sv650s speedo
nsr_rory
PostPosted: 00:03 - 28 Feb 2008    Post subject: sv650s speedo Reply with quote
i have bought an sv650s but unfortunately the speedo isn't working. the rev counter and all the warning lights are working fine. i asked somebody and was told they dont have speedo cables so i am very worried now.
please could somebody advise me as to how to check this to find out what is wrong.
thanks in advance
hmmmnz
PostPosted: 00:18 - 28 Feb 2008    Post subject: Reply with quote
https://www.suzukisv.hu/karbantartas.htm
there is sv manuals on the bottom of that page,
you have a speedo sensor with 3 wires, any one of them could be damaged, or the sensor itself
the humans are dead
I kick arse for the lord
nsr_rory
PostPosted: 00:48 - 28 Feb 2008    Post subject: Reply with quote
thanks
ive had a look at the manuals and they tell you how to disconnect the clocks but dont tell you anything about faults with it.
where would the sensor be situated and how would i test to see if its working ?
hmmmnz
PostPosted: 07:08 - 28 Feb 2008    Post subject: Reply with quote
The SV-650 uses a sensor that sits on the axle of the front wheel
there should be a wire coming up, Orange/red= Vsupply, Black/white= ground, Pink= signal
the humans are dead
nsr_rory
PostPosted: 09:16 - 28 Feb 2008    Post subject: Reply with quote
theres no wires coming up at all from the front. there is only that brake hoses. i have looked to see if there is a sensor there but i cant see anything
Louise
PostPosted: 09:38 - 28 Feb 2008    Post subject: Reply with quote
I had the same problem. Look at the front wheel, where the bolt sits right in the middle that black round thing (Good use of words here Rolling Eyes ) is the sensor.
Go good SV650 forum, (cant member off top of my head) and ask in the wanted section for the speedo sensor. I got one cost £20 Thumbs Up
nsr_rory
PostPosted: 11:03 - 28 Feb 2008    Post subject: Reply with quote
thanks for that.
should there be a wire there then that connects to that ?
how is it supposed to work ?
hmmmnz
PostPosted: 20:42 - 28 Feb 2008    Post subject: Reply with quote
got be be a wire Very Happy is not bluetooth enabled yet Very Happy
i only have a diagram and it shows that its connected Very Happy
you might want to take off the front of you bike and look at the wires coming from he dash and look for a cut wire
the humans are dead
husky
PostPosted: 15:03 - 29 Feb 2008    Post subject: Reply with quote
if its a curvy sv mate the rotor inside the speedo sensor is broke-go to robinsons foundery website and order a new one-part number-34983-21E00-delivery is very quick -just take your time refitting it or it'll break again.
husky
nsr_rory
PostPosted: 10:46 - 01 Mar 2008    Post subject: Reply with quote
ive got a problem. i have gone out to the bike and where the forks meet the wheel and the axel piece goes through holding the wheel on there is a hole all the way through so you can see through the center of the axel. there is no wires there at all for a speedo.
the bike has been modified and has got gsxr front forks on but i am not sure what model they are from.
what do i do now ?
Louise
PostPosted: 11:52 - 01 Mar 2008    Post subject: Reply with quote
Are you sure the wire is not tucked away? IIRC it was a bit of a struggle to get mine sorted, with the wires ect.
Maybe he didnt have a speedo? In that case the wire would start just under the fuel tank. Look there to see if there is a connector type thingy which could be attached to something else.
hmmmnz
PostPosted: 13:18 - 01 Mar 2008    Post subject: Reply with quote
so you have gsxr forks, why didnt you say that at the beginning, Rolling Eyes
you will have to buy a magnetic pick up, (like what you use on door sensors for alarm systems) but for automotive use, and get 4 small magnets and mount them to the wheel/disc, where the sensor can pick them up and then wire it back to the clocks
https://www.magsensors.com/vss.html you need a hall effect or reed that sends 4 pulses back to the clocks.
basically any reed type switch should work
the humans are dead
There is a gap of 1 year, 54 days between these two posts...
McGee II
PostPosted: 17:45 - 24 Apr 2009    Post subject: Reply with quote
I Gots me an '07 SV, if you havent seen the thread about me fucking it up, well, i fucked it up.
I managed to acquire some '03 forks, but is there a difference between the size of the speedo, or the forks or something because it wont go back right, help!
As for nsr-rory, I was planning on fitting some gixxer forks but was told it was more trouble than its worth, but it is possible to get it to work.
McGee II
PostPosted: 17:47 - 24 Apr 2009    Post subject: Reply with quote
I just realized that this thread is old as shit! never mind, lol
The last post was made 16 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 81.71 Kb
