Question about the fuel tap thing
Trylski
PostPosted: 20:20 - 24 Feb 2008    Post subject: Question about the fuel tap thing Reply with quote
Is it going to damage my bike if I leave the fuel tap thing turned on to main all the time? (The switch between main tank, reserve tank and off).
Ghost
PostPosted: 20:23 - 24 Feb 2008    Post subject: Reply with quote
Dunno but mine leaks if I don't set it to off Crying or Very sad I need to have a look at it.
Stegsie
PostPosted: 20:59 - 24 Feb 2008    Post subject: Reply with quote
The off setting is there for a reason.....
If you are leaving the bike for any length of time - use it.
MaybeGuy
PostPosted: 21:02 - 24 Feb 2008    Post subject: Reply with quote
the off setting is there for a reason, i agree...
its to stop fuel pissing out when you take the tank off Rolling Eyes
if it leaks out when its on, then somethings wrong...
no harm in not turning it to off all the time.
deanoet
PostPosted: 21:24 - 24 Feb 2008    Post subject: Reply with quote
If left on over a long period of time it can drip a bit of petrol into the engine, which can cause corrosion.
Not sure if it is true or not, but for how long it takes to flick it to off if it is to be left for a while.......
It cant be a major problem as some bikes dont have a tap at all.
truslack
PostPosted: 22:08 - 24 Feb 2008    Post subject: Reply with quote
Don't those have a vacuum tap instead?
iooi
PostPosted: 22:15 - 24 Feb 2008    Post subject: Reply with quote
I would turn it off, purely from the point of view that if you don't the dammed things can sieze up and when you need to get it over to reserve in a hurry while on the move.... You can't.....
Trylski
PostPosted: 22:36 - 24 Feb 2008    Post subject: Reply with quote
cheers for the replies guys. ill switch it off when im done on it for the day.
Kal
PostPosted: 02:39 - 25 Feb 2008    Post subject: Reply with quote
Fuel to Off is part of my shut down ritual, and fuel On is part of my start up.
Unless I do it everytime I occasionally forget Embarassed Embarassed
Kal...
Trylski
PostPosted: 08:41 - 25 Feb 2008    Post subject: Reply with quote
I forgot it was off yesterday. got round the corner and the engine just spluttered and died. I instantly knew it was the fuel switch. but i had to bump start it up hill cos my battery is getting low... Sad
iooi
PostPosted: 09:31 - 25 Feb 2008    Post subject: Reply with quote
Usually just flicking it on while still on the move will get you running again, without the need to stop.
Why bump up hill.... Just turn round and use the slope the other way Laughing
Finglonga
PostPosted: 13:49 - 25 Feb 2008    Post subject: Reply with quote
Never ever turned the fuel tap to off with any of my bikes unless I was removing the tank.
If you are leaking petrol with it left on for any period then there is a problem that needs to be fixed. It is not normal on any bike to leak with the tap left to on or reserve.
Andy Sez....
F.Y.Y.F.F.
Jaloopa
PostPosted: 21:41 - 26 Feb 2008    Post subject: Reply with quote
I don't turn mine off overnight, but I would if I wouldn't be riding for a week or so.
Re: switching it while moving. I wouldn't want to try that. Maybe my tap's in a funny place but I have to lean over and look down for too long to want to try it on the move. I always pull over and switch off before moving it.
mattsprattuk wrote: but at least the lifan could do like 104mph in 3rd gear
The last post was made 18 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.38 - MySQL Queries: 13 - Page Size: 77.13 Kb
