| MillaMeter |
 MillaMeter Nova Slayer
| Ichy |
 Ichy World Chat Champion
 Posted: 09:22 - 23 Feb 2008 Post subject: |
ummmm. Now clutch rattle is very common, I think Kawasaki build it into all their bikes . Mine sounds like its going to self destruct if I don't start it for a few days. Sounds fine at around 2k+ rpm. Usually its worth checking the carb balance first to see if this quietens it down. Try cleaning and lubing the clutch cable to see if the gear change is any better.
Occasionally the start clutch bolts can work a bit loose and rattle about. Goes quiet at above about 3k rpm.
Don't know if your engine is the same but some Kawasaki engines don't have a tensioner on the primary chain. This can flap about a bit at low revs. Not much you can do about that though.
Grinding noise? You sure? That's a bit more worrying. |
| satans_BIG_helper |
 satans_BIG_helper Nearly there...
 Posted: 11:47 - 23 Feb 2008 Post subject: |
General problem with kawasaki's everyone i have owned/ridden has done it, if it is a bit worrying for you i would get the cam chain checked and possibly changed, and maybe strip down the clutch buy a set of new plates and springs and fit them also a new cable at the same time, but the rattle was there on my 750 H2 and never affected its performance or caused any problems for me |
| MillaMeter |
 Posted: 13:39 - 23 Feb 2008 Post subject: |
| satans_BIG_helper wrote: | the rattle was there on my 750 H2 and never affected its performance or caused any problems for me |
Exactly the same with my zxr, the rattle is there, but doesn't effect it's handling, acceleration etc...
When starting the bike it sounds like the engine is growling at ya like a very angry grizzly bear that has a very empty belly, but as soon as I pull in the clutch, the engine is well.... music to my ears (sounds gorgeous and smooth)
Because the bike was bought from a twat ed, I think I'll go ahead and buy a whole new clutch system for her as I have no idea what the previous owner has done and/or changed on the bike.
| Ichy wrote: | Sounds fine at around 2k+ rpm. Usually its worth checking the carb balance first to see if this quietens it down. Try cleaning and lubing the clutch cable to see if the gear change is any better.
Occasionally the start clutch bolts can work a bit loose and rattle about. Goes quiet at above about 3k rpm. |
Thanks Ichy, I'll try and check the carbs today if it's nice today, and I may just buy a new clutch cable as the 1 that's on there now seems to be rather stiff. (I have no cable lubing tool )
And blast! I just done a oil change on her so I can't really strip the clutch down to find out if any bolts are loose. Soon as she needs a oil change, I'll check everything out then.
Nice 1, and thanks guys  ____________________ Currently Own:
2010 Kawasaki ZX6R RAF Performance Edition / 2008 Kawasaki Ninja 250 K8F |
| MillaMeter |
 Posted: 19:47 - 24 Feb 2008 Post subject: |
Ok, the carbs are now balanced and the rattle still remains there. Now i would strip the clutch down but not knowing what the problem might be, it means buying new oil with money i don't really have. And not to mention not knowing how long it'll take to fix, i need the bike 4 work.
any ideas anyone? As the bike doesn't sound very pretty sitting at the lights  ____________________ Currently Own:
| Ichy |
 Posted: 20:02 - 24 Feb 2008 Post subject: |
You could always drain the oil and put it back after?
The thing is that if you do find anything wrong are you going to have the money to repair it? Your may need to replace the clutch gasket for starters.
Remember its a common fault which in many cases is not likely to cause any problems. To attempt to resolve it your may be looking at replacing the plates, bearings,springs and the basket, I was told that normal wear in the basket causes most of the rattle, no idea how true this is, I chose to ignore it. It ain't cheap. If you take it all to bits and can't find anything obviously wrong what are you going to do?
Does it sound any better if you bump the tickover up by 100rpm?
If you think yours sounds bad at the lights then you should listen to a Ducati.  |
| Ichy |
 Posted: 20:14 - 24 Feb 2008 Post subject: |
Oh yeah, forgot to mention. If you take the oil filler plug out with the bike running you can pretty much confirm that its the clutch rattling.  |
| The Tot |
 The Tot World Chat Champion
| crphillips |
 crphillips Borekit Bruiser
There is a gap of 1 year, 327 days between these two posts... |
| ninja-man |
 ninja-man L Plate Warrior
| andys675 |
 andys675 World Chat Champion
The last post was made 16 years, 287 days ago. Instead of replying here, would creating a new thread be more useful? |
