do i wet and dry sand primer?
hmmmnz
PostPosted: 18:31 - 12 Mar 2008    Post subject: do i wet and dry sand primer? Reply with quote
or to i just sand it dry before i start adding colour??
the humans are dead
I kick arse for the lord
Odie
PostPosted: 18:56 - 12 Mar 2008    Post subject: Reply with quote
wet sand is smoother
mad4it028
PostPosted: 18:57 - 12 Mar 2008    Post subject: Reply with quote
rub it back down wet thats what i do
jwet soapy water
hmmmnz
PostPosted: 19:02 - 12 Mar 2008    Post subject: Reply with quote
cheers lads, Very Happy much appreciated Thumbs Up
the humans are dead
tutton
PostPosted: 20:34 - 12 Mar 2008    Post subject: Reply with quote
Wet sanding - less sanding dust as its a slurry as well Smile
although your wet and dry is probably a higher grade. dry papers will be more sensitive, you should probably be using about a 240 to flat primer.
hmmmnz
PostPosted: 21:52 - 12 Mar 2008    Post subject: Reply with quote
im up to 800 between coats of primer, a couple more layers and i should be ready for the colour
the humans are dead
ZRX61
Victor Meldrew
PostPosted: 22:23 - 12 Mar 2008    Post subject: Reply with quote
WAY too fine, won't provide enough key for the colour & increases the chances of paint chipping because there's no mechanical bond.
hmmmnz
PostPosted: 22:45 - 12 Mar 2008    Post subject: Reply with quote
ok sweet. ill go back to a 400 Very Happy
the humans are dead
tutton
PostPosted: 22:46 - 12 Mar 2008    Post subject: Reply with quote
No,
still not enough
you need 180-240 as i said.
if you'd read my post.
i do bodywork as does he.
hmmmnz
PostPosted: 23:47 - 12 Mar 2008    Post subject: Reply with quote
oooh but the 800 was so nice and smooth, Sad
now the 400 seems rough,
and you want me to go back to the 240??
the humans are dead
tutton
PostPosted: 23:49 - 12 Mar 2008    Post subject: Reply with quote
you want to make a good key for the paint to grip to.
so 240 or 180, youll notice it taking primer off, thats good, just take some off all around, and clean it up. the prime is only a undercoat remember, it wont show afterwards.
ZRX61
Victor Meldrew
PostPosted: 23:50 - 12 Mar 2008    Post subject: Reply with quote
Put on multiple coats of primer, wet sand that with 400, & guide coat it or you're just pissing in the wind. Add more primer of needed, guide coat it again.
Final sand with 500 & then put the colour on.
tutton
PostPosted: 23:53 - 12 Mar 2008    Post subject: Reply with quote
In my personal opinion 400 is too fine.
Unlikely hes going to have guidecoat too. seems like a diy job, not a bodyshop Laughing
hmmmnz
PostPosted: 01:19 - 13 Mar 2008    Post subject: Reply with quote
what is a guide coat?? is that just an over spray first??
the humans are dead
ZRX61
Victor Meldrew
PostPosted: 04:58 - 13 Mar 2008    Post subject: Reply with quote
180/240 is for final shaping of filler.
ZRX61
Victor Meldrew
PostPosted: 05:04 - 13 Mar 2008    Post subject: Reply with quote
You're 16, I've been doing this for 30 years.. explain why on earth he's unlikely to have any old rattlecans laying about?
& if he sands the primer with 180/240 his finishe work is going to be full of sand scratches.
Mist coat sprayed on from about 2ft away for contrast when snading to know you got everything sorted.
Any contrasting rattlecan will do as it all ends up on the floor anyway.
hmmmnz
PostPosted: 08:43 - 13 Mar 2008    Post subject: Reply with quote
thought so, cool, Thumbs Up
back to 400 then Very Happy
hehe, lucky ive got lots of time
the humans are dead
tutton
PostPosted: 15:36 - 13 Mar 2008    Post subject: Reply with quote
Weird when we spray over 240 its perfect,
And the guidecoat, seems i know something else to be guidecoat, we use 3M dry guide coat, which is a powder found at the below link
https://www.levineautoparts.com/3mdryguidecoat.html
ZRX61
Victor Meldrew
PostPosted: 18:04 - 13 Mar 2008    Post subject: Reply with quote
I've used that stuff, I just prefer the spray kind.
hmmmnz
PostPosted: 21:28 - 13 Mar 2008    Post subject: Reply with quote
ok overspray on...
next question,
do i wet and dry that and every layer of paint until the clear coat,
and do i wet and dry the clearcote??
the humans are dead
ZRX61
Victor Meldrew
PostPosted: 23:29 - 13 Mar 2008    Post subject: Reply with quote
Get the primer sorted.
Start spraying the colour, & if you don;t get any boogers or runs etc just keep adding coats until you have good coverage with no *holidays*
If you fuck it up just knock back that bit.
Then start adding the clear, get 3 coats on, let it dry 24 hours & then hit it with 1200-1500 wet (obviously if you fuck it up knock it back & go at it again etc)
Throw on another 3 coats & repeat with 1500 wet -> 2000 wet & then buff it out
DO NOT!! use T-Crap.
If you get a REALLY big run, wait til it dries & take it off CAREFULLY!with a file. Saves a lot of buggering about with blocks & sandpaper etc... but smooth it out with 1200-1500 wet before continuing
Ichy
PostPosted: 23:44 - 13 Mar 2008    Post subject: Reply with quote
What do you use for buffing?
ZRX61
Victor Meldrew
PostPosted: 23:54 - 13 Mar 2008    Post subject: Reply with quote
Personally? I use a 9in Dewalt variable speed polisher, start with wool pads, then foam & then finish off with a PorterCable DA with foam pads so the finish has no swirl marks in it...
But that Dewalt has enough power to throw large car parts clear across the workshop if you're not paying attention... With bike parts you need someone to hold em down on the bench.
tutton
PostPosted: 23:56 - 13 Mar 2008    Post subject: Reply with quote
and what compound?
hmmmnz
PostPosted: 01:33 - 14 Mar 2008    Post subject: Reply with quote
ok sweet cheers, 3 thin coats of colour on tonight, looking good so far Very Happy i think ill do another 4 or 5 then clear,
so do i sand between the clears??
the humans are dead
The last post was made 18 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.08 - MySQL Queries: 15 - Page Size: 126.81 Kb
