70cc kits
benjy bwoii
PostPosted: 20:52 - 18 Mar 2008    Post subject: 70cc kits Reply with quote
can 50cc cranks take the power of the 70cc kits.cheerz.
PostPosted: 20:57 - 18 Mar 2008    Post subject: Reply with quote
It's not designed to take the extra weight of the piston but it will cope with it.
benjami
PostPosted: 21:53 - 18 Mar 2008    Post subject: Reply with quote
It also depends on what 70 kit you're thinking of, and the milage of the original crank.
prawny1
PostPosted: 22:34 - 18 Mar 2008    Post subject: Reply with quote
If the standard cranks can handle pulling my 18stone uncle around then i should think a 20cc capacity hoik would be fine.
Its high revs that small 2t cranks hate, they just twist or spit there big end bearings everywhere,
If your worried about your crank twisting or something from the extra power don't it should be fine,
but if you are worried then you could have the big end pin welded which will stop twisting but makes the crank unservicable when it wears out.
PostPosted: 23:44 - 18 Mar 2008    Post subject: Reply with quote
Thats a 40% increase.
PostPosted: 23:50 - 18 Mar 2008    Post subject: Reply with quote
It could be only slightly heavier though if the original piston was steel and the 70cc is aluminum.
PostPosted: 00:13 - 19 Mar 2008    Post subject: Reply with quote
If would way less if the new piston was made of marshmellow.
PostPosted: 00:59 - 19 Mar 2008    Post subject: Reply with quote
Toasted marshmellows Mr. Green
colin1
Captain Safety
PostPosted: 01:13 - 19 Mar 2008    Post subject: Reply with quote
i think its more overheating that you have to worry about, but im not an expert on modifying 50cc bikes
The last post was made 18 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.69 - MySQL Queries: 15 - Page Size: 59.96 Kb
