nrg slow exelaration problem.!!!help!!!
nrg-mental
PostPosted: 16:43 - 13 Mar 2008    Post subject: nrg slow exelaration problem.!!!help!!! Reply with quote
[b]hi i have just bought i nrg 50 that is 2004 with the digital dash and it came with a fitted leo vince exhaust, the bike does around 45-50 mph easy on the flat and about 60 mph down hill lol. the only problem im having is the exelaration.. it is poor. if i set off from sood still and full rev it revs to 9000 but drops to 7000 till i pick up a little speed then they go to about 9000-10000. how can i inprove exelaration with out redusing reliability?
21 and still on a bloody scooter : (
Proview
PostPosted: 17:23 - 13 Mar 2008    Post subject: Reply with quote
Hi i have found this with some moded scooters they are crap at exelaration but good at top speed im not sure why but some one should know i think it has something to do with back pressure in the exaust but i might be compltetley wrong Embarassed Embarassed
and i would personaly buy a second hand scooter with mods they dont seem to last very long Laughing
Aerox R 50cc 2008 ,Aerox RR 2002, Mbk Nitro 2001, Beta RRT Elf racing series ,1989 Beta trueba Needs fixing
! ! ! -Pat- ! ! !
Gonna wrap a teatowel around the lid nextime..y'know for relgious reasons
nrg-mental
PostPosted: 18:03 - 13 Mar 2008    Post subject: mods Reply with quote
the scooter has only done 3000 miles since new and the exhaust has only been on for the last 200. there are no ther mods..
nrg-mental
PostPosted: 18:11 - 13 Mar 2008    Post subject: 1 more thing Reply with quote
if i put a performance air filter on do i have to up jet it or do any think else?
70m1
PostPosted: 18:51 - 13 Mar 2008    Post subject: Reply with quote
if the only thing that has been done is seriously just a new exhaust then u will need to sort it pronto as it will be running fairly lean, however if the jetting has been changed to suit the zorst then adding some lighter rollers should improve accel
Finglonga
PostPosted: 19:02 - 13 Mar 2008    Post subject: Reply with quote
https://img.photobucket.com/albums/v112/finglonga/Finglonga%20Inc/popcorn.gif
Andy Sez....
F.Y.Y.F.F.
cheekythomas
PostPosted: 19:09 - 13 Mar 2008    Post subject: Reply with quote
First of all the question of jetting is correct... did you fit the exhaust or did a dealer?? Either way was the jetting increased to suit the change of exhaust as if not it will be running lean.
It sounds like it needs some stiffer clutch springs.... chances are its just had light rollers fitted to help mask the race exhaust drop in torque.
Get a set of Malossi springs, about £10 and you get 3 strengths. Black,white and yellow... I would use the try using the black first as you dont want the clutch engaging too high on the standard cylinder and they are normally the ones we end up using.
nrg-mental
PostPosted: 19:14 - 13 Mar 2008    Post subject: Reply with quote
i have e mailed the guy i bought the bike off but he is yet to reply as to wether he up jeted it or not, he gave me original exaust and box. in the box there are 3 small yellow springs ( never used)and a brand new set of rollers, dont know what wait they are but they are orangie and have 3 little dots on???
cheekythomas
PostPosted: 19:20 - 13 Mar 2008    Post subject: Reply with quote
Ah there you go then... he has just put the pipe on and not the springs so the clutch is engaging to soon and not letting the engine get into its powerband so lifting off slowly... also without the lighter rollers fitted it will be changing gear too quickly which is also adding to the problem.
Get them fitted and make sure its jetted right. Wink
nrg-mental
PostPosted: 19:23 - 13 Mar 2008    Post subject: Reply with quote
well thats a job to do for when it stops raining lol, ive done the rollers before but not the springs, thanks alot for your help Surprised Surprised Surprised
nrg-mental
PostPosted: 19:29 - 13 Mar 2008    Post subject: my mistake Reply with quote
the cluch springs are blue not yellow, are you sure these will be the right ones? or would i be better of buying the kit? realy apreciateing your help
nrg-mental
PostPosted: 19:42 - 13 Mar 2008    Post subject: the jet Reply with quote
just found out all the bike has done is the exhaust and he says he remover the restrictor from the exhast aswell....no jet. what size do you recomend and will this reduce the reliability?
cheekythomas
PostPosted: 19:42 - 13 Mar 2008    Post subject: Reply with quote
Colour doesnt matter if they came with the exhaust they will be the right ones... sounds like a Leo Vince ZX you have then.
rezzin
PostPosted: 20:12 - 13 Mar 2008    Post subject: Reply with quote
Its almost definate its the rollers for goodness sake..Either wrong weight,or worn it sounds like. The bike should rev 'the same' all the way to top speed ideally. Thumbs Up
Finglonga
PostPosted: 22:05 - 13 Mar 2008    Post subject: Reply with quote
nrg-mental, pray tell how the feck is that abusive? Rolling Eyes
Andy Sez....
F.Y.Y.F.F.
rezzin
PostPosted: 22:51 - 13 Mar 2008    Post subject: Reply with quote
Jog on p^ss takers. Find something better to do you hardcore forum walkers. Rolling Eyes Thumbs Up
cheekythomas
PostPosted: 21:41 - 14 Mar 2008    Post subject: Reply with quote
Fitted them clutch springs yet... youll be amazed how much difference letting the engine get that extra few rpms higher before it engages actually makes...
...a lot of people dont bother and just mask the problem with stupidly light rollers... but that makes the speed change too slow, and can lead to hesitiation if you shut the power off and then reapply it, most often noticed at roundabouts.
Understanding how the drive system works and what to tune makes a lot of difference, as when set up they can be quite fun.
nrg-mental
PostPosted: 07:48 - 15 Mar 2008    Post subject: Reply with quote
erm... well i went and took the casing off and removed the fan like plastic piece and then i came across a problem. i cant undo this copper looking part that has the cluch sat behind it, it just spins, any sugestions??? then i tried to do the rollers and the rollers came with a part that you bolt onto the main part to stop the hole thing spinning. well it ended up snaping were one of the bolts for the casing straight off Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad . so i gave up on that to. i have done these things on a sym and a vision before and had no trouble now im not sure i ever wana touch the bike again... ow i also found a jet in the box of the exhaust... there is no chance im gona try fitting this my self lol
Finglonga
PostPosted: 11:45 - 15 Mar 2008    Post subject: Reply with quote
nrg-mental, what's your problem? Be a man and say, don't fanny about with the kama if you have a problem! Your first rating has been revoked(thanks) so you do the same rating again on the same post?!?!?!
How the feck is a guy eating popcorn ABUSIVE? Rolling Eyes
Andy Sez....
F.Y.Y.F.F.
nrg-mental
PostPosted: 12:30 - 15 Mar 2008    Post subject: Reply with quote
whats your problem, i just need help not some 1 posting popcorn eating faces......
ljwalker
PostPosted: 18:39 - 15 Mar 2008    Post subject: Reply with quote
do u know what rollers you got in it mate Thumbs Up
nrg-mental
PostPosted: 19:03 - 15 Mar 2008    Post subject: Reply with quote
they are standard rollers, every think is standard but the exhaust Wink
ljwalker
PostPosted: 19:32 - 15 Mar 2008    Post subject: Reply with quote
maybe try changing the rollers i heard this helps but not really too sure to be honest Confused
bearwood.beckham
PostPosted: 19:33 - 15 Mar 2008    Post subject: Reply with quote
Change your rollers and it'll be fine..
The last post was made 17 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 126.52 Kb
