge your shins if you slip with them. But a good set of grippy trainers like Vans are good with them.
Id pay £120 -£150 for that Hardrock on ebay. Alot of bike for the money Smile
Eddie Hitler
PostPosted: 14:33 - 03 Feb 2008    Post subject: Reply with quote
Laughing Thumbs Up Thumbs Up Thanks guys, wish me luck Twisted Evil
RealNinja
PostPosted: 14:39 - 03 Feb 2008    Post subject: Reply with quote
Components new are about £500 squids, excluding the frame, which would have cost about £300 ish new, so off ebay....
I would pay about £300 quid for it and then look at spending another £100 squidlings on having it stripped down and serviced....
I would be looking at doing some 'proper' MTBing on it though, for the money, cos that's what it's been specc'd for.
Eddie Hitler
PostPosted: 14:42 - 03 Feb 2008    Post subject: Reply with quote
I live in the sticks..
I used to ride to school everyday (same distance) and often take the walkways, but my bike was shit for that. So it will more than likely be used off-road. And 0_o!! Lets hope i get a good deal Very Happy
Walloper
PostPosted: 16:20 - 03 Feb 2008    Post subject: Reply with quote
You wont need to worry about de-laminating your shins-calves on the pedalerimos if you go to the bother of fitting toe clips.
They keep your plates of meat on the pedal.
I almost needed a fuckin bone graft once when I was pushed off my bike by a big jaggy bush. Sad
Nothing better then pushing the stoopid fukcing heap of shite home with a sock full of blood and guts. Laughing
They can be a cnut to install but well worth the effort.
(You learn real fast how to get your feet out before stopping too. Embarassed )
Eddie Hitler
PostPosted: 20:03 - 03 Feb 2008    Post subject: Reply with quote
Hes asking £200 for it. Worth it?
pwntifex
PostPosted: 20:19 - 03 Feb 2008    Post subject: Reply with quote
Yea. See if you can get him into the 100s though.
Marcg868
PostPosted: 20:26 - 03 Feb 2008    Post subject: Reply with quote
Snap it up at that price, but offer him £180 see if he bites.
I think them HS 33 magura's rear brakes are nearly £150 on their own.
cagiva gezzer
PostPosted: 22:12 - 03 Feb 2008    Post subject: Reply with quote
Maguras are old hat. £200 is a good price though, as long as it's not too bashed .
Marcg868
PostPosted: 23:44 - 03 Feb 2008    Post subject: Reply with quote
I swear by mine, as i think their better than regular cable V brakes on the back. And i never really liked having a disc on the back so these are were the ideal option.
thx1138
PostPosted: 16:24 - 04 Feb 2008    Post subject: Reply with quote
I have a road bicycle, it has drum brakes, and a 8 speed sturmy archer type gearing, great for commuting, and the brakes are much better than those blocks that clamp the wheel rims.
The last post was made 18 years, 237 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 128.01 Kb
