Neutral Light
Billd
PostPosted: 16:38 - 17 Feb 2008    Post subject: Neutral Light Reply with quote
Hi, when I pull my clutch in the neutral light comes on, when I let the lever out it goes off (except if the bike's in neurtal Wink ) Any ideas??
Itchy
PostPosted: 16:42 - 17 Feb 2008    Post subject: Reply with quote
sounds exactly like what my NTV is doing TBH , not diagnosed the problem though ..
PostPosted: 17:19 - 17 Feb 2008    Post subject: Reply with quote
Sounds like it could well be a bad connection on the clutch switch. What bike is it.
Does the engine cut out when this happens?
Does it stay on all the time when the bike is in neutral.
Billd
PostPosted: 17:44 - 17 Feb 2008    Post subject: Reply with quote
It's a 1982 CB750 Custom & the problem doesn't affect the running at all. The light is on all the time unless it is in gear with the clutch out Sad
garyd
PostPosted: 18:23 - 17 Feb 2008    Post subject: Reply with quote
Replace neutral switch Neutral
CRF230 all you need
tutton
PostPosted: 19:59 - 17 Feb 2008    Post subject: Reply with quote
Black insulation over the bulb
hahaha
PostPosted: 17:50 - 18 Feb 2008    Post subject: Reply with quote
Unlikely to be the neutral switch causing the problem.
I suspect your clutch switch is duff. There are usually three wires. One connects to earth, one connects to the neutral switch, the third connects to the starter motor relay.
What should happen is when the clutch is out, the relay wire is connected to the neutral switch. When the clutch is in, the relay wire is connected to earth.
It would appear in your case that when the clutch is pulled in, the neutral switch is being connected to earth also/instead. Now you need to find out why.
I'd suggest cleaning the switch first off. Then testing it with a multimeter, then checking it has been connected up correctly and finally checking the wires leading away from it for damage/shorts.
It would be interesting to see if your starter motor also works when in gear with the clutch out (carefully), if it does, there is a good chance someone has connected the switch up incorrectly.
garyd
PostPosted: 22:51 - 18 Feb 2008    Post subject: Reply with quote
Good info Stink Thumbs Up
CRF230 all you need
The last post was made 18 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.67 - MySQL Queries: 13 - Page Size: 56.89 Kb
