Think I might have to break my steering lock......
GhostRider
PostPosted: 14:16 - 13 Mar 2008    Post subject: Think I might have to break my steering lock...... Reply with quote
Well, on monday I lost my only set of keys to my motorbike at work.
Have had a locksmith out who attempted to forge a key that would fit the ignition, and whilst he successfully got it to work in the seat cover and petrol cap, after 3 and a half hours it just wasnt happening in the ignition.
He says he'll come back today and probably resort to removing the ignition barrel and either taking it apart and making a key to it or use the key code if its printed on the base of the barrel.
Thing is my steering lock was on, and I dont see how he's going to be able to get to the second bolt in the position its currently in to remove the ignition barrel.
In addition, depending on what time he comes depends on whether the job gets done today, and as a consequence whether my bike spends another night outside which im very against doing as the area isnt the best.
Therefore, Im either going to have to break the steering lock so that he can remove the ignition barrel, or break it anyway to wheel the bloody thing home so at least then I know its safe, if somewhat out of action until I can afford to fix the problem.
What im asking is.... is there a 'proper' way to do this? Im gathering its just a matter of applying enough torque, but I dont want to mess up my bike any further, and any ideas on how much it would cost to replace the steering lock, if at all possible??
GhostRider
the grim reaper
PostPosted: 14:21 - 13 Mar 2008    Post subject: Reply with quote
Do NOT break your steering lock. Depending on the bike, the steering lock will operate in one of a number of ways but most of these involve a rod inserted into the frame by the turning mechanism of the lock.
If you break the steering lock, you risk damaging the frame and even jamming it so that the locksmith has an even more difficult job in trying to get a key to fit.
Far cheaper would be to drill the ignition barrell out or hammer a screwdriver down it and use molgrips to turn the screwdriver like a key would. You'll wreck the ignition but that is cheaper than damaging the frame.
Remember to take your documentation with you in case the Police turn up while you are trying to release your bike. You don't want to end up in a cell for the night.
Grim
GhostRider
PostPosted: 14:26 - 13 Mar 2008    Post subject: Reply with quote
Ahhh ok then,
Im just at my wits end as the locksmith is the only one of about 20 that I;ve called thats actually said he's able to do it, plus its costing me a feckin bomb already, so am kinda getting desperate, hasty and not thinking too far ahead at the moment.
Thanks,
GhostRider
PostPosted: 14:29 - 13 Mar 2008    Post subject: Reply with quote
It only looks like he's nicking a motorbike the police won't care anyway. Unless it's got a small plate/noisy can.
the grim reaper
PostPosted: 14:32 - 13 Mar 2008    Post subject: Reply with quote
GhostRider wrote:
Ahhh ok then,
Thanks,
GhostRider
If you're worried about the bike, get a mate or two, a plank with some rags wrapped round it to protect the wheel paint and just lift the front end up and wheel it somewhere safe.
Alternatively, a strap round the front wheel will do just as well.
Grim
veeeffarr
PostPosted: 03:10 - 14 Mar 2008    Post subject: Reply with quote
- you break steering lock
- the broken steering lock jams back on mid corner
Ben.
PostPosted: 03:24 - 14 Mar 2008    Post subject: Reply with quote
get frame number, etc, take all your documents to a dealer and they should be able to cut you a new key...
follow my racing season
Race bike - R6
Road bike - sv650
NSR Mick
PostPosted: 13:11 - 14 Mar 2008    Post subject: Reply with quote
And once you get it all sorted you'll find your keys. Embarassed Whistle
The last post was made 18 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 58.63 Kb
