Bike thief killing device
Rowey
PostPosted: 16:23 - 18 Mar 2008    Post subject: Bike thief killing device Reply with quote
Hey guys, been a bit concerned about my bike recently, was parked at my mates house, and the alarm kept going off. His area is well know for pikeys (west drayton), In the end I had to disarm the alarm, due to his parents trying to sleep. I was really worried it could be pikeys or chavs pissing about with it.
I was wondering, is there anyway I could modify my bike, with some form of device, that if it isn't deactivated, the bike won't move, or a quarter mile up the road, the front brake will lock, or something or the sort. Just so If someone does try stealing my bike, they can't or will get fucked in the process.
I did think about removing a nut from the wheel but it seems too much hassle, loosening and tightening everytime, or maybe a padlock or something over the brake lever to lock it on.
Any Ideas, It has to be portable, and cheap. The more gore and crazy the better Karma
ZX6R C6F.
Shaane
PostPosted: 16:27 - 18 Mar 2008    Post subject: Reply with quote
Rig your bike up to a semi automatic mini gun Smile
Or.. Use CCTV etc in case something does happen.
Or a few disc locks/ chains or ground anchors.
Previous: 1992 DT125R
Current: ~ 2005 ZX6R C1H
Gazdaman
I did a trackday!!!
PostPosted: 16:31 - 18 Mar 2008    Post subject: Reply with quote
You can get throttle locks. But locks are the way forward, and locking it /to something/.
Also, a cheap DIY imobiliser is to wire a switch into the low tension side of the coil. So when the switch is off, it won't spark.
Doesn't stop chavs wheeling it away though, just starting it. A big lock round a lamppost probably will though.
Gaz
Richard_Schmid
PostPosted: 20:11 - 18 Mar 2008    Post subject: Reply with quote
Just leave the emergency stop in the wrong position...
That`s kept me scratching my head many atime.
Finglonga
PostPosted: 20:54 - 18 Mar 2008    Post subject: Reply with quote
Or the kill switch. Wink
As said chain it to something solid then it should be there when you go back to it as long as you don't skimp on the chain you use.
Andy Sez....
F.Y.Y.F.F.
mr.z
PostPosted: 21:05 - 18 Mar 2008    Post subject: Reply with quote
another less obvious thing is a cover, a dull coloured one.. just haveing it where it can't be seen will make it much less likely to go walkies.
or padlock on the brake disc, they might get it off but after fucking the disc it'll be going nowhere.
another quite clever thing i've seen is a lock which fits on your tyres valve, take it off without unlocking and the tyre goes down.. ever tryed to move a bike with a flat tyre? wont deter anyone wanting it for the back of a van but thats not likely unless its worth anything, i'd say 95% of the time it'll be pikey scum, specially smaller bikes and scooters.
Mac_Black
PostPosted: 22:32 - 18 Mar 2008    Post subject: Reply with quote
lol wtf is a semi-automatic minigun?
no offence but that is tha world's most retarded concept,
think about it, a self loading, chain fed, air/spin cooled multi barrel gun that only fires one round per trigger pull Laughing
Finglonga
PostPosted: 22:47 - 18 Mar 2008    Post subject: Reply with quote
From the same people that made the break barrel, pump action shotguns. Wink
Andy Sez....
F.Y.Y.F.F.
pa_broon74
PostPosted: 22:57 - 18 Mar 2008    Post subject: Reply with quote
Some sort of automatic garrot.
I piano wire, probably a high C or G depending on your mood springs up out of a contraption on the handle bars, lasoo's (sp?) anyone sitting on the seat and tightens (possibly some sort of hydraulic system) thus decapitating the erst-while rider...
Need to remember to deactivate it before sitting on it yourself...
Failing that, chaining it to a lamp post is good. I got a good deal on a D lock and metal rope thing. D lock goes through the front forks with the two loops at the end of the wire rope threaded through.
All fits under the seat on my tiny hair dryeresque bike...
(Oh, and flick the kill switch, every little helps...)
Didn't catch anything.
Shaane
PostPosted: 23:04 - 18 Mar 2008    Post subject: Reply with quote
Mini Gun Very Happy
https://youtube.com/watch?v=oLAIemsdmTM
How it works Very Happy
https://youtube.com/watch?v=kxFMFZVQ968&feature=related
How Cool are they Smile
PostPosted: 23:13 - 18 Mar 2008    Post subject: Reply with quote
Problem with a theif killing device is if you forget about it it will kill you.
You'll be all over the news as 'Man murdered by motorcycle' Laughing
pa_broon74
PostPosted: 23:15 - 18 Mar 2008    Post subject: Reply with quote
Shaane wrote:
Scary, although that guy was hitting nothing... I reckon I could survive it...
(I might patent my garrot device, I think it has legs... Dragon's Den?)
Shaane
PostPosted: 23:17 - 18 Mar 2008    Post subject: Reply with quote
LoL IT fires like... So many thousand rounds a minute Smile
I wouldn't even attempt to 1 vs 1 it Razz
Mac_Black
PostPosted: 03:02 - 19 Mar 2008    Post subject: Reply with quote
Shaane sorry I was being a bit of a gun nerd...
My point is miniguns are fully automatic, as are light machine guns and assault rifles ect.
Where as most hanguns and an assortment of sniper rifles, shotguns and even grenade launchers are SEMI-automatic, that cycle semi automatically aided by recycled gasses that force tha slide/ cocking mechanism back and load a round ready to fire (known as blowback).
Fully automatic weapons are based on several machanisms,
firstly there are blowback systems very similar to that of a semi auto gun apart from tha fact that in blowback guns tha rapid expansion of gases will force tha actual bolt back.
Then there is Gas driven which is basically tha same except it diverts tha gas back towards tha bolt through tha use of a piston that recocks tha cycle.
Then there is a recoil effect gun, many of tha early gatling guns and MG's are based on this, where tha force of tha bullet creates an equal reaction where tha gun kicks back, though this 'recoil' is captured in tha mechanism which uses tha barrel to cycle tha rounds.
If thats sorted you, Great Thumbs Up
In any case I'll shut up now.
Louise
PostPosted: 08:44 - 19 Mar 2008    Post subject: Reply with quote
I see this on Ebay a while back and was thinking of getting one.
Not sure if there could be around it tho for the scum.
Clicky
PostPosted: 08:52 - 19 Mar 2008    Post subject: Reply with quote
between 6k and 3k rpm. Cool
Timmeh
PostPosted: 13:31 - 19 Mar 2008    Post subject: Reply with quote
Tie a piece of rope to the exhaust.
they'll try to ride off and then bang, off they come.
I've always thought about buying crap CGs and turning them into deathtraps, then leaving them so the chavs will try to steal them and kill themselves on it.
Sparkplug inside the fuel tank sounds like a good start, or maybe explosive fork bolts.
Shaane
PostPosted: 13:41 - 19 Mar 2008    Post subject: Reply with quote
Damn... And i thought my imagination lead me a stray Razz
TheDonUK
PostPosted: 14:24 - 19 Mar 2008    Post subject: Reply with quote
Ugh, West Drayton/Hayes, Really the dregs of london live out here, not the kind that are "hard" enough to actually carry guns or sell drugs, proper typical suburban chavs... Drop a bomb on the whole fuckin area.
Wouldent surprise me at all, Mr.Z said it, a cover mate, a boring looking one, If they dont know what it is they dont know they want to steal it, and invariably they are too lazy and feckless to take off the cover and have a look. My cover goes on every night not because of the rain, but to keep prying eyes off my bike...
Louise
PostPosted: 15:39 - 19 Mar 2008    Post subject: Reply with quote
Laughing Me being me would forget about things like that, ride off then thud I go.
Even a chain, I ride off with it still attached to the wheel Mr. Green
AngelGrinder
PostPosted: 19:29 - 19 Mar 2008    Post subject: Reply with quote
Clicky
They would likely just cut the front brake line Crying or Very sad
virus
PostPosted: 20:06 - 19 Mar 2008    Post subject: Reply with quote
i belive the armstrong mt500 has a unboltable headstock designed for easy dissasembly and transport. exploding bolts there would be fun, chav nicks bike, press button and bang , the chav is rolling down the road on a heavy unicycle Laughing
own: 81 xs1100g...
sickpup
Old Timer
PostPosted: 21:54 - 19 Mar 2008    Post subject: Reply with quote
Can get those off with no noise in about 2 seconds.
Louise
PostPosted: 22:19 - 19 Mar 2008    Post subject: Reply with quote
Was thinking more along the lines for the clutch.
But as Pup just mentioned not worth bothering.
The last post was made 18 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 128.38 Kb
