| Damon |
 Damon World Chat Champion
| Mr.Everready |
 Mr.Everready World Chat Champion
| Itchy |
 Itchy Super Spammer
 Posted: 19:22 - 15 Feb 2008 Post subject: |
The thing is all your brake fluid will pee out when you pop the pistons anyway , so just lose the brake fluid that way,
But to bleed it you do pretty much what you said just keep topping it up so that it doesn;t get more than 50% empty, if the fluid coming out the caliper bleed nipple is only fluid and no bubbles you can bleed it from the top.
Ie do up the bleed nipple and slowly pump the lever with the top of the master cylinder off, it can take 15-30 minutes of pumping it to get the minute bubbles out. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Damon |
| Itchy |
 Itchy Super Spammer
| Damon |
| garyd |
 garyd Brolly Dolly
 Posted: 18:27 - 17 Feb 2008 Post subject: |
Change the fluid,bleed brake then cable tie lever back to bar overnight ..that will do it  ____________________ CRF230 all you need |
| Damon |
| Damon |
 Posted: 19:19 - 18 Feb 2008 Post subject: |
| Hetzer wrote: | If you leave the reservoir-cap off, the fluid will absorb moisture from the air, so don't do it.
To successfully bleed the system (after you have re-assembled the calipers) you first need to fill the system with fresh fluid.
Once you have fresh fluid coming out of the nipples you need to bleed the system of air. You can try to use a kit, but you will probably fail due to air being sucked back through the nipple-threads. The solution to this is to do the procedure 'manually'.
Transparent pipe from nipple into jar with fluid in it, so that the pipe's orifice is submerged. Crack nipple open a tad, pump brake lever and hold it closed, close nipple, release lever. Repeat continuously until no bubbles are appearing in the pipe.
Tap calipers, stand bike upright, shake it, dive forks, tap reservoir, try to dislodge any hidden bubbles. Repeat bleed procedure from nipple.
Finally, with nipples and reservoir closed, pump up the brake lever and clamp it fully on with tie-wraps and leave overnight. In the morning put the pipe back on the nipple, crack nipple a tad and see what you get. If bubbles, repeat bleed procedure. |
Brilliant.
Thanks, you are a star.  |
| garyd |
 garyd Brolly Dolly
 Posted: 22:49 - 18 Feb 2008 Post subject: |
what i managed to say in one line | Hetzer wrote: | If you leave the reservoir-cap off, the fluid will absorb moisture from the air, so don't do it.
The last post was made 18 years, 31 days ago. Instead of replying here, would creating a new thread be more useful? |
