Tzr125 problem
nipper2803
PostPosted: 12:56 - 19 Feb 2008    Post subject: Tzr125 problem Reply with quote
I took my tzr125 out today for a run and i couldnt get the rev counter to go past 7500rpm when it reaches this the throttle cuts out. Please help
TUG
PostPosted: 18:33 - 19 Feb 2008    Post subject: Reply with quote
Is that in top gear? or all the way through the gears?
Also what yeatr/model TZR?
Haz ER-5, innit!
nipper2803
PostPosted: 19:37 - 19 Feb 2008    Post subject: Reply with quote
its 1992 model and it happens all through the gears
bikerg
PostPosted: 19:44 - 19 Feb 2008    Post subject: Reply with quote
Have you had it "de-restricted" or have the servo kit fitted?
I had a TZR a while back, and had a similar problem.
Check there are no leaks from the powervalve covers (will be a blackish fluid if it is).
Check the reeds for damage too.
nipper2803
PostPosted: 21:24 - 19 Feb 2008    Post subject: Reply with quote
i was told by a bike mechanic that it is de restricted, it doesnt have a servo kit on it. The was like oil comeing out of the cover but it has stopped and the reeds are brand new.
bikerg
PostPosted: 21:39 - 19 Feb 2008    Post subject: Reply with quote
The powervalve covers shouldn't leak at all.
Does your bike accelerate up to 6k faster than it used to? If so then the powervalve has moved.
Check the airbox isn't blocked and that the filter is clean.
nipper2803
PostPosted: 09:31 - 20 Feb 2008    Post subject: Reply with quote
i have sorted out the leaking, the air filter is new, no blockages, it accelerates at the same speed even though we have tried moving the powervalve. i am going to have a good fiddle with the bike and i will let you know what i come up with if anything.
nipper2803
PostPosted: 11:13 - 20 Feb 2008    Post subject: Reply with quote
i had a play and then took it out for a ride, i got it to 9000rpm in 1st gear. when i went to second and it got to 7000rpm it felt like the bike didnt want to go past it as it was shuddering. i changed the plug and still the same. air filter is fine carb is fine.
nipper2803
PostPosted: 14:21 - 20 Feb 2008    Post subject: Reply with quote
its all sorted, dont know what i did it just started going better. thanks for all your help.
The last post was made 18 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.54 - MySQL Queries: 13 - Page Size: 57.25 Kb
