Flashing energy saving lightbulb.
McJamweasel
BCF Junkie
PostPosted: 21:59 - 08 Feb 2008    Post subject: Flashing energy saving lightbulb. Reply with quote
As per the title really, the energy saver in the landing light flashes after its turned off. The longer its been on for, the brighter it flashes and the longer it goes on, I assume that this means its a capacitor discharging or similar. Is it a problem? If I just carry on ignoring it (which is easy as the light isn't on for very long very often) is it going to kill kittens and eat babies or will it be OK?
CRAZY_BIKER
Guest
PostPosted: 22:04 - 08 Feb 2008    Post subject: Reply with quote
How long does this go on for ?
Confused
McJamweasel
BCF Junkie
PostPosted: 22:09 - 08 Feb 2008    Post subject: Reply with quote
Not long, a few minutes.
CRAZY_BIKER
Guest
PostPosted: 22:12 - 08 Feb 2008    Post subject: Reply with quote
HAHA! That is mental ! Shocked
Stelmer
Strange, I use eco bulbs everywhere and never experienced this.
Is the bulb blackened when lit (where the electrodes are)?
I have had loads of cheap ones burn themselves out in a few months
Itchy
PostPosted: 22:22 - 08 Feb 2008    Post subject: Reply with quote
its normal if you keep them long enough, I had a few from the 90s , used as stairwell lights , they would do the same on and off , all these energy saving bulbs are I reckon are just floresent tubes but in bent glass, and anybody who has those floresent tubes knows the starters die after a few years of use, since starters are non replacable in these things you have to chuck them.
Also due to such things they are not as tolerant as std bulbs in places like toilets where the bulb is on many times but only for a short while.
Walloper
PostPosted: 22:36 - 08 Feb 2008    Post subject: Reply with quote
THIS THREAD IS USELESS WITHOUT PHOTOGRAPHS!
Stelmer
PostPosted: 23:33 - 08 Feb 2008    Post subject: Reply with quote
Here's mine. It's about 3 years old and gets around 6 hrs use a day. The picture looks brighter than it is. Mr. Green
It's rather difficult taking a photo of a lit bulb for some reason Laughing Wink
Ichy
PostPosted: 00:12 - 09 Feb 2008    Post subject: Reply with quote
I've got one outside thats been doing it for two years. I personally don't think its down to starters, I put it down to the loop wiring, you know, like how you can light up a florescent tube by touching it?
carvell
Scuttler
PostPosted: 01:15 - 09 Feb 2008    Post subject: Reply with quote
Mine does exactly that too.
Guess it's just as they get old or something.
Yamaha TDM 850
leiba1
PostPosted: 11:22 - 09 Feb 2008    Post subject: Reply with quote
i have exactly the same thing so I contacted the bulb makers. This is the reply I got.
"There is actually no fault with your electrics. Unfortunately with the old style of energy saver lamps this phenomenen can occur where the lights are on a 2 way circuit. between the 2 switches used there are 2 strapper cables one of which will always have a voltage going down it. This voltage is induced onto the other strapper and your lamp is seeing it trying to ignite but ultimately switching off again as there is no current flowing.
Richard Kellaway
Philips Lighting Technical
Tel 01483 29 3258
Fax 01483 29 8822 "
Still seems odd though.
Ichy
PostPosted: 11:31 - 09 Feb 2008    Post subject: Reply with quote
Thats what I said, sort of Wink
mr.z
PostPosted: 12:16 - 09 Feb 2008    Post subject: Reply with quote
Itchy wrote:
..all these energy saving bulbs are I reckon are just floresent tubes but in bent glass..
As far as i understand it thats precisely what they are, just slightly more clever, in the not too distant future that'll be all thats available to buy.
I reckon if you were so inclined you could open it up and solder on a new starter.
In fact i reckon there be big business in getting used bulbs and reconditioning them, chances are they'll just be smashed in a bin and then need remaking.. hooray for half arsed shitty environmental policys!
iCraig
PostPosted: 12:23 - 09 Feb 2008    Post subject: Reply with quote
Never heard of it happening, but we have a energy saver thats 11 years old and still working!
Also don't break Energy Savers Mr Z, they contain mercury! Surprised
Finglonga
PostPosted: 12:40 - 09 Feb 2008    Post subject: Reply with quote
As do florescent tubes and always have.
Andy Sez....
F.Y.Y.F.F.
garyd
PostPosted: 09:25 - 10 Feb 2008    Post subject: Reply with quote
And here lies the trap.....its not well known that each flash clocks up around £3 worth of leccy used........repeated flashing is clocked up at the power of 4 so you my friend are looking at a hefty bill...................................probably! Rolling Eyes you didnt think "energy saving" was aimed at you /us did you ??its a government ploy Shocked
CRF230 all you need
Walloper
PostPosted: 13:03 - 10 Feb 2008    Post subject: Reply with quote
Same as there are 'talks' about charging you to coast down hill in neutral.
They have technology available to impose such controls.
I wonder if some Science Buff out there will come up with some clever electronic gadgetry to thwart that one? Eh! Wink
Stelmer
PostPosted: 22:59 - 10 Feb 2008    Post subject: Reply with quote
Eco lamps have no starters in them. They are started electronically. A 7w eco lamp will actually draw around 5w when warmed up.
The only ones to have starters are the ones with a removable bulb
like the butterfly ones.
Conventional fluorescent lamps do use more elecc than what it says on the tube though.
A 18w 2ft fluorescent lamp uses 30w. it starts off at about 10w and rises once the tube is energised.
EuropeanNC30R...
Gay Hairdresser
PostPosted: 23:33 - 10 Feb 2008    Post subject: Reply with quote
The one in my bedroom does it too, a little strange but I can't say I stay awake at night worrying about it.
The last post was made 18 years, 60 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 100.38 Kb
