Can you weld chrome?
PostPosted: 18:15 - 24 Feb 2008    Post subject: Can you weld chrome? Reply with quote
Could you weld this?
I'm planning on making a rack for my scooter so things are easier to carry round. The tubing used on this wine rack is the perfect size so I thought I could hack it up weld it together so that it will fit my scooter.
If it's not possible where could I buy some tubing?
cestrian
PostPosted: 18:30 - 24 Feb 2008    Post subject: Reply with quote
No. Chrome plating is done after the rack is put together. Unless it's only screwed together. You need to make yourself a rack, then take it somewhere to be chrome plated.
Ariel Badger
PostPosted: 18:50 - 24 Feb 2008    Post subject: Reply with quote
That steel that will be made from is far too thin. I would think it would be about 1mm you need 3mm wall thickness.
PostPosted: 19:04 - 24 Feb 2008    Post subject: Reply with quote
Where could I get some steel tubing that is 3mm thick?
virus
PostPosted: 19:12 - 24 Feb 2008    Post subject: Reply with quote
thats really not suitable but yes you can weld chrome with a mig, it just spits like a bitch untill you get through the plating, on the other hand you could grind the plating back.
best place for steel tubing = engineers places, ask to raid the offcuts bin.
John
own: 81 xs1100g...
colin1
Captain Safety
PostPosted: 19:48 - 24 Feb 2008    Post subject: Reply with quote
Personally, I think it would be a better idea to either get a rack made for your scooter, or get one that you could modify to fit your scooter.
Ebay is a good place to start.
PostPosted: 19:54 - 24 Feb 2008    Post subject: Reply with quote
When I bought my scooter there were 2 brackets hanging down which I assume is for a rack. As my scooter was in a breakers yard though (Cat D write off) so someone probably bought the rack.
I've had a look on ebay and I can't find one for my scooter and I've looked at modifying one but I think it will be harder than just getting some steel tubing, welding it so it will fit and then spraying it with some black paint.
colin1
Captain Safety
PostPosted: 19:59 - 24 Feb 2008    Post subject: Reply with quote
if you do a whole rack from scratch there is more to do than if you just bake adapting bracket things that can support a rack not designed for your scooter
often with scooters, one is like another with a different name.
it might be worth finding out if other ones with the same name have racks available on ebay
PostPosted: 20:28 - 24 Feb 2008    Post subject: Reply with quote
Here is my design I just made in paint.
https://i15.photobucket.com/albums/a376/ms51ves3/Rackdesign.jpg
That's is what I am looking for. I just think with a bit of tubing it will be pretty easy to make.
colin1
Captain Safety
PostPosted: 21:18 - 24 Feb 2008    Post subject: Reply with quote
yeah, maybe. have u done any welding before ?
PostPosted: 22:27 - 24 Feb 2008    Post subject: Reply with quote
I was going to get my dads mate to do it as I don't have a welder and he does.
I was going to get the tubing, cut it to size then ride my scooter to his house and get it welded, fit it and back home.
colin1
Captain Safety
PostPosted: 00:06 - 25 Feb 2008    Post subject: Reply with quote
sounds like a good plan
PostPosted: 00:23 - 25 Feb 2008    Post subject: Reply with quote
Thank you.
Lets just hope it works Cool
Ariel Badger
PostPosted: 08:42 - 26 Feb 2008    Post subject: Reply with quote
Of course you can weld metal far thinner than 1mm, that was not my point. A bike rack made of metal that thin would last about as long as a Lifan in the TT.
PostPosted: 09:17 - 26 Feb 2008    Post subject: Reply with quote
the warped one wrote:
Ok lets just clairify you can weld thinner than 1mm i've done it and its a bitch to do, you must have exactly the right amps. Trust me i was a welder. Secondly forget MIG go TIG then you can use very little wire and the torch to 'burn in'. TIG is alot neater, if its crome and you MIG it will rust on the first rain. Sand off the crome as the less stuff in the way for imperfections to occour. And decent crome plating costs a bomb go powder coat.
As i stated i was a welder (for Alstom)
cheers
Warped
I'm using what ever welder my dads friend has. I'm not bothered if the welds aren't neat. It's for praticality, not looks.
Kal
PostPosted: 17:32 - 26 Feb 2008    Post subject: Reply with quote
Now you've done it now...
You've set off my perverse nature and sense of humor...
Kal...
colin1
Captain Safety
PostPosted: 18:49 - 26 Feb 2008    Post subject: Reply with quote
that really does depend on what he's gonna use the rack for, but i would agree it would be more sensible to use thicker tubing than improvise something from a wine rack when for the same price he could get a rack deisgned to use on some other bike that he could improvise to fit his.
He has his idea, he wants to make it work, let him try it and he'll just have to be careful he doesnt overload his winerack based rack.
SoND
PostPosted: 19:33 - 26 Feb 2008    Post subject: Reply with quote
You can't weld chrome.
If you try and weld 1mm chromed pipe to support luggage on your bike, you fail.
His idea is a bad idea and dangerous.
Forget that pos wine rack and buy some solid mild steel bar and make it from that.
PostPosted: 01:10 - 27 Feb 2008    Post subject: Reply with quote
I'm not going to use the winerack anymore. I'm going to do what Virus said and go to an engineering shop and look through the cut offs bin.
If I can't find all the metal I need in the bin could I buy some steel tubing off the engineer?
ZRX61
Victor Meldrew
PostPosted: 05:21 - 27 Feb 2008    Post subject: Reply with quote
Ok lets just clairify you can weld thinner than 1mm i've done it and its a bitch to do, Warped
it's fairly easy once you master running tig beads across a sheet of tinfoil.. Wink
The last post was made 18 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.64 - MySQL Queries: 13 - Page Size: 110.18 Kb
