Stripping my Exhaust system to bits.
gmanxiii
PostPosted: 19:58 - 02 Mar 2008    Post subject: Stripping my Exhaust system to bits. Reply with quote
Right ive taken off the whole of my exhaust system off my NC30 and removed the front downpipes from the system. Ive noticed theres some melted wirey type stuff in there. Checked the microfiche and it has it down as "packing, muffler" see part number 11 in the diagram. Is this just a gasket? or something else. Is it reusable?
I kills hondas
VFR400NC30 > ZZR600 > CBR600FX > CBR1000rr
finpos
PostPosted: 21:11 - 03 Mar 2008    Post subject: Reply with quote
It'll be basically a fat, malleable gasket. Whether or not you can re-use it depends on the state it's in. "Melted" doesn't sound promising Smile
f.
gmanxiii
PostPosted: 21:14 - 03 Mar 2008    Post subject: Reply with quote
Haha cheers, i forgot i posted this in help.
Yeah its pretty melted, ive just ordered a couple replacement they aint cheap i tell you.
I kills hondas
Whosthedaddy
PostPosted: 21:15 - 03 Mar 2008    Post subject: Reply with quote
The gasket on the monkey's exhaust sounded like something similar. Does it look like a slinky if pulled a part?
The replacement gasket was more like a large copper washer.
gmanxiii
PostPosted: 21:17 - 03 Mar 2008    Post subject: Reply with quote
Nah i started picking at it and it crumbled, underneath was like wire wool, took me ages to scrape it out. Its a type of gasket apparently. Cheers anyway Thumbs Up
I kills hondas
Whosthedaddy
PostPosted: 21:19 - 03 Mar 2008    Post subject: Reply with quote
Ahhh, my bad.
Picking at stuff is aways fun.
Dalemac
PostPosted: 23:11 - 03 Mar 2008    Post subject: Reply with quote
yep, its like wire wool but thicker and shaped around the exhaust fitting.
Had you got a screwdriver under it you could have loosened it and slid it off, shouldnt take more than a couple of minutes!
YBR125 -> GPZ500S -> SL1000
gmanxiii
PostPosted: 10:36 - 04 Mar 2008    Post subject: Reply with quote
Took my like half an hour to do one! Razz it seems to have partially bonded with the inside of the pipes
I kills hondas
Dalemac
PostPosted: 16:32 - 04 Mar 2008    Post subject: Reply with quote
lol maybe they were the original ones?!
Apparently should be replaced every 18 months or so....
gmanxiii
PostPosted: 16:55 - 04 Mar 2008    Post subject: Reply with quote
Blimey those did look like they had been there for about 16 years...
I kills hondas
Itchy
PostPosted: 18:04 - 04 Mar 2008    Post subject: Reply with quote
why? , every time you change your exhaust you should change them since they fall apart but why would you need to change them on an 18 month basis? .
ie its not a moving part , its not a particularly stressed part and it only falls apart when you try to remove it, as the pressure from the pipes resting against it and or the clamps hold it together and seeing as the '30 has stainless as std it will very rarely need replacement.
The last post was made 18 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 70.98 Kb
