Bump starting a bike - was I kidding myself?
Polo
PostPosted: 09:00 - 08 Mar 2008    Post subject: Bump starting a bike - was I kidding myself? Reply with quote
Can you bump start a Fireblade in a short space? I managed to push the bike, after flattening the battery before realising I needed to switch to reserve, out of the Croydon Underpass into Fairfield Halls car park.
Have circled the area I was trying to do it - but failed. Fortunately, as I had just left work 200m away, I rang a mate and he came and gave me a push.
Was it ever a possibility to do it on my own? Or do you need a slope and more space to stand a chance? Each time I tried it, the back wheel locked up - 1st, 2nd or 3rd gear.
My mum smells your fingers
Jenks
PostPosted: 09:40 - 08 Mar 2008    Post subject: Reply with quote
you could have done it , it just takes some serious effort.
Tends to help if you run next to it and jump on the seat hard.
1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi
Polo
PostPosted: 10:05 - 08 Mar 2008    Post subject: Reply with quote
I did try that but the engine would maybe turn twice, three times tops if you see what I mean.
At least I know it can be done - cheers. Thumbs Up
KLR600
PostPosted: 10:38 - 08 Mar 2008    Post subject: Reply with quote
I've found when bump starting bikes that it takes few times for them to "warm up" (probably not whats happening though but that's the easiest way to explain it) but it gets easier the more times you try. Of course you also get more tired with each time but I used to be able to bump my old KLR and my XJ in about 15ft worth of space before I get the ZRX.
<Take Cool Photos!>
Finglonga
PostPosted: 11:13 - 08 Mar 2008    Post subject: Reply with quote
If I can bump start an 1150GS then a Fireblade will be a piece of pi$$, you need to practice for next time you need to do it again. Wink
Andy Sez....
F.Y.Y.F.F.
Cigaro
PostPosted: 11:20 - 08 Mar 2008    Post subject: Reply with quote
You need to put as much weight as possible on the seat when you jump on, as having enough weight over the rear wheel will ensure the wheel doesn't lock and give you enough momentum to start the engine. Also helps if you are in a higher gear, 2nd or 3rd for instance.
Ben.
PostPosted: 11:54 - 08 Mar 2008    Post subject: Reply with quote
i cant bump start my sv Embarassed is it harder with v twins?
follow my racing season
Race bike - R6
Road bike - sv650
PostPosted: 12:21 - 08 Mar 2008    Post subject: Reply with quote
I could bump start my downgeared zx9 that some headwork done (definitely /felt/ like high comrpession ratio Smile ).
Technique:
Run along beside bike until you get a decent speed up, jump on to seat. If your clutch is working good, do it wit the clutch in and dump clutch as you land on seat.
If you've got to run with it in neutral, either knock it down as you land, releasing the clutch as your weight gets on it. Or get on the bike knock it down with the clutch in, then stand up and drop down onto the seat, releasing the clutch as you drop down.
SV should be fine - bigger V-twins may be more of an issue, but there are many other factors.
Polo
PostPosted: 15:35 - 08 Mar 2008    Post subject: Reply with quote
Many thanks, chaps. Thumbs Up
M1ghtyDUck
PostPosted: 16:54 - 08 Mar 2008    Post subject: Reply with quote
Fairfield Halls? Might be a bit of effort/tight squeeze, but if you could fit it down the underpass there's a pretty decent long slope down there. It's long and straight over the other side. Might not really be feasible but hey, it's an idea if you're really stuck.
Method
PostPosted: 17:22 - 08 Mar 2008    Post subject: Reply with quote
I have to bump start all my race bikes, its not hard.
Theres a knack to it, like all things.
Run along next to it, get some momentum up, jump on the seat and drop the clutch at the same time!
Now - this is where most people end up ruining their chances... Dont stay on the seat - whats that going to acheive? Hop back off and keep pushing it, being very easy on the throttle. You will hear it pop and feel it jump forward a little bit as it splutters, then its just a case of feathering on slowly small bits of throttle untill it catches.
When it catches, yank the clutch in, keep it revving and jump back on it. Ride it to a stop and put it into neutral.
Simple as.
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
Madmanx
PostPosted: 17:25 - 08 Mar 2008    Post subject: Reply with quote
Practice it one day when you have time.
Then you'll know how to do it when in need. Thumbs Up
https://i284.photobucket.com/albums/ll9/manxhornet/Hornet001.jpg
geordiecbrblo...
PostPosted: 18:17 - 08 Mar 2008    Post subject: Reply with quote
Done it a few times on my old (heavy) CBR600, 2nd gear, push it along, let clutch out and she started.
This was on the flat within about 3 car lengths, so no great build up or need to jump on to the seat.
map
Mr Calendar
PostPosted: 21:05 - 08 Mar 2008    Post subject: Reply with quote
Old carb bikes should be ok to bump but I was told not to even try with injection bikes.
Can anyone clarify?
Sparks!
Sir Tart-a-lot
PostPosted: 21:07 - 08 Mar 2008    Post subject: Reply with quote
I could do it in a shorter space....
unfortunately had a lot of practice with my CBR6 Laughing
Fawbish
PostPosted: 21:24 - 08 Mar 2008    Post subject: Reply with quote
can bump start my zx6 in about ten feet, and i only weigh ten stone Thumbs Up
I assume a thou would be a bit harder though
But i know big v-twins are a right bastard! My mates TLR, we tried loads and the back wheel just locked up every time, with both of us pushing Shocked
iooi
PostPosted: 10:32 - 09 Mar 2008    Post subject: Reply with quote
Can anyone clarify?
Most likely to do with the fact that they require power to squirt the gas, which due to a flat battery and the lack of cranking speed on the altenator isn't there.
Method
PostPosted: 11:39 - 09 Mar 2008    Post subject: Reply with quote
iooi wrote:
Can anyone clarify?
In theory i would imagine you are right.
However it has been done, and is possible. You have to remember that it is very rare for a battery to be completely flat. It doesnt take an awful lot to throw enough through to power the injectors etc, and when pushing it - you are turning the generator / alternator and throwing juice into the battery - whether it stays there for long or not. The biggest load on the battery is always the starter switch - if you can get it started, the bike will run on what is coming into the battery from the generator - if the battery is knackered it just wont hold the charge put into it. Remember you are throwing ~ 14volts into a 12v battery to charge it, so with a totaly wasted battery, it basically turns into just another connection in the circuit - flows in and out.
So by pushing it- you are throwing juice into the circuit and thus after a small period of time will have enough flowing through to power everything you need to get it started.
In theory Smile
Dom_
Points Mean Prizes
PostPosted: 11:40 - 09 Mar 2008    Post subject: Reply with quote
I was bump starting my cbr4 everywhere for about a month when the battery was shagged, was only about 9 stone at the time, no problem.
I'm sure i've bump started a fuel injected car though.
JAMSXR
PostPosted: 11:49 - 09 Mar 2008    Post subject: Reply with quote
I managed to do it with my 636 in a space of about 5 meters, i was shocked! My KTM 640 was a different story Rolling Eyes
I think temprature can help, in the middle of winter cold tyres and ice cold roads don't help but on a hot summers day that bit of extra grip will stop the back wheel locking.[/i]
matthab
PostPosted: 12:46 - 09 Mar 2008    Post subject: Reply with quote
thank the lord for kick starts Wink
2005 - 2006:Peugeot jet force 50 TDSI (sold)
2006 - Present: Yamaha YBR125 06 (extras:pilot sporty tyres and screen)
WildGoose
White Van Man
PostPosted: 13:01 - 09 Mar 2008    Post subject: Reply with quote
I seem to remember it being a fair slog to bumpstart a firestorm on a flat road, there were 4 or so of us pushing it, all hungover so probably not giving our best performance, but took more than a couple of goes.
MY CB-1 flattens the battery trying to start it in below freezing temps it just doesn't go. It's worth nothing that if the starter struggles when the battery is healthy, there is not a great deal of chance that you will do better bumpstarting it in the same environment, in my experience.
As has been said the more times it takes, the more you will want to die, particularly in full leathers, so give it everything on the first go, with a view to not needing a second attempt Wink
virus
PostPosted: 13:02 - 09 Mar 2008    Post subject: Reply with quote
managed to bump start an xl600 once, and thats a single cylinder beast, just knock it into second, roll backwards untill its hard to move, thats the start of compression, clutch in, go forwards as fast as possible then dump the clutch.
own: 81 xs1100g...
Peter3hg
PostPosted: 15:39 - 09 Mar 2008    Post subject: Reply with quote
I have tried it on the YBR though and it does it within about 2 feet. You basically just lunge it forward a bit, let the clutch out in second and it goes. This was from cold as well.
c_dug
PostPosted: 00:14 - 10 Mar 2008    Post subject: Reply with quote
I give a big Middle Finger to bump starting!
I was giving my dad a hand with his R1100S beemer and it decided to backfire leaving a nice black mark all over a (nearly) new white shirt Evil or Very Mad and it didnt even start!
Anyways the battery was shagged so he got one of those capacitor things to replace the battery, not sure exactly how it works but it does the job so now no more bumping for us, yay!
c_dug
The last post was made 18 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 132.83 Kb
