ns125r wont rev above 6000
busy
PostPosted: 23:49 - 18 Jan 2004    Post subject: ns125r wont rev above 6000 Reply with quote
hello everyone i have just purchased a ns125r but it has a problem that the engine wont rev above 6000 on the road but it will in neutral but feels that its being strangled so i would like to no if this has been experienced before or if anybody knows any ns specialist in the midlands area thank you ****fixed*** problem was restricted exhaust managed to get brand new micron from exeter 175 pounds, as old exhaust was a derestricted type but blocked internally thanks for replys
PostPosted: 00:34 - 19 Jan 2004    Post subject: Reply with quote
They do not go much beyond that in good condition if they are restricted (well, not without a lot of effort).
Is it still restricted?
GFK
PostPosted: 00:42 - 19 Jan 2004    Post subject: Reply with quote
Eh? Mine's restricted and it does 9,000rpm easily.
Are you trying to rev it up from cold? If I do that on mine it won't go much above 5,000rpm either. Best to let it warm up for a few minutes first. After that it should be going as far as you want to take it.
PostPosted: 00:59 - 19 Jan 2004    Post subject: Reply with quote
Well, I was thinking of in the higher gears!
Will it rev out in the lower gears once warm?
Sparks!
Sir Tart-a-lot
PostPosted: 01:02 - 19 Jan 2004    Post subject: Reply with quote
If it revs out in neutral no problems, but not on the road then as Kickstart said he could be in a higher gear, and as Kickstart says... It won't rev much past it. (If that makes sense)
So maybe there's nothing wrong, it's just restricted?
Ian (GPX)
PostPosted: 09:53 - 19 Jan 2004    Post subject: Reply with quote
Most NS125R's will rev past and up to 10k in gears 1 - 4, once you get into gears 5 & 6 the NS125R will struggle to reach 7k unless your going down hill.
The NS125R I sold last year could rev to 10k with ease, but as soon as 5th or 6th gear was selected the revs just could not reach 10k, the max I got in revs if I can remember was 8k in 6th gear and at times the bike just started to die and overheat, I had to drop her down to 5th just to keep the speed up at 85mph. On a good day, the bike could do 93 - 97mph in 6th gear @ 8,500k, but it was rare.
Sounds like the jetting or mixture could be out on his NS125, or air filter leaks / blocked.
The last post was made 22 years, 130 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.47 - MySQL Queries: 13 - Page Size: 48.87 Kb
