Carbs
matty8887
PostPosted: 15:57 - 10 Feb 2008    Post subject: Carbs Reply with quote
Hi all,
Well heres my problem, i have a yzf750r and was having problems with the petrol consumption and flat spots.
Ive had the carbs off,cleaned them out, replaced the emulsion tubes with titanium ones, cleaned them all out and reset the pilot screws to 2 turns out as stated in the manual and i measured the fuel level and was surprised that it was 15mm!
I set this back down to 7mm by bending the tabs on the floats(they looked new and probably wasnt done when they were fitted)
All four carbs are roughly 7mm like it says in the haynes.
I put it all back together and fired it up, with full choke on it was only on 1.5k revs where as befor it would go to 5k revs on full choke. If there was no choke it wouldnt idle and would stall.
It would idle fine and run ok before i did the carbs, one thing though is the pilot screw was turned out 3/4 time when i first took the carbs out but i reset it to 2 as it stated in the haynes manual but now it runs crap at idle.
Its also a bit noisier than is was before.
Any suggestions as to what it is, i know it could be a few things just wondering what it sounds most likely to be.
Cheers, matt
Test passed october 2005
Cadburys boost yamaha yzf 750r
TUG
PostPosted: 16:44 - 10 Feb 2008    Post subject: Reply with quote
But did you walm the bike up and full choke and let it get to a good temp and then set the idle???
Think you missed resetting the idle after changing alot of the carbs.
Did you set the floats on a flat surface? Any mods done to the bike? Exhaust, air filter?
Haz ER-5, innit!
matty8887
PostPosted: 08:13 - 19 Feb 2008    Post subject: Reply with quote
Hi, havent been on the net for a week so ill reply now.
I warmed the bike up to full temp reset the idle and it would flutter all over the place, i set the carbs float height on the bike so i know they are correct.
The bike has a sports end can and a k&n panel filter but this was jetted to suit before and i havent changed the jets only the emulsion tubes/needles as they were worn.
As i said the pilot screws on the carbs were out 3/4 turns before but in the book it suggests 2 and then to fiddle about with them a bit which i have a lottle bit but no difference.
The idle wont stay constant really, the petrol has been standing a couple of months though but i wouldnt have thought it would effect it this much?
Bru
PostPosted: 10:43 - 19 Feb 2008    Post subject: Reply with quote
Perhaps, after all that work on your carbs, you need to rebalance them. At least, get a gauge to check.
TUG
PostPosted: 18:35 - 19 Feb 2008    Post subject: Reply with quote
Beat me too it, if not balanced correctly they can have trouble idling.
Re balance and see if it will idle again, swap the guages over incase one of the gauges it out. Thumbs Up
Haz ER-5, innit!
matty8887
PostPosted: 22:45 - 19 Feb 2008    Post subject: Reply with quote
ok guys, will try that first on the weekend and let you know Thumbs Up
The last post was made 18 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.7 - MySQL Queries: 13 - Page Size: 47.87 Kb
