What exhaust do I have?
Polo
PostPosted: 21:19 - 15 Mar 2008    Post subject: What exhaust do I have? Reply with quote
I have a 97 Blade. I am looking at how much replacement end cans are but I cannot marry up the type I have.
It seems my year of bike should have a 3-bolt type:
https://w3.bikepics.com/pics/2008%5C03%5C15%5Cbikepics-1217177-full.jpg
but my bike has just a normal clamp fitting:
https://w3.bikepics.com/pics/2008%5C03%5C15%5Cbikepics-1217178-full.jpg
So what do I look for as I cant find cans that have a slip on fitting of say 55mm.
Thanks.
My mum smells your fingers
MattHirst
PostPosted: 21:27 - 15 Mar 2008    Post subject: Reply with quote
Is the akra designed to be using with an akra link pipe maybe?
Is your current can the original, someone could of got slip on and use the normal clamping method.
Polo
PostPosted: 21:46 - 15 Mar 2008    Post subject: Reply with quote
No, it's a Scorpion race can.
I see what your saying about the Ackrapovic link pipe but I have looked at a few can manufacturers and if you tab through the bike model drop downs until you get to 1997 Fireblade, they mention "3-bolt type". Confused
McGee
O RLY?
PostPosted: 21:47 - 15 Mar 2008    Post subject: Reply with quote
Slip ons are usually cheaper and more universal.
If you can find out the size of the pipe and all that pretty much any slip on should fit.
Its pronounced Jixxer!
Polo
PostPosted: 22:02 - 15 Mar 2008    Post subject: Reply with quote
Nice one, thanks.
You happen to know any online stores that sell by the mm?
Thumbs Up Karma
sickpup
Old Timer
PostPosted: 22:19 - 15 Mar 2008    Post subject: Reply with quote
Your bike appears to have a Micron system on it.
McGee
O RLY?
PostPosted: 22:21 - 15 Mar 2008    Post subject: Reply with quote
Wish I could help you there, but I have no idea.
May be worth searching ebay for slip ons.
Or give a pm to Type_Mo as he can get some.
Gazdaman
I did a trackday!!!
PostPosted: 22:51 - 15 Mar 2008    Post subject: Reply with quote
Micron have weird sized link pipes. I found this on the bandit.
Normal slip on is 50mm, but my old Micron was 54mm I think.
Sickpup sounds right on the money.
Gaz
Type_Mo
PostPosted: 00:49 - 16 Mar 2008    Post subject: Reply with quote
ive noticed most microns use a 64mm slip on can Shocked
sickpup
Old Timer
PostPosted: 03:04 - 16 Mar 2008    Post subject: Reply with quote
Why shock? 64mm is pretty much a standard.
Polo
PostPosted: 11:08 - 16 Mar 2008    Post subject: Reply with quote
It may well by Micron up to the can, there are no distinguishing marks. However, the can is Scorpion.
The clamp, as you can see , says 51-55, so the size is somewhere therein.
If I can find the exact size, is it possible that this would be the norm, for say, a ZX9-R, R1 etc that would broaden my horizon for searching. Or is the norm for other bikes along the line of the 3-bolt?
Ta muchly.
Type_Mo
PostPosted: 13:14 - 16 Mar 2008    Post subject: Reply with quote
whip the end can off and use a ruler to measure the size of the link pipe then Wink
J.K.R
PostPosted: 13:16 - 16 Mar 2008    Post subject: Reply with quote
Or just leave it where it is and get the verniers out? Razz Wink
www.oldskoolsuzuki.info
Polo
PostPosted: 14:23 - 16 Mar 2008    Post subject: Reply with quote
So if I am to purchase a slip on, it is the link pipe diameter I go by, not the can itself?
Type_Mo
PostPosted: 15:25 - 16 Mar 2008    Post subject: Reply with quote
That is correct mate Wink
Polo
PostPosted: 16:37 - 16 Mar 2008    Post subject: Reply with quote
Thanks chaps.
Type_Mo
PostPosted: 18:22 - 16 Mar 2008    Post subject: Reply with quote
Karma
If its 52mm then i can sort you out with a viper can Wink
Polo
PostPosted: 18:54 - 16 Mar 2008    Post subject: Reply with quote
Duly noted - thanks. Thumbs Up Thumbs Up
PostPosted: 18:59 - 16 Mar 2008    Post subject: Reply with quote
If you find a can that you like but is slightly larger ID than your link-pipe's OD, you can either have an adapter made or have the link-pipe expanded slightly to suit.
The last post was made 18 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 103.29 Kb
