missfiring speedfight 100
drwizz
PostPosted: 22:31 - 25 Feb 2008    Post subject: missfiring speedfight 100 Reply with quote
hi my first post and its a question "typical"
we just bought our son a peugeot speedfight 100 off a mate "cheap"
he was using it for a bike to commute to work but one day it got left out and got SOAKED through.......
now the bike is missfiring according to my friend ,.....
he said hes spoken to a friend and they rekon its the ECU do the speedfight have this issue or am i being lead down a wrong way path ???
any help and advice on possibly fixing this problem would be really great as my boys currently got no transport for work after crashing his old bike neos 50 that now wont start neither Smile
thnx in advance
Ichy
PostPosted: 22:48 - 25 Feb 2008    Post subject: Reply with quote
It may be the ECU, just as likely the coil, plug, or leads.
The ECU will dry out nicely, if it is wet, in an airing cupboard or next to a hot water tank. Once you've got it sorted and reconnected spray it all with WD40 or ignition sealant.
Just give the plug and lead a good clean to see if it helps. Once again, when its all dry spray it with WD40 or ignition sealant.
boiboi
PostPosted: 08:26 - 26 Feb 2008    Post subject: Reply with quote
Just a heads up. Speedfights use CDIs, not ECUs
drwizz
PostPosted: 17:06 - 26 Feb 2008    Post subject: Reply with quote
sorry if im stupid but whats the diff ?
Cigaro
PostPosted: 17:20 - 26 Feb 2008    Post subject: Reply with quote
'ECU' = Electronic Control Unit - generally a little computer that runs fuel injection, ignition, etc.
CDI = Capacitor Discharge Ignition, which as you can probably guess is only responsible for sparking at the right time.
I'd agree that it's the plug leads.
drwizz
PostPosted: 17:00 - 01 Mar 2008    Post subject: Reply with quote
this bike gets even weirder
so missfiring
but NOT when then headlights are turned on yeah i know what lol
but true if the headlights are off it splutters but if they are on its sweeeeet any ideas ??
Cigaro
PostPosted: 14:51 - 02 Mar 2008    Post subject: Reply with quote
Odd. I suppose it could be the battery, or the regulator.
I would imagine that when the headlights are on they would act as a 'ballast' smoothing out the power going to the ignition system.
I might be talking out of my arse though.
The last post was made 18 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 50.32 Kb
