How much?...
highland biker
PostPosted: 20:40 - 12 Feb 2008    Post subject: How much?... Reply with quote
... Would it be to get a new cam chain tensioner fitted at a garage/dealer?
Cheers Thumbs Up
EDIT: yeah sorry its a SRAD 600
NSR Mick
PostPosted: 20:45 - 12 Feb 2008    Post subject: Reply with quote
On a CG125 or a GSXR1000?
the grim reaper
PostPosted: 21:40 - 12 Feb 2008    Post subject: Reply with quote
Depends on the bike, a Blade is one 13mm centre nut and two 8mm bolts, absolute piece of piss, unless the gasket falls apart on you but it shouldn't.
As stated, depends on the bike.
Grim
Phoenix
Twisted Firestarter
PostPosted: 02:51 - 13 Feb 2008    Post subject: Reply with quote
Not exactly the best thread title, and very lacking in information as said. However as I know from your previoius post you have a 600 SRAD then I would guess about 1.5-2hours labour so depending on their labour rate, £40-80 probably. It's just fairing off, and 3 bolts.
Now presumably this is because you have a camchain rattle, if you do and it's not a death rattle I wouldn't bother swapping it, you may still have it, this is a GSXR. Might be worth removing the tensioner and then cleaning and resetting it's position as they often stick, this is why they're considered to fail.
If you do go for a replacement, get a Suzuki one, a manual one will need manual tensioning and if you forget you're in trouble, if you overtension you're also in trouble.
benc
PostPosted: 04:12 - 13 Feb 2008    Post subject: Reply with quote
Hopefully its not a bastad like a zxr400 where you have to drop the engine out to do it Evil or Very Mad
But if not it should just be an hour or two's labour as said.
zxr400 - zx7r
highland biker
PostPosted: 16:56 - 13 Feb 2008    Post subject: Reply with quote
Really I thought that once you take it off it cant be used again
Oh and how do I tell when its the death rattle Question
Phoenix
Twisted Firestarter
PostPosted: 02:43 - 14 Feb 2008    Post subject: Reply with quote
Benc, not sure on the ZXR400, I know they also suffer failing tensioners and camchains, presumably the chain is in the middle on those with 2 cylinders either side making it hard to access, it's on the offside of the engine on the GSXR, only needs the sidepanels taking off, maybe the tank too.
If you've got a death rattle you'll know about it, be this metallic lashing noise as the chain rattles around like a tin of nails, it'll get worse as the engine gets hotter. If you've only got a very minor rattle, similar to a clutch rattle then it's probably nothing to worry about, as I said, you could well fit a new tensioner and still have the noise. They can indeed be removed, cleaned and replaced, they're just a spring loaded ratchet mechanism.
Tristan.
PostPosted: 02:53 - 14 Feb 2008    Post subject: Reply with quote
Mattsprattuk mentioned that he got a quote for one recently on a '97 SRAD, though I wasn't paying attention to him at the time so I'm not sure how much he said it was, £25 possibly, drop him a PM.
the grim reaper
PostPosted: 08:58 - 14 Feb 2008    Post subject: Reply with quote
Eh? 1.5 to 2 hours labour? Not in this lifetime. On the SRAD you can just drop the fairing lower and go from there. I reckon about ten minutes, although most places will charge you an hours labour as a minimum charge.
Grim
Phoenix
Twisted Firestarter
PostPosted: 03:38 - 15 Feb 2008    Post subject: Reply with quote
Which is why I stated 1.5-2hours. Not many places will charge you for less than an hours labour. If they have to remove the sidepanels (maybe tank too), and remove clean and replace the tensioner and then roadtest it (some insist on this) then you are looking at 1hour absolute minimum possibly rounded up to 2, so my point stands. I'd be impressed to see someone take off the sidepanles on a GSXR, take out a camchain tensioners, clean it up, replace it and refit the sidepanels in 10minutes, be realistic.
The last post was made 18 years, 151 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.87 - MySQL Queries: 13 - Page Size: 65.04 Kb
