| 19van71 |
 19van71 Spanner Monkey
 Posted: 00:19 - 01 Mar 2008 Post subject: Cg125 oil?? Why NOT synthetic? |
HI all,
Just read this post (it's old I know), but it recommends NOT using synthetic oil in a CG125. Does this include synthetic oil made for motorcycles?
https://www.bikechatforums.com/viewtopic.php?t=133559&highlight=cg125+oil
Thanks in advance  ____________________ Living the dream....on my little 'ol CG125  |
| Ichy |
 Ichy World Chat Champion
| Dalemac |
 Dalemac World Chat Champion
| 19van71 |
 Posted: 00:38 - 01 Mar 2008 Post subject: |
Great!!
Anyone want to buy a 2 litre bottle of FULLY SYNTHETIC 5w40 oil??  ____________________ Living the dream....on my little 'ol CG125  |
| 19van71 |
 Posted: 00:40 - 01 Mar 2008 Post subject: |
| Robby |
 Robby Dirty Old Man
| 19van71 |
 Posted: 00:56 - 01 Mar 2008 Post subject: |
Don't tell potential buyers , but the oil only cost me a fiver anyway  ____________________ Living the dream....on my little 'ol CG125  |
| Ichy |
| Robby |
 Robby Dirty Old Man
| Kickstart |
 Kickstart The Oracle
| Bezzer |
 Bezzer World Chat Champion
| Ichy |
| Billd |
 Billd Nova Slayer
| 19van71 |
 Posted: 01:14 - 01 Mar 2008 Post subject: |
| Ichy |
| 19van71 |
| Ichy |
| 19van71 |
 Posted: 01:34 - 01 Mar 2008 Post subject: |
| stinkwheel |
 Posted: 03:04 - 01 Mar 2008 Post subject: |
You should beware of synthetic oil!
It can do terrible things to you and your bike. It will not only leak out of your engine faster than you can put it in, but it will also cause your oil filter to clog and implode, dumping debris and dirt into your lubrication system. It also will make every part of your bike permanently slippery because of its linear molecular chain dispersion action.
Then it will leak onto your kickstand causing it to retract automatically, dropping your bike on the ground! But that's not all... Synthetic oil will round off your gears and spin your bearings. It will also splatter onto your seat causing your girlfriend to fall off in the apex of a turn and she'll never ride with you again. Synthetic oil coats your sight window and your timing window with a whitish pro-emulsification additive that is both non-removable and highly corrosive. Synthetic oil will completely leak out onto the ground overnight and your dog will drink it and die.
Synthetic oil will wear out your tires and make your battery leak. It will give you the desperate need to urinate after you put your full leathers on and then jam your zippers shut. It will contaminate your gasoline causing your bike to stall on railroad tracks and accelerate uncontrollably near police cars. It will make it rain during rallies and on weekends. It will lubricate four timing belts causing them to jump teeth and break your valves to bits. Synthetic oil chemically weakens desmodromic valves and causes the clearances to change every six miles. Then it melts the black soles of your riding boots at night before you walk across your new carpeting.
While riding past groups of attractive women it will cause both of your handlebar grips to slip off at the same time so you smash your windscreen with the bridge of your nose. It also causes your swingarm to crack, your studs to break, and your rotors to warp, and then it voids your warranty by changing your odometer reading to 55,555. It also dries out your wetclutch and wets your dryclutch. It makes your clutch slave cylinder seal fail in the heaviest traffic on the hottest day of the year while putting an angry wasp in your helmet for good measure.
Synthetic oil hides your 13mm socket and puts superglue on your earplugs. Synthetic oil will scratch your faceshield and make your gloves shrink two sizes night before trackday. Synthetic oil will steal your neutral and sell it to the Chinese for £1.25.
So let's be careful out there! ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| kingsknight |
 kingsknight World Chat Champion
| 19van71 |
| 19van71 |
 Posted: 10:04 - 01 Mar 2008 Post subject: |
You forgot about the backward compression stroke - Synthetic oil will make your bike suck in air through the exhaust, causing a backward compression stroke. This will blow high pressure gases through the carb and up the fuel lines, blowing the filler caps off and spraying all your fuel out the tank and oil out of your engine!  ____________________ Living the dream....on my little 'ol CG125  |
| Robby |
 Robby Dirty Old Man
| Pete. |
 Pete. Super Spammer
| 19van71 |
 Posted: 11:49 - 02 Mar 2008 Post subject: Synthetic oils |
Thanks everyone for your input(s).  ____________________ Living the dream....on my little 'ol CG125  |
The last post was made 18 years, 48 days ago. Instead of replying here, would creating a new thread be more useful? |
