Author |
ljwalker |
 ljwalker Nitrous Nuisance
 Posted: 10:38 - 15 Mar 2008 Post subject: battery problem |
i have yet another problem with my bike the battery seems to die very very quickly, i charge it up and the next day it will be dead again.
can anyone help me ?  |
Back to top |
hmmmnz |
 hmmmnz Super Spammer
 Posted: 10:57 - 15 Mar 2008 Post subject: |
got an alarm??
have you got a multi meter??
if so disconnect the battery and connect up the multi meter in siries (inline with the + on the battery) and select Amps and see if when the bike is off if it is drawing any current, if its not then its safe to say that you need a new battery, if it is, pull each fuse 1 at a time untill he current drops to 0 and then you'll see where the electrickery is going,
and then you are 1 step closer,  ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
Back to top |
ljwalker |
 Posted: 13:19 - 15 Mar 2008 Post subject: |
thankyou very much i will try that, very helpfull  |
Back to top |
Finglonga |
 Finglonga World Chat Champion
Back to top |
ljwalker |
 Posted: 14:08 - 15 Mar 2008 Post subject: |
yes but i replaced the battery last month.  |
Back to top |
Finglonga |
Back to top |
ljwalker |
 Posted: 16:19 - 15 Mar 2008 Post subject: |
it is acid type how do i test it ? when i bought it it was perfectly fine for a couple of weeks very strange.
thanks for your help  |
Back to top |
timjim |
 timjim Trackday Trickster
 Posted: 17:12 - 15 Mar 2008 Post subject: battery |
firstly,with the engine running,check the charge rate..this should be between approx 12.7volts and up to 14 volts,anything less,then you may have a charge/regulator fault.Make sure you check the charge with the lights on and the lights off.I would suspect with the symptoms you describe,the battery is knackered.If youre charging it,make sure you use a charger specified for motorbike batteries....a car charger is too high an output and will fry and buckle the plates inside if left on charge too long....use an optimate..good value at approx 30-40 quid.
I would still look at a suspect battery as the symptoms sound similar to mine!!new battery..no problem!!  |
Back to top |
timjim |
 Posted: 17:14 - 15 Mar 2008 Post subject: battery |
correction to the above statement!!!!!when i mentioned charge the battery with the lights on..i meant CHECK the battery with the lights on and off..this will see what the alternator is doing under loaded conditions..sorry for the confusion!!!Tim  |
Back to top |
ljwalker |
 Posted: 18:30 - 15 Mar 2008 Post subject: |
yes but have nothing to check the charge rate with what do i have to use  |
Back to top |
Finglonga |
Back to top |
ljwalker |
 Posted: 20:24 - 15 Mar 2008 Post subject: |
do you have any idea how much they cost as budget is low at moment and where can i get one from.
thanks for all your help  |
Back to top |
timjim |
Back to top |
ljwalker |
 Posted: 21:02 - 15 Mar 2008 Post subject: |
dont even go there i hate hate halfords they are all a bunch off useless TW*TS in my local one they are all chavs that i cant understand what they are saying. then again they dont like me in there ever i kick up a fuss all the time.  |
Back to top |
timjim |
Back to top |
ljwalker |
Back to top |
Finglonga |
 Posted: 21:25 - 15 Mar 2008 Post subject: |
They were probably going to do a drop test, that's not what you want.
This is what you need . . Clicky, you can get them from most car accessory stores. ____________________ Andy Sez....
F.Y.Y.F.F. |
Back to top |
crphillips |
 crphillips Borekit Bruiser
Back to top |
ljwalker |
 Posted: 22:00 - 15 Mar 2008 Post subject: |
great thanks everyone for your help i will let you know how i get on  |
Back to top |
ljwalker |
 Posted: 22:07 - 15 Mar 2008 Post subject: |
would this work  |
Back to top |
19van71 |
 19van71 Spanner Monkey
Back to top |
ljwalker |
 Posted: 22:28 - 15 Mar 2008 Post subject: |
cool thanks for that  |
Back to top |
glosoli |
 glosoli Two Stroke Sniffer
Back to top |
ljwalker |
 Posted: 10:25 - 16 Mar 2008 Post subject: |
well im going to buy a multimeter today if i cant find out what the problem is i mite just have to take it to the garage although £££ are a bit short a moment.  |
Back to top |
ljwalker |
 Posted: 11:00 - 16 Mar 2008 Post subject: |
i was speaking to my dads mate and he thinks it is the altenater that is the problem.  |
Back to top |
The last post was made 17 years, 152 days ago. Instead of replying here, would creating a new thread be more useful? |
