crash bang wallop what a video... need a verdict
MaybeGuy
PostPosted: 23:24 - 15 Mar 2008    Post subject: crash bang wallop what a video... need a verdict Reply with quote
had my worst spill so far on friday, yaaayyy!
cornering at around 15mph, the rear end skipped, and launched the bike into a kerb...
at first i thought the damage was all cosmetic, and i was pretty gutted...
then i noticed the bike wouldnt push... FUCK my front wheel looks like pacman! so thats a £170 fix...
then i noticed bent forks...
then i noticed my oil level looking rather high... and it stinks of petrol Sad
so i get my bike home with RAC folk, and start the strip down and damage report.
basically i need the following:
>new fairings (full set pretty much apart from tiny little mid-section
>rear brake lever
>front wheel (big dent stopping wheel from turning through calipers)
>maybe a rear wheel as it has a bit of a dent in it too
now the thing that worrys me the most is the fuel in the oil...
i cant think of a logical explaination for it.
the only thing i can think of is that when the bike fell, a float bowl stuck open and filled up my cylinder with fuel, and this has somehow seeped down into the sump? at the moment the engine wont turn over... but if the rings are ok, surely the fuel wouldnt get past them??
a compression check 2 days before the crash showed 150psi in each cylinder.
any ideas? ill get some pics up later, the wheel looks sexual!
cheers crashing queers xxx
ZRX61
Victor Meldrew
PostPosted: 01:28 - 16 Mar 2008    Post subject: Re: crash bang wallop what a video... need a verdict Reply with quote
Do NOT!! try to start the bike unless you want a rod to poke a hole in the cases you bonehead!
Drain the oil/fuel out, fit a new oring to the fuel tap, remove sparkplugs & spin the engine over. refill the oil & bob's yer uncle.
Nebzor
PostPosted: 01:58 - 16 Mar 2008    Post subject: Reply with quote
Once again, bad luck with the spill - I know nothing about anything so I can offer you no advice.
Sorry sweety XXx Wink
Peugeot Speedfight 2 - Honda VFR400 - Honda CB500
MaybeGuy
PostPosted: 10:49 - 16 Mar 2008    Post subject: Re: crash bang wallop what a video... need a verdict Reply with quote
theres no fuel tap on a SRAD6, and ive drained the fuel.
ill get the oil out at some point when i have more to put back in.
what was bothering me is how the fuel got there in the first place.
drwizz
PostPosted: 12:24 - 16 Mar 2008    Post subject: Reply with quote
its not uncommon dude for the fuel to get in to the sump after a spill my mate had a harris with a gsxr 1125 engine and that used to spill the tank of fuel into the sump without the bike falling over .............
so as mentioned just drain everything and start over .
checking floats in the carb .
the harris was an Oring perrished
MaybeGuy
PostPosted: 12:35 - 16 Mar 2008    Post subject: Reply with quote
thanks drwhizz, thats a load off my mind...
i was thinking cracked rings or something Very Happy
ill give it a go and get it running again...
im going to order my panels one at a time doing one a week as pay permits, first part to buy is a front wheel, then the forks straightened, then the fairings.
then, once its all done, ill buy a new rear wheel to get rid of the slight dink in the old one...
when im done it should look mint and perfectly stock.
tutton
PostPosted: 14:50 - 16 Mar 2008    Post subject: Reply with quote
On your list to buy?
dont you need to add new forks?
or are they bendable back?
Unlucky, need some drifting lessons? Laughing
MaybeGuy
PostPosted: 14:55 - 16 Mar 2008    Post subject: Reply with quote
they're about 5 degrees bent, so not too bad... if they cant be bent back, they're still usable to a certain extent...
ill be back on the road as soon as i get a new front wheel.
crphillips
PostPosted: 18:07 - 16 Mar 2008    Post subject: Reply with quote
I assume with all of the damage sustained to your bike that your speed of 15mph is a typo?
What year is your bike? carbs or fuel injected?
CBR600RR8 Hannspree Colours, beautiful!
Pie-Roe
PostPosted: 19:05 - 16 Mar 2008    Post subject: Reply with quote
I have no practical advice, I was just wondering where this video you speak of is Cool
Pyro
MaybeGuy
PostPosted: 20:02 - 16 Mar 2008    Post subject: Reply with quote
nope, was actually 15mph... its a carbed bike, 1997 SRAD. pre-USD forks thank god, i think it would have had headstock damage if the forks hadnt bent.
i hit the kerb pretty much head on with the bike at an angle, so all the impact went into one side of my front wheel. that then shot the bike out from under me because it was at an angle.
have you seen that youtube vid of that guy doing a headstand, falling off, and his bike hitting the only lamppost within miles around?
it was like that sort of speed.
as for the title ''crash bang wallop what a video''
havnt you ever seen alan partridge?
youtube it Wink
heres a little mspaint of what happened.
>the stretched circle is the invisible and slippery bump the wheels slipped on.
>square things are cars
basically, as i went round the corner, the wheels slipped on the bump, rear brake was released and reapplied and stopped skidding (i think), but the front just went straight into the kerb.
the kerb in question is about 20cm high Sad
https://img369.imageshack.us/img369/1536/92785424zw1.png
tutton
PostPosted: 21:04 - 16 Mar 2008    Post subject: Reply with quote
Real pics of the bike
Im intrested in how "fucked" this fairing is.
as we repaired some bad shit in the bodyshop..
MaybeGuy
PostPosted: 22:07 - 16 Mar 2008    Post subject: Reply with quote
https://aycu06.webshots.com/image/46245/2001862219716001239_rs.jpg
check the wheel bendage
https://aycu33.webshots.com/image/46592/2001807766229082299_rs.jpg
you can see the forks bent slightly
https://aycu20.webshots.com/image/48139/2001805383943831706_rs.jpg
a bit scrapey
https://aycu22.webshots.com/image/48501/2001855004876802859_rs.jpg
my beautiful can all scuffed up Sad
https://aycu17.webshots.com/image/48336/2001855505141314952_rs.jpg
i have no idea how this happened as this is the opposite side to the one that it landed on :S and how it bent past the windscreen without cracking it ill never know... mystery.
https://aycu28.webshots.com/image/45307/2001800894096135698_rs.jpg
another fork shot
https://aycu22.webshots.com/image/47221/2001808434789933215_rs.jpg
lid damage... got it for xmas Thumbs Up
https://aycu40.webshots.com/image/48119/2001868765003416482_rs.jpg
i started a strip down, this is when i noticed the oil level being stupidly high.
theres no frame damage, the forks dont look TOO bad, so straightenable...
ive ordered some new panels, and at the end of it, im going to get it from this...
https://aycu33.webshots.com/image/33512/2006215421018579523_rs.jpg
to this...
https://aycu21.webshots.com/image/47500/2005869253536915653_rs.jpg
tutton
PostPosted: 22:13 - 16 Mar 2008    Post subject: Reply with quote
That wheel is majorly fucked i was going to suggest getting a refurb company to straighten it but thats not viable,
How about phoning up loads of breakers tommorow see if you can get a wheel, maybe not the same colour, but just so its rideable, till you can get it sprayed?
The farings could be repaired, but the repair bill for that is probably going to be as bad as getting new ones. If that wouldnt cost alot to post them down id tell you to post them to me, and id repair them lol.
Lid - christmas present, well im sure whoever gave it to you, will be more happy it stopped your brain turning into slush, than scraping it (maybe even making it unusable if your a real safety watcher)
MaybeGuy
PostPosted: 22:25 - 16 Mar 2008    Post subject: Reply with quote
ive been scouring ebay since friday, and emailing people who are selling GSXR's with spare sets of wheels. no joy yet... a brand new front wheel is £169, but i dont really want to pay that much for it as i earn less than that a week at the moment.
so far ive bought a left hand side fairing that looks like the one in the last picture for £9.99, bargain Very Happy its got some scuffs, but theyre only on the white bits, so ill be able to sand, spray and laquer them.
im bidding on a nosecone at the mo like in the pic, but once ive got that (if i win), then im going to wait until thursday (payday) to get the wheel, then at least im on the road.
im also considering getting wing mirrors with integrated indicators... good idea? or is it likely to be one of those 'mods' that lowers the bikes value?
tutton
PostPosted: 22:34 - 16 Mar 2008    Post subject: Reply with quote
Ye, maybe get on to some local breakers as well tommorow, might be possible they have a similar wheel going pretty cheap Smile
Mod liks the integrated indicators is more a taste thing, some people like original work, some don't, if it were me id have integrated, but often doing work to a bike like that unless its can or tailtidy looses money. although at the end of the day its your bike style it how you wish!
MaybeGuy
PostPosted: 22:42 - 16 Mar 2008    Post subject: Reply with quote
i dont think ill bother with my local breakers, as when ive asked about SRAD parts previously, they didnt have anything at all.
ive got a GSXR400 with wheels, but i doubt it would fit, as its a 71B model and has the front wheel smaller than the rear by a noticeable amount.
i think ill save for a stock one as id rather not buy twice.
what i was thinking regarding the indicators is the LED ones.
they require less power so flash faster.
so if i was to have both side LED, as well as the mirror LED's, it would flash slower?
i know LED lights are chav poser associated, but they're just cheaper.
crphillips
PostPosted: 22:46 - 16 Mar 2008    Post subject: Reply with quote
Ah well if it's a carb'd bike i can tell you how the fuel got in there. Every bike/car engine has a crankcase breather.......due to environmental laws that were passed around 1996 the breather hoses from an engine had to be plumbed into the air box so that fumes from the crankcase were fed back into the cylinders and burnt.
When your bike has fallen over the floats in the carb's will not have closed the flow of fuel thus spilling fuel into the inlet manifold and air box. Chances are some of your cylinders may have fuel in them and it would be worth taking out the plug and cranking.....the way the fuel will have got into the crankcase will be through the breather hose from the air box.
Change oil and and filter and you should be up and running again.
That's some major damage for 15mph.....i've seen bikes crashed on a track at 115mph with less damage:-)
MaybeGuy
PostPosted: 22:50 - 16 Mar 2008    Post subject: Reply with quote
thanks a lot for that, thats a load off my mind, never thought of that.
would that mean if i was to re-route this breather, it would increase engine efficiency?
say i was to add a 'u bend' and route it towards the ground.
crphillips
PostPosted: 22:54 - 16 Mar 2008    Post subject: Reply with quote
You can gain a little power usually by removing the breathers from the air box and venting straight into the atmosphere. You'd never notice the perfomance gain on the road though.
MaybeGuy
PostPosted: 22:59 - 16 Mar 2008    Post subject: Reply with quote
hmm, interesting to know that, but it wont make a difference to me then, as its 33bhp.
ill leave as is Very Happy
McGee
O RLY?
PostPosted: 20:42 - 19 Mar 2008    Post subject: Reply with quote
That sucks man.
Best of luck getting her mint.
Its pronounced Jixxer!
MaybeGuy
PostPosted: 15:47 - 26 Mar 2008    Post subject: Reply with quote
got my left and right panels now... and a wheel.
left side panel like the one in the ''what i want it to look like'' was £10... the right hand side was £15 Very Happy
little scuffed, but ill either touch it up or slap some stickers over.
the wheel was £93 off ebay with a tyre. hopefully a decent one.
yet to get the wheel or the right side fairing... damn post.
im using this as an excuse to give it a nice clean as i put it back together. whore pics to come!
Finglonga
PostPosted: 22:54 - 26 Mar 2008    Post subject: Reply with quote
That damage at 15mph . . . . Suzuki build quality has taken a nose dive or the kerb was 6foot high. Confused
Andy Sez....
F.Y.Y.F.F.
MaybeGuy
PostPosted: 23:10 - 26 Mar 2008    Post subject: Reply with quote
thats what i thought, but it seems all the impact went into that one side of the wheel.
if you look on the other side, theres no damage at all.
The last post was made 18 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.12 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 145.47 Kb
