| warped one |
 warped one Banned
| NickD |
 NickD World Chat Champion
 Posted: 18:08 - 09 Mar 2008 Post subject: |
You'll be needing this page.
https://www.ratbike.org/rat-tech.html ____________________ I was only doing what it said on my licence officer....
Tear along the dotted line! |
| virus |
 virus World Chat Champion
 Posted: 18:19 - 09 Mar 2008 Post subject: |
you have put a smile on my face today
what do you want out of it?
trailbike?
chop?
general backup bike?
real head turner?
give a bit more info and we can suggest things to do to make it more fit for purpose/ easier maintenance.
Cheers
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| warped one |
 warped one Banned
| virus |
 Posted: 18:51 - 09 Mar 2008 Post subject: |
well ratbikes typicaly evolve, mines been evolving since i got it, i only had it standard for a while before i changed the bars because i couldnt get on with them, then i go into trail riding and it went from there.
methinks your looking for a ratfighter or a chop
where do you want the back end to go? up or down?
cheers
| matthab |
 matthab Crazy Courier
 Posted: 19:34 - 09 Mar 2008 Post subject: |
lol jons face just lit up
Every day i pulled into college Jons bike had somthing else taped to it lol ____________________ 2005 - 2006:Peugeot jet force 50 TDSI (sold)
2006 - Present: Yamaha YBR125 06 (extras:pilot sporty tyres and screen) |
| warped one |
 warped one Banned
| virus |
 Posted: 23:11 - 09 Mar 2008 Post subject: |
pretty easy to bolt a 30 cal tin on as a backrest for a solo conversion, and if you really want to (i.e. you cant be arsed to mount the numberplate next to the swingarm) then you could mount it onto the 30 cal tin, just needs some lighting work ____________________ own: 81 xs1100g...
 Posted: 23:28 - 09 Mar 2008 Post subject: |
I had one .
It wasn't exactly mint but it was all there and in oiriginal condition. Then some wee bastard pinched it, threw away the sidepanels, smashed the headlight and keyed the tank
As I recall I decided the carbs were FAR too worn to be capable of being balanced so I got a 2-1 inlet manifold off a CD125 (or CM125) and made up a single carb using the best looking bits from both of the original ones.
In order for this to fit, I had to remove the airbox and the battery box. I fitted a pod filter on the end of the single carb and bungeed the battery to a little alloy 'shelf' I made lying horizontally across the frame just under the seat (it bolted directly to some of the original captive nuts for the airbox).
I had a rake about in the scrap metal bin at a local garage and pulled out an intact 2-1 splitter box and a length of 1 1/2" pipe with a curve on one end and a flare on the other. I got these welded together and fitted them as the exhaust with a removable baffle (held in place with a wing-nut).
Err. I fitted an old round headlight I had lying about and a set of handlebars off an MTX125. I painted the tank matt black with warped superman logos on the side. I fitted really cheap and nasty trials tyres. I replaced the grab rail with a HUGE sissy bar made out of twisted flat bar so I could "sit" my rucksack on the pillion seat and strap it to the sissy bar. I fitted an ammo box to one side for a toolbox.
Oddly, it ran smooth as a babies arse and carburetted perfectly on the single carb, pod filter and homemade exhaust.
It passed two MOTs in that form.
I have no pictures of it.
EDIT: I also re-covered the saddle by stretching an old, brown leather jacket from a charity shop across the foam and attaching it to the seat base using self-tappers. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| virus |
 Posted: 23:35 - 09 Mar 2008 Post subject: |
was waiting for your wisdom scott
btw, is the jawa still alive?
been browsing through the old RBZ pics today and saw it, in its R+S 04 setup.
Cheers
 Posted: 00:03 - 10 Mar 2008 Post subject: |
| virus wrote: | was waiting for your wisdom scott
Cheers
John |
I consigned it to the back of the lockup (on account of the frame being so bent, I couldn't justify riding it any more). About 12 months later, someone gave me another one. Same model, same year, not bent.
Then the main bearings collapsed. I am currently waiting on the guy up the road putting the crank back together again and balancing it (he's pressed it apart, I've dropped the new bearings in past. He's only had it for three months so far though ).
The old engine had a big-bore top-end and a different gearbox. Basically I'm going to amalgamate the best bits of both bikes into one. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| mr.z |
 mr.z World Chat Champion
 Posted: 00:50 - 10 Mar 2008 Post subject: |
Found out i'll be getting my cb125 back on tuesday yay!
Currently torn between flogging the cx and cb and haveing a 250/350 or just keeping the cb and useing the cx every so often. or the 125 and a 250.. :/
Liking the idea of the single carb though, really appealing that it needs no fiddling, also should it go tits up you have a spare carb ready to go!
Imo The trick to modifying it into something improved is just ride it for a while, decide what you think it could do with then get on with it, or just ride it till bits fall off, tape them back on or find other bits that are to hand to replace them with (be it from a bike, car, boat, tractor), or make them yourself. Both will end you up with something delightfully shitty looking. Theres lots of "rats" that are stock bikes in matt black.. in only special circumstances is this what i would constitute a rat (i.e. a completely stock shiny triumph, matt black = really upset triumph owners club said triumph has evolved more interesting stuff now)
Actually a far rattyer thing would be to use what you didn't use on your liveing room, or your garrage, or your roof.. wrap underlay up and gaffa tape it where your knackered seat was. Sky (or should that be the gutter) is the limmit.
Have plans for mine all thought out (that is if its kept) ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| virus |
| warped one |
 warped one Banned
| Endless Nameless |
 Endless Nameless World Chat Champion
 Posted: 19:07 - 10 Mar 2008 Post subject: |
No advice, but karma given for being the worst paintchop since... well, it's probably just the worst one ever, to be honest
Should look good though  ____________________ A2 passed 22/07/08; restriction up 22/07/10 (just so I don't forget)
'79 Suzuki GS550E. Yes, that's a GS550, not a GS500.
Supersports "In a video editing competition I'd kick your sorry ass" |
| virus |
 Posted: 19:50 - 10 Mar 2008 Post subject: |
blue line will be much better for the exhaust, will require less work and will mean you can still get the side pannel off for maintenance,
keep your eye out in show and tell, just uploading the pics of my cg as a single seater, with a marshall deeptone exhaust set as a high level.
very similar to your plan. ____________________ own: 81 xs1100g...
| mr.z |
 Posted: 21:20 - 10 Mar 2008 Post subject: |
thoughts..
in a crash sort of situation how happy will you be with a big metal box right where your spine is? could be enough to make a bad crash in to something worse 0_o
twin lights, ime your just as well with one, adding another makes allot less difference than you think apart from spread of light and a decent one will cover enough anyway, plus its a 125 it'll be struggling to run two
Car lights are plenty full and cheap and work very well, nath on here has one on his 550 and is very pleased with it.
Johns blue line idea with the exhaust makes allot of sense too, all you'd need to do is get a 40degree angle in there and a bracket and something to make sure you don't burn your leg off..
good luck, keep us posted  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| hellkat |
 hellkat Super Spammer
 Posted: 03:12 - 11 Mar 2008 Post subject: |
Did Urban Terrorist not have a 125 that he farted about with?
I think it was in BSH a couple of years ago.
Look him up on Myspace.
Or am I too far behind this thread already?
Jenny-come-lately  ____________________ Not nearly as interesting in real life. |
| Rowey |
 Rowey World Chat Champion
 Posted: 11:27 - 11 Mar 2008 Post subject: |
I'm thinking of ratting my superdream, at the mo the paint is chipped, scratched and worn. Was thinking dark, army green panels and tank and matt black everything else, so far the wheels, frame and exhausts are. Want to chop the seat and get rid of the airbox and replace with a pair of pod filter, then chuck some canvas panniers over it.
I'm a bit weary though, been told that good working superdreams are becoming quite a collectors piece now, and a good paint job and clean up will make it worth a pretty penny in the coming years.
Might wait untill I can find/afford a dropped, cosmetically shit, 600/500 and chop that. ____________________ ZX6R C6F.
Never argue with an idiot. They'll only bring you down to their level, and beat you with experience. |
| Mudskipper |
 Mudskipper World Chat Champion
 Posted: 11:32 - 11 Mar 2008 Post subject: Re: CB125 Ratbike |
| virus |
 Posted: 12:52 - 11 Mar 2008 Post subject: |
hellkat, it was an ar125 i believe, nice machine.
rowey, to be honest superdreams aren't that valuable, for example i know a breaker who has had 4 in his yard that haven't shifted since ive been going there. a superdream chop would be good, stay away from off-road style though, they're too big and beefy to carry it off.
mudskipper, PICS!!!!!!
Cheers
| warped one |
 warped one Banned
| mr.z |
| Mudskipper |
 Posted: 15:41 - 12 Mar 2008 Post subject: |
The last post was made 18 years, 208 days ago. Instead of replying here, would creating a new thread be more useful? |
